Ok soo i just got this kpro off Craigslist for super cheap. What i wanna know is if it is for my year rsx. I have an 03,is there anyway to know what year its for?? And also how to install it(if there’s anything else i need to do other than plug it in) any help would be appreciated
Yes it will work on your 03. You most likely will be able to use one of Hondata’s free can tunes to get your car running but you should get a custom tune even if it is an etune. The ECU is bolted to the firewall with a plug connection (ECU is located under the glovebox). Download Hondata software onto your computer and then transfer their can tune to your ECU using the cable coming out Kpro 3 ECU. Go on their website for more information.
Also im seeing that the ecu i got is a PRC,not a PRB like it says on hondata that is for my 03 type s. Will this one still work? Looks like its off a type r dc5
I’m guessing all you have is just the k-pro v3 circuit board itself. To the best of my knowledge you need Hondata’s hardware that matches your 2003 RSX-S PRB type ECU. Even if you had the correct circuit board I have no experience on how to install it. I sent my ECU into Hondata for them to install and test. Sorry.
Related Threads
29.7M posts
179.4K members
Since 2001
