Replacement of stock struts/springs - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Suspension, Chassis & Brakes
Reply
Thread Tools
Old 09-25-2018, 08:03 PM   #1
kakMclaren570s
New Member
kakMclaren570s's Avatar
kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx kakMclaren570s is a jewel in the rough of c-rsx
Garage
Hey all,
My struts are busted and gone. I'm in the market to replace my 02 base auto with a fresh set of struts/springs. I've always had great luck with the eibach/koni combo with my Integra's in the past. Suggestions. Also, depending on the kit I purchase will a camber kit have to be purchase?
Best regards,
Timmay
kakMclaren570s is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-25-2018, 09:11 PM   #2
marko16
Senior Member
marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx marko16 might be well recognized one day on c-rsx
No need for a camber kit. Tein, BC and Ksport make great products
It matters zero if I dislike your reality.
marko16 is offline   Reply With Quote
Old 09-26-2018, 01:42 AM   #3
daje00
Master Member
daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx daje00 is a jewel in the rough of c-rsx
Get a set of Tein coilovers, you can get them for around $500. Will ride much better than any koni or eibach combo.
05 Rsx S k20z1
Ktuner end User (220/162)
Invidia RH, Exedy Stage 1 Clutch
Vibrant Stealth Muffler
Injen CAI , Hondata IMG, RBC IM, RDX Injectors
VibraTechnics rear mount
daje00 is offline   Reply With Quote
Old 09-26-2018, 09:24 AM   #4
BrutalB83
WILDCARD!
BrutalB83's Avatar
BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx
Are you talking about the Eibach Pro-Kit or the Sportline? With the Pro-Kit, you can probably get away with no camber adjusters.
As daje00 said, another option is to go with the Tein Basis. That's what I have. It's a great, cost effective combo for daily driven cars.
BrutalB83 is offline   Reply With Quote
Old 09-26-2018, 07:57 PM   #5
kakMclaren570s
New Member
Garage
Found a sweet deal on a set of Tein Basis Z coilovers. I need to find a place to install them. Ya'll know ballpark what the cost is to install? I'm sure the dealership will be a rip off. Also, what setting should the car have with this setup? Do the coilovers come preset from the factory? This is my daily driver and not super concerned with performance.
Old 09-27-2018, 07:00 PM   #6
ali626
New Member
ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx
$20-30 per corner. should be preloaded from factory, don't touch the spring preload setting. just unlock lowest perch and rotate shock body to find your desired height, and adjust valving (clicks SOFT ~ HARD). if you daily put it like 6-8 clicks away from full soft all around
you can also try to DIY. not that hard. takes me an hour to do it on a rsx after so many times now. a beginner should take 4-6 hours.
ali626 is offline   Reply With Quote
Old 09-27-2018, 08:27 PM   #7
kakMclaren570s
New Member
Garage
Great. Thanks for the info. I've come to the conclusion that I'm going to install myself. I recently got an amazing deal on the following oem replacement parts for the front suspension.
END, TIE ROD
53541-S7A-003 - Set of two
LINK, L. FR. STABILIZER
51321-S5A-003
Link, R Front Stabilizer
51320-S5A-003
BUSH, STABILIZER HOLDER (19MM)
52306-S6M-A01 - Set of two
KNUCKLE, L. FR.
51215-S6M-A00
KNUCKLE, R. FR.
51210-S6M-A00
I was like while I'm replacing the struts I might as well replace the above components. The car is 18 years old and needs a fresh set of suspension pieces.
Anything that stands out to be a bitch to install?
Old 09-27-2018, 08:32 PM   #8
kakMclaren570s
New Member
Garage
Forgot to mention what the best ride height is without purchasing a camber kit?
Old 09-27-2018, 09:30 PM   #9
daje00
Master Member
Hey the Tein basis Z doesn't have adjustable damping. The only adjustment you can make is the ride height. If you want the Adjustable damping you need the street advance Z. I have the street advance Z and I love them.
05 Rsx S k20z1
Old 09-27-2018, 10:39 PM   #10
ali626
New Member
END, TIE ROD
51321-S5A-003
51320-S5A-003
KNUCKLE, L. FR.
51215-S6M-A00
KNUCKLE, R. FR.
51210-S6M-A00
why change knuckles if its not damaged? if you want to improve the stability i'd recommend bushing kit.
https://www.kseriesparts.com/ENS-16-18111R.html
Old 09-27-2018, 10:48 PM   #11
daje00
Master Member
The most you'd need from knuckles is the ball joints and those you can get seperately.
05 Rsx S k20z1
Old 10-16-2018, 03:38 PM   #12
kakMclaren570s
New Member
Garage
Ok. I'm installing the coilovers this weekend. What is the best ride height to set at and how do you do that exactly? How much will the car drop without any adjustment from the factory? I'm just street driving and don't need the car to be slammed and have any issues with camber and premature tire wear.
Old 10-25-2018, 11:46 AM   #13
BrutalB83
WILDCARD!
BrutalB83's Avatar
Have you opened the coils yet? There should be instructions inside on adjusting height, and Tein does have a recommended ride height. To adjust, you twist the collars on the bottom of the shocks with the provided wrench.
Reply
Bookmarks
replacement , stock , struts or springs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
