DIY Guide To Removing Caliper Paint - Club RSX Message Board
Reply
Thread Tools
Old 07-29-2007, 01:50 PM   #1
DC5Berry
Communication Breakdown!
DC5Berry's Avatar
DC5Berry is an unknown quantity on c-rsx
I had some people that were interested in seeing if this would work.
About a year ago, the first thing I did to my RSX was paint my calipers Dark Ford Blue with Dupli-Color spray paint. It looked kind of cool at first, but in reality it was pretty cheap looking ("ricey") as most would say. Anywho, it started chipping off after a couple months which made it look all the worse. I tried using a wire brush to scrub it off, but it just wasn't cutting it. My calipers looked ridiculous and I wanted the paint gone so I wouldn't look cheap anymore.
So this is a DIY guide for those of you who, like me, suffered or currently suffer from Caliper Painter's Remorse, also known as CPR
Caliper Paint Removal
Products needed:
Aircraft Remover (paint thinner) in an aerosol can
Small wire detailing brush (size of a tooth brush) or a toothbrush
Painters tape (blue or green, half in.)
Latex gloves (double up when spraying the thinner)
Disposable towels (Place under the rotors to avoid paint getting on the ground)
Process:
1) Park in a cool area and on level ground. If it is hot, you will want shade for your own sake.
2) Make sure your car is on jack stands
3) Remove all rims
4) Tape off the surface of the rotors with painter's tape (I used 3M)
5) Put on 2 latex gloves on the hand you will be spraying with. (A.K.A. - Double up)
6) Shake the spray can of paint thinner well for a minute or two.
7) Spray the caliper conservatively with the paint thinner. Remember, if this gets on your paint, you will hate yourself. Do about 3 passes with the spray across the caliper.
8) Let the thinner sit on the caliper for 5 minutes to allow the acid to melt the paint. I recommend walking around to kill time or reading your favorite car magazine. I chose Motor Trend.
9) After the paint boils up and your caliper is no longer soaked with paint thinner, begin to wipe away the paint from the caliper. That's right...wipe. No scrubbing is needed. The paint simply falls off.
*A word of CAUTION: If you scrub your caliper and the little pieces of paint get on your arm, face, or hand, you will feel a very intense burning sensation. It will feel like your skin is melting off. I suggest you immediately immerse the area with water and wipe away with a towel as soon as you realize what has happened.
10) Use a Q-tip to remove paint from the small crevices of the caliper
11) Remove the painter's tape from the rotor and start on the next caliper.
Pictures for those that are visually learners:
Paint thinner
When I first painted my calipers
After half a year (Most had chipped away, but some a lot still remained)
The blue on the rotors is painter's tape. You can see the paint boiling off from the acid
Afters (The blue stuff is painters tape)
For those that are wondering:
My brakes work the same as they did before doing this project. I've driven on them for 2 days already and no problems, noises, etc.
Paint thinner is fun to use, but it is also very dangerous. I realize that it is probably not good for your rotors or brake pads. This is why I suggest that you spray conservatively and carefully. Treat it like spray paint and move in concise passes, not direct spray shots. Do this, and you will get good results. Don't do this, and you will have an accident on your hands.
Total time expectancy: 30 minutes to 1 hour
Remember: Prep is key.
'04NBP
DIY JDM style headlights, 06 Type-S rims, Fujita SRI, Red-Outs
I detail...on the side.
M.D.(Memphis.Detailer.) Crew Member #1
MEMPHIS TIGERS!
DC5Berry is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-29-2007, 01:58 PM   #2
2010 admin
Guest
Posts: n/a
Good DIY. Thanks for sharing.
Old 07-29-2007, 02:03 PM   #3
riceman
WWJDMD?
riceman's Avatar
riceman has been a little shit in the past
Good work. Paint stripper in a tin can that you brush on will do the job as well (less masking). You can get those at Home Depot.
92 Frost White Integra LS-Vtec - 2.1 NA - sold
06 PWP Type-S - little show limited go
08 UG R32 - sold
Rice fo Life y0!
riceman is offline   Reply With Quote
Old 07-29-2007, 03:26 PM   #4
JByron
Master Member
JByron is an unknown quantity on c-rsx
that shit BURNS lol. Burned right through my latex gloves (double layered). Make sure to buy the chemical resistant gloves at home depot while you are at it.
JByron is offline   Reply With Quote
Old 07-29-2007, 03:37 PM   #5
Gradydc5
12345678-87654321
Gradydc5's Avatar
Gradydc5 is an unknown quantity on c-rsx
and try not to fling any on your arm.
1992 Honda Civic SI - Daily
2002 Acura RSX Type-S - SOLD
2006 Honda S2000
Gradydc5 is offline   Reply With Quote
Old 07-29-2007, 03:41 PM   #6
DC5Berry
DC5Berry's Avatar
Yeah, and don't get coolant in your eye
'04NBP
MEMPHIS TIGERS!
Old 07-29-2007, 09:25 PM   #7
articbluedc5
Master Member
articbluedc5's Avatar
articbluedc5 is an unknown quantity on c-rsx
yes it does, I got some on the bottom of my wrist I thought I was goign to die learned my lesson...nice diy
09 Civic Si Sedan
Caleb's Customized Alarm Install
All stock
articbluedc5 is offline   Reply With Quote
Old 07-30-2007, 12:27 AM   #8
koreaplayer4lyf
New Member
koreaplayer4lyf's Avatar
koreaplayer4lyf is an unknown quantity on c-rsx
(o.0)KiMcHi(0.o)
koreaplayer4lyf is offline   Reply With Quote
Old 07-30-2007, 01:27 AM   #9
Game
Game's Avatar
Game might be well recognized one day on c-rsx Game might be well recognized one day on c-rsx Game might be well recognized one day on c-rsx Game might be well recognized one day on c-rsx Game might be well recognized one day on c-rsx Game might be well recognized one day on c-rsx
Any idea if this would remove powder coated calipers?
MIDWEST CREW
LAKERS!!
Game is offline   Reply With Quote
Old 07-30-2007, 02:47 AM   #10
RollinDownI95
Member
RollinDownI95's Avatar
RollinDownI95 has been a little shit in the past
nice job
RollinDownI95 is offline   Reply With Quote
Old 07-30-2007, 08:45 AM   #11
DC5Berry
DC5Berry's Avatar
I remember you talking about wanting to get rid of that paint from the previous owner. I'd give it a shot because the paint literally just melted. I didn't have to scrub at all. I would think paint, no matter how applied, whether by spray, brush, or powdercoat, would have the same reaction to paint thinner.
Aren't our valve covers powdercoated...and rims? I would think if people use this on their VC and rims, that it should work on calipers that are powdercoated as well. It's fun stuff!
'04NBP
MEMPHIS TIGERS!
Old 07-30-2007, 04:42 PM   #12
vltnolia
Senior Member
vltnolia's Avatar
vltnolia is an unknown quantity on c-rsx
THats ugly. Good diy
05-06 Acura RSX Type S I Want Again
vltnolia is offline   Reply With Quote
Old 08-02-2007, 07:18 AM   #13
EGSwap
Owner of Racecoated
EGSwap's Avatar
EGSwap is an unknown quantity on c-rsx
Stock rims and vc are painted, not coated. But yes, Aircraft stripper will remove powder coating as well.
Steve
I accept and embrace the ricer in me.
EGSwap is offline   Reply With Quote
Old 08-02-2007, 08:13 AM   #14
DC5Berry
DC5Berry's Avatar
Steve
Thanks for the info
'04NBP
MEMPHIS TIGERS!
Old 08-02-2007, 08:58 AM   #15
VIKItypeS
Rockin' in the 808
VIKItypeS's Avatar
VIKItypeS is an unknown quantity on c-rsx
Thanks for the DIY
Groovin' to the Beat of life
http://www.soundclick.com/nemesismuzic
VIKItypeS is offline   Reply With Quote
Old 08-02-2007, 09:50 AM   #16
03blackRSX1028
Master Member
03blackRSX1028's Avatar
03blackRSX1028 is an unknown quantity on c-rsx
yea nice DIY man
** RIP oShieT iTs LonnY **
03blackRSX1028 is offline   Reply With Quote
Old 08-02-2007, 10:26 AM   #17
speed_jaycer
I am a victimless crime
speed_jaycer's Avatar
speed_jaycer gets around and is known
speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known speed_jaycer gets around and is known
i think one of your biggest probs was that you literally painted EVERYTHING around the calipers and rotors blue...but regardless, looks much better with no paint...nice DIY
2006 BMW 530i
2005 Infiniti G35x
2008 Honda CBR600RR
Motorcycle crew #69
www.mycanikon.com Best photo forum on the web
join if you love camera's and list me as your referrer.
speed_jaycer is offline   Reply With Quote
Old 08-02-2007, 12:29 PM   #18
DC5Berry
DC5Berry's Avatar
You're right...pretty stupid huh
'04NBP
MEMPHIS TIGERS!
Old 08-02-2007, 02:43 PM   #19
EGSwap
Owner of Racecoated
EGSwap's Avatar
I've seen much worse...much worse.
Old 08-02-2007, 03:15 PM   #20
DC5Berry
DC5Berry's Avatar
Thanks for the compliments everyone.
'04NBP
MEMPHIS TIGERS!
Old 12-19-2008, 10:05 PM   #21
jusdc5
Senior Member
jusdc5's Avatar
jusdc5 is an unknown quantity on c-rsx
instead of painters tape could i use some kind of cloth to cover the rotors and brake pads?
jusdc5 is offline   Reply With Quote
Old 12-19-2008, 10:12 PM   #22
Jon Reremy
Stick it in her Yeah
Jon Reremy's Avatar
Jon Reremy is an unknown quantity on c-rsx
You don't need to. Paint thinner is not very violent stuff. Your rotors and pads will be fine. If anything, paint thinner is oil based and leaves kind of an oily film. I suggest cleaning the whole area with either lacquer thinner or brake cleaner afterwards.
One more thing, OP, paint thinner is not acidic.
You are now breathing and blinking manually.
Jon Reremy is offline   Reply With Quote
Old 12-20-2008, 12:58 PM   #23
jusdc5
Senior Member
jusdc5's Avatar
thanks for the info man
Old 12-20-2008, 01:58 PM   #24
tuner-stop
ArmenianCRSX Crew Founder
tuner-stop's Avatar
tuner-stop is an unknown quantity on c-rsx
Products needed:
Process:
3) Remove all rims
Paint thinner
how will you have an accident from painted calipers?
-Naz 08IS250 w. navi + misc.
1st ever BuddyClub N+ Coilover system for Lexus, Sponsored in part by BuddyClub.USA<-click
Armenian crsx crew member #1
LA Lakers 65-17 LOOKS/LUXURY > SPEED! posting from work /
tuner-stop is offline   Reply With Quote
Reply
Bookmarks
caliper , diy , guide , paint , removing
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
