D.I.Y Battery In hatch - Club RSX Message Board
Reply
Thread Tools
Old 09-20-2010, 01:46 PM   #1
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
*PLEASE CHECK OUT THE UPGRADED DIY WITH ADDITION GROUNDING**
http://forums.clubrsx.com/showthread.php?t=1144338
Ok this one is kinda long because of all the pictures. But here I go with yet again another DIY. So today, with the help of Gigs, Nick, and Silvia I relocated my new Odyssey Battery to the rear hatch of my Type-S.
So first, you don't have to get everything I did but I would recommend something similar. So for this install you'll need:
Batter
Battery Box
4 Gauge Bulk wire (minimum size I recommend)
Connectors
Fuse Box
Splitter Box
and Misc. Tools
Ok So lets begin!
First we started by picking a spot in the hatch where we would locate the new battery. We decided the driver side for my trunk will do
So then we took out the panels inside the hatch so that we can start mocking up wire locations and where we'll bolt down the bracket.
Next we found the exact spot and made marking in the carpet where our holes will be
Then take out the drill and begin drilling your holes
Here is the bracket mounted and bolted down
Next we decided where the cables will run down threw the carpet and into the car. We marked our spots and drilled those too.
From there we next decided where to put my fuse box. Next to the battery of course. You never want to be more than a 12" away
That was that for the front. Then we moved to the engine bay
Type-Spaz is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-20-2010, 01:47 PM   #2
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
So first start by taking out the stock batter and it's battery tray
Here is a better shot of my distribution block. Also the fuses installed
Then we had to find a spot for the wire to come through. We used a stock wiring harness and you can kinda see it through the mess
We poked a hole in the rubber from the inside and started feeding the battery cable through it. From the outside to inside
Here is a shot from the inside
The cable comes in from under the carpet so you will have to lift that up if you use this spot. We then modified the foot rest so the cable would fit comfortably and easy
Here a shot with it installed
Next we started routing the cable. So I took off the side trim and lifted the carpet to place the line down the side of the car
Here it is back together, you can see the line coming out the back
Next route the line under the rear seats and bring it back out the back. We choose the little hole by the struts
We then routed the line down the body line
Old 09-20-2010, 01:47 PM   #3
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Next it's time to do some wiring. I used the stock ground for the taillights for my battery ground
It it's good enough for them, it's good enough for me. Then I place the cable through the carpet and put the carpet back in the car. Don't install the carpet yet, just set it in there.
Check all of the lengths and make cuts to the cable to fit how you would like it. We hooked up the power to the fuse box
Then did the ground and the other side of the power and attached the battery terminal clamps
Thats it for the batter, now back to the engine bay for the rest of the wiring...
So the distribution box I used uses for holding screws. We were only able to fit two into the spot we used but we also used extreme industrial velcro to hold it down to the frame.
Then we cut the positive cable apart and inserted them into the box
Also hooked up the original transmission ground up to the original grounding spot and grounded out my distribution box. Now you should pretty much be done. Go ahead and connect the battery up and check it out.
I used a digital distribution box because I wanted to check the voltage and amps being pushing and pulled.
Now you have a battery relocation!
On another note, you should place the battery on the passenger side to help offset your body weight but I didn't nor am I worried about the 11lb battery.
Old 09-20-2010, 01:59 PM   #4
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
this guy! at it again!
Drewpreme is offline   Reply With Quote
Old 09-20-2010, 02:08 PM   #5
a1r86
a1r86's Avatar
a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though a1r86 is cool, not as cool as some though
good shit
GO LAKERS!
[SIGPIC][/SIGPIC]
a1r86 is offline   Reply With Quote
Old 09-20-2010, 04:26 PM   #6
penguin0123
Member
penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx penguin0123 is a jewel in the rough of c-rsx
So what happened to the original ground (the wire that attaches to the negative terminal of the original battery)?
What is the purpose of the distrubution box? Can one eliminate it?
I tried to construct a wiring diagram and here is what I came up with, is this right?
Original Power Wire Original Ground Wire (?)
Distrubution Box => Transmission Ground
Fuse Box Tailgate Ground
Battery Positive Terminal => Battery Negative Terminal
penguin0123 is offline   Reply With Quote
Old 09-20-2010, 04:45 PM   #7
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
The original ground is gone. The original ground just goes from battery to frame. So the new ground is the same just in the rear. I used a splitter so I could run one wire from the back to the front and split the wire one to the fuse box and one to the alternator up front. If you run separate wires from the battery sure you won't need the splitter but thats more cable and more work.
My transmission ground is now going from the frame under the radiator where there is another ground location to the tranny.
Old 09-20-2010, 06:46 PM   #8
penguin0123
Member
So would the following scheme work?
Old 09-20-2010, 06:58 PM   #9
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Old 09-20-2010, 07:09 PM   #10
recliner15
New Member
recliner15 is an unknown quantity on c-rsx
hope you dont plan on going to the track
recliner15 is offline   Reply With Quote
Old 09-20-2010, 07:39 PM   #11
rlippy001
@AllMotorRy
rlippy001's Avatar
rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though rlippy001 is cool, not as cool as some though
Originally Posted by Type-'S'paz View Post
Nice skillz on the drawing. lol good diy
rlippy001 is offline   Reply With Quote
Old 09-20-2010, 07:47 PM   #12
clean3two3
Master Member
clean3two3 is an unknown quantity on c-rsx
why do you say this?
and nice write up
clean3two3 is offline   Reply With Quote
Old 09-20-2010, 07:50 PM   #13
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
yeah why? I go to the track all the time with no issues
Old 09-20-2010, 07:58 PM   #14
Creepy Chris
Too much drama
Creepy Chris's Avatar
Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList
Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList Creepy Chris needs to visit eHarmony.com or at least the hook up section on CraigsList
Check your track rules on relocated batteries.
I know my local track has specific rules, like needing a kill switch, etc.
Creepy Chris is offline   Reply With Quote
Old 09-20-2010, 08:01 PM   #15
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
so do ours but until you hit 12's are local tracks don't care. Hell I have friends running 11's and the track hasn't cared yet lol
Old 09-20-2010, 08:04 PM   #16
Creepy Chris
Too much drama
Ok, so in your case you have a lenient track. Others though, may not be as lucky. Just a disclaimer for others who may try this and plan on going to the track.
Old 09-20-2010, 08:14 PM   #17
itskien
Doesn't Give A F*ck
itskien's Avatar
itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with
damn son. you're on a roll.
itskien is offline   Reply With Quote
Old 09-20-2010, 09:09 PM   #18
korney
Midwest K Productions
korney's Avatar
korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx korney is a jewel in the rough of c-rsx
yesss!!! I been needing to do this for awhile now!!! thanks Spaz!!!!!
korney is offline   Reply With Quote
Old 09-21-2010, 10:01 AM   #19
sinisterdc5
Master Member
sinisterdc5's Avatar
sinisterdc5 is an unknown quantity on c-rsx
yup most tracks wont let you pass tech if you have the battery in the trunk with out a kill switch
RIPPEDCrew
K-SERIES ONLY Creator
INSTAGRAM:ROZAYDC5
INSTAGRAM:kseriesonly
sinisterdc5 is offline   Reply With Quote
Old 09-21-2010, 06:02 PM   #20
dmike03
Master Member
dmike03's Avatar
dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx dmike03 is a jewel in the rough of c-rsx
i would like to do this but i fail when it comes to stuff like this
Originally Posted by crod06 View Post
Nothing beats dome and country music
Originally Posted by MadVillain View Post
Yeehaw suck my Dick bitch
dmike03 is offline   Reply With Quote
Old 09-21-2010, 06:22 PM   #21
penguin0123
Member
Where did you get the wire? I went to home depot, and they have 1/0 with the really stiff sheath, and the flexible ones are 12-4.
Old 09-21-2010, 07:39 PM   #22
civictype_r
Member
civictype_r's Avatar
civictype_r is an unknown quantity on c-rsx
I have been looking for one ofd these for months!!!!!! Im going to use a battery box though for my optima battery!
NEW NUMBERS - 301WHP 250WTQ 9.5PSI
Buddyclub / Greddy / Megan Racing / Carbing / Rev Hard / Skunk2 / Nitto / ESMM / Mugen / Tanabe / Hondata / JDM Honda / Gran Sport / HFP
civictype_r is offline   Reply With Quote
Old 09-21-2010, 09:11 PM   #23
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
I bought the cable, end fittings and digital splitter box from a local stereo shop.
The circuit breaker I bought at autozone
The battery and tray were passwordJDM.com
Old 09-25-2010, 12:26 AM   #24
k24penguin_pwd
b@nned
k24penguin_pwd is an unknown quantity on c-rsx
you have the brand of the splitter?
Originally Posted by HenHouseSuprise View Post
that thing has like 400 HP and awd and my civic could beat it out of any parking lot in the US....how sad.
k24penguin_pwd is offline   Reply With Quote
Old 09-25-2010, 12:54 AM   #25
3rdGearGRNDRR
Section 8
3rdGearGRNDRR's Avatar
3rdGearGRNDRR is an unknown quantity on c-rsx
you have exposed (+) terminals on your circuit breaker in the rear,
if something metal goes rolling into that
if u thought the '10ers are this retarded ,
wait till '11!
3rdGearGRNDRR is offline   Reply With Quote
Reply
Bookmarks
battery , diy , hatch
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
