Heater blower won't turn on when car is started by remote - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Audio, Security, & Electronics RSX
Reply
Thread Tools
Old 06-17-2012, 02:28 PM   #1
My02DC5
My02DC5's Avatar
My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx My02DC5 is a jewel in the rough of c-rsx
So i have a viper 791XV alarm and everything works fine. Except that the heater blower won't turn on when the car is remote started, and the stereo doesn't turn on either.
Did i miss a wire or maybe hooked up the wire in the wrong spot?
APB RSX TYPE-S
NHBP RSX TYPE-S
Yamaha R6
Motorcycle Crew #19
My02DC5 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-18-2012, 08:27 AM   #2
Locotony
The Audio Guru
Locotony's Avatar
Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx
Does the radio and blower work if you start the car normally?
Car Audio, Security, & Electronics Moderator
2014 CBP Civic Si Coupe
Rockford Fosgate 3sixty.3
Illusion Audio Carbon C6 Comps
Precision Power Phantom 900.4 and 1000.1
2 - 12 inch Acoustic Elegance IB12AU Subs
Locotony is offline   Reply With Quote
Old 06-18-2012, 12:57 PM   #3
My02DC5
My02DC5's Avatar
Yes they do
APB RSX TYPE-S
NHBP RSX TYPE-S
Yamaha R6
Motorcycle Crew #19
Old 06-19-2012, 08:45 AM   #4
Locotony
The Audio Guru
Locotony's Avatar
well something is hooked up wrong, but not sure what as I am not up to speed on alarms these days, I know the heater/ac is sometimes on a second line with a delay so the car could start and then the ac/heat would kick on 10 seconds latter or so but not sure, check the guide on installing a compustar as this question may have been asked there and even though the wiring is different between the compustar and the viper the principles on ow they work and the lines to connect to on the RSX are the same.
http://forums.clubrsx.com/showthread.php?t=172184
Old 06-19-2012, 03:50 PM   #5
My02DC5
My02DC5's Avatar
Will do, thanks.
APB RSX TYPE-S
NHBP RSX TYPE-S
Yamaha R6
Motorcycle Crew #19
Old 06-20-2012, 11:20 AM   #6
mr. fusion
Murder/ator
mr. fusion's Avatar
mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx mr. fusion might be well recognized one day on c-rsx
did you hook up all of the accessory wires? if there is more than one and they are not all hooked up this could happen because the wire controlling the feature is not energized.
mr. fusion is offline   Reply With Quote
Old 06-20-2012, 11:22 AM   #7
mr. fusion
Murder/ator
mr. fusion's Avatar
I will check Directechs when I get home tonight to see if it has a second (or third) accessory wire. It is the 05 RSX right?
Old 06-25-2012, 04:30 PM   #8
mr. fusion
Murder/ator
mr. fusion's Avatar
Accessory black/red ignition switch or dash fuse box, lt green 5 pin plug, pin 4
Second Accessory white/red ignition switch or dash fuse box, lt green 5 pin plug, pin 2
if both aren't hooked up some accessories will not work.
Reply
Bookmarks
blower , car , heater , remote , started , turn
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
