Is this brake caliper piston retracted all the way? QUICK ANSWER NEEDED - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Reply
Thread Tools
Old 01-25-2013, 01:36 PM   #1
dtb4876
Member
dtb4876's Avatar
dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx dtb4876 is a jewel in the rough of c-rsx
I am installing the powerslot rotors I picked up from kseriesparts the other week, and I do not have enough clearance to reassemble the rear calipers. However I am not sure if the rear pistons in my back calipers are retracted completely.
I have broken a screw driver and a chisel already and I finally resorted to going out and buying the cube looking retractor tool although I cannot get the piston to retract more than it already is.
I am wondering if they are completely retracted.
Does the boot need to sit flush with the middle cross indent part or should it sit flush with the top of the piston itself?
[IMG]
piston 1 by Dan Brady2, on Flickr[/IMG]
[IMG]
piston by Dan Brady2, on Flickr[/IMG]
Yes, my brake fluid reservoir cap is popped but I do not understand why I cannot retract the piston more yet my caliper will not fit over the assembly.
They are not the powerslot big brake kit so they are near if not the same size as stock rotors
This is the kit I picked up front and rear
http://www.kseriesparts.com/cr/PWS-126-40057S.html
Any answer is appreciated! Thank you!
dtb4876 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-25-2013, 02:10 PM   #2
Kaiser67
Lurker since 06
Kaiser67's Avatar
Kaiser67 is on a distinguished road
no its not.
the piston should be flush or slightly indented.
I just use a clamp...
05 NHBP Type-S
Nikon d5000
Deutcher Krew
Originally Posted by Hump View Post
Didn't you learn anything from Tokyo Drift?
Originally Posted by SHINS View Post
didnt read the thread, but according to your title you are a fgt
Kaiser67 is offline   Reply With Quote
Old 01-25-2013, 02:22 PM   #3
Scrs10
Master Member
Scrs10's Avatar
Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx Scrs10 is a jewel in the rough of c-rsx
if clamp doesnt push it in more then its time for a new one, there cheap at autozone if you dont want to wait for shipping for a good set.
Irresistible to the other sex Crew #069
LETS GO NY RANGERS!!!!
Scrs10 is offline   Reply With Quote
Old 01-25-2013, 02:36 PM   #4
frostydc5
frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx frostydc5 is a jewel in the rough of c-rsx
like stated above its not in all the way if it doesnt go in then its bad, so time for a new one. GL
frostydc5 is offline   Reply With Quote
Old 01-25-2013, 02:39 PM   #5
dtb4876
Member
dtb4876's Avatar
I was able to get the caliper on by tapping it with a hammer but once I got it on I was not able to pull the e-brake cable lever down to reattach it so I had to take it apart again (moved freely once it was apart). Although I have the same problem on the other side. I am just a little confused as to how the caliper went bad because I changed my pads a week or two ago and reassembly with the stock rotors wasn't too much of a pain but the piston was in the same spot it was now. New rotors may be a little thicker perhaps? If I have to I can go to autozone and pick up new calipers today, I believe I will have to bleed the system if I am correct?
Also what is your opinion on calipers from autozone? Obviously not as good as a set of spoons or brembos but is the life expectancy shorter overall? I want to get my car back together but if it means waiting a little for calipers to come in I would rather that than sacrifice a $450 upgrade of new pads and rotors with cheap calipers that won't work as well.
Old 01-25-2013, 02:51 PM   #6
Kaiser67
Lurker since 06
Kaiser67's Avatar
Auto zone calipers are going to be cheaper. I mean they're alright for Duralast but I would get them from Honda/Acura or something.
Yes you will need to bleed the system if you replace calipers.
05 NHBP Type-S
Nikon d5000
Deutcher Krew
Old 01-25-2013, 03:23 PM   #7
dtb4876
Member
dtb4876's Avatar
shit guess I'll be doing all that today this weekend too. Unfortunately I have to go back and switch the rotors in the front because for some reason powerslot only had the paper saying that they are directional and side matters in one of the boxes in the rear and did not come across it until the fronts were already done.
Old 01-25-2013, 03:39 PM   #8
DJCarbine
dolan pls
DJCarbine's Avatar
DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though DJCarbine is cool, not as cool as some though
Autozone/Duralast are remanufactured parts. Chances are it is an OE/OEM caliper thats been remanufactured. I've gotten remanufactured parts from autozone before with the BMW logo removed from OEM BMW parts
2013 FR-S - Vortech Supercharged
No vtaks
diablo 3 DJCarbine#1903
Budget Turbo Build
Base Auto Kpro DIY
DJCarbine is offline   Reply With Quote
Old 01-25-2013, 05:20 PM   #9
VTEC_Inside
Mmm, 3rd lobe...
VTEC_Inside's Avatar
VTEC_Inside is an unknown quantity on c-rsx
That's a rear caliper. Needs to be screwed in...
Honda, The Heartbeat of Japan...
2006 Acura CSX Touring 160hp 141lb/ft
2004 Acura RSX Type S 6spd 200hp 142lb/ft
1989 Honda Accord Coupe LX 5spd 2bbl 98hp 109lb/ft
Slushies are something to drink, not drive...
Nikon Crew Member #23 | Gripped D700/D200, 2.8 from 17-200
VTEC_Inside is offline   Reply With Quote
Old 01-25-2013, 05:28 PM   #10
dtb4876
Member
dtb4876's Avatar
Thanks for all the input! I bought calipers from advance auto picking them up tomorrow. $160 after core charge. I read online that advance has better quality parts than autozone (i hope for that price) Is it necessary to bleed the whole system? A friend of mine who goes to auto tech school said I can just buy plastic clips to clamp the line and a bleed is not necessary. He has been wrong before and I trust this communities input more than anyone else.
Old 01-25-2013, 05:30 PM   #11
da tick 07
Member
da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx da tick 07 is a jewel in the rough of c-rsx
x2
I had the same issue and used a HUGE freaking pry bar to turn the piston in. They do sell a special tool kit that is like a c-clamp but rotates the piston. I will definitely buy the correct tool next time I change my rear brakes. It took FOREVER and I got a workout
And yes bleed them. At least bleed the rear but you should go by the order in the helms manual.
edit: for a brake change you don't have to bleed them but once you remove the line you do. just for the clarification
da tick 07 is offline   Reply With Quote
Old 01-25-2013, 05:57 PM   #12
lbk05dc5
I-VTEC do you?
lbk05dc5's Avatar
lbk05dc5 is an unknown quantity on c-rsx
let us know how they work out. I am in a similar situation but was thinking of going with oreillys instead of advanced auto parts.
Texas Tech Alumni
2005 RSX-S
HKS-SKUNK2-BUDDYCLUB-TEIN-EIBACH-AEM-INGALLS-BEAKS
lbk05dc5 is offline   Reply With Quote
Old 01-25-2013, 06:50 PM   #13
dtb4876
Member
dtb4876's Avatar
will do! i was going to try o'reillys because i read the best reviews for the calipers they carry but then realized they dont have any locations in new jersey. advance seemed like the next best thing because to be honest i'd just rather stay away from buying from dealership unless i have to. after hearing they charge $400 for a new iac valve sensor with labor (and will not just clean it out) when i cleaned it out myself and spent $3 on brake cleaner i want nothing to do with them lol.
Old 01-25-2013, 11:08 PM   #14
dtb4876
Member
dtb4876's Avatar
also will i be ok only bleeding the rears or should i do the fronts also?
Old 01-27-2013, 01:10 AM   #15
dtb4876
Member
dtb4876's Avatar
finally got the brake system back together. caliper is the same as oem except the usual hex nut that was near the end of the caliper pin was replaced with a strange half circle with 2 flat sides. ended up tearing a 1/32" slit in the boot on the brand new caliper when the pliers i was using slipped off, wouldn't have happened if i used an open ended wrench. luckily the guys at my local padik who are actually useful hooked me up with a few old boots from other core charges and i found one that fit. I'm taking it out tomorrow when i drive to work so ill be able to give some info on the quality of the calipers and new rotors on hawk hps pads
Old 01-27-2013, 01:20 AM   #16
RSX-S2006
SHOCKER!
RSX-S2006's Avatar
RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx RSX-S2006 is a jewel in the rough of c-rsx
yea that! lol you beat me to it
NvUS - OHIO
Broke Student Crew #113 - KSU
2010 CU2
2006 DC5S
1995 EJ1 2006 STi 2006 Boosted tC
RSX-S2006 is offline   Reply With Quote
Old 01-27-2013, 07:03 PM   #17
dtb4876
Member
dtb4876's Avatar
well after getting everything back together with the brake system bled and the proper pressure in my pedal built up I went to drive the car to school today and after starting the car i gradually lost more and more pressure on the pedal until it was eventually back to the start. after bleeding the rears at least 30 times and the fronts 5-10 one of my calipers began to pour fluid out of the boot area of the spring mechanism for the parking brake. im assuming a defective rebuilt caliper was the reason i could not keep pressure in my system. going to call advance tomorrow and see what they can do about caliper replacement.
Old 01-27-2013, 08:22 PM   #18
lbk05dc5
I-VTEC do you?
lbk05dc5's Avatar
damn dude sorry to hear that.
Texas Tech Alumni
2005 RSX-S
Old 01-28-2013, 10:22 AM   #19
Kaiser67
Lurker since 06
Kaiser67's Avatar
Haha shit, that sucks.
I think you jinxed me this weekend too.
Replaced all of my pads and rotors and my passenger rear ended up being seized and the boot completely torn off...
Had to get one from Autozone, fml.
Did the bed in for the HPS and seems like they're all good now.
05 NHBP Type-S
Nikon d5000
Deutcher Krew
Old 01-28-2013, 12:33 PM   #20
dtb4876
Member
dtb4876's Avatar
haha what a coincidence. called advance today and they're replacing the part tomorrow. who knew a rotor change would prove to be so problematic, at least i know my brake system like the back of my hand now.
Old 01-28-2013, 04:49 PM   #21
lbk05dc5
I-VTEC do you?
lbk05dc5's Avatar
in for updates! well after you get the next one installed of course
Texas Tech Alumni
2005 RSX-S
Old 01-31-2013, 12:10 AM   #22
dtb4876
Member
dtb4876's Avatar
got it installed today, install went find and the bleeding process went well. i'm still bedding in the whole system so i havent really been able to see what they can do yet. everything seems to be working well all in all, if you have a better place to go i'd recommend it. when i went in to swap the defected caliper the employee asked where the leak was and he mumbled "of course" under his breath so obviously its a problem they deal with often. customer support was good and they swapped the caliper for free.
Old 01-31-2013, 08:02 AM   #23
Kaiser67
Lurker since 06
Kaiser67's Avatar
Mine seem like they bedded in nice now.
Everything feels nice and tight.
Brake jobs used to be so easy
05 NHBP Type-S
Nikon d5000
Deutcher Krew
Old 01-31-2013, 01:37 PM   #24
dtb4876
Member
dtb4876's Avatar
Brake systems working well now but the calipers are completely rusted after the first rainfall! Guess ill have to go back and paint the black or something. IMO if you need a quick fix and don't want to wait on parts in the mail or a rebuild kit these calipers will do just fine. Near same quality of oem but definitely somewhat of a downgrade in terms of quality of their rebuild kits..
Old 01-31-2013, 01:40 PM   #25
Kaiser67
Lurker since 06
Kaiser67's Avatar
Most calipers are just reman anyway.
Chipped the hell out of the paint on the ones that stayed trying to get them back on and aligned and new one is bright silver lol
Probably just going to paint them black soon.
Red ain't doing it anymore.
05 NHBP Type-S
Nikon d5000
Deutcher Krew
Reply
Bookmarks
answer , brake , caliper , needed , piston , quick , retracted
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
