Time for some new fuel injectors??? Any help is appreciated! - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Reply
Thread Tools
Old 07-29-2018, 03:12 AM   #1
Eddie06Z1
New Member
Eddie06Z1's Avatar
Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx Eddie06Z1 is a jewel in the rough of c-rsx
Really dirty .... why does it look like it was burned ? Its marked with a red circle. The other end never had a clamp??
Trying to figure out why i have a CEL p0304. Misfire code. It's not an ignition misfire because the car starts up perfectly! Could it a be a lean misfire? Thank you.
Click image for larger version
ID:	546597   Click image for larger version
ID:	546599   Click image for larger version
Eddie06Z1 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-29-2018, 10:47 AM   #2
marko16
Master Member
marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx
If it starts and drives fine I wouldn't get new injectors. The red circle looks like someone broke that piece and glued it. Put on a clamp and send it. Check your plugs and wires.
It matters zero if I dislike your reality.
marko16 is offline   Reply With Quote
Old 07-29-2018, 12:24 PM   #3
Eddie06Z1
New Member
Eddie06Z1's Avatar
It just seems like the rpm goes a little higher than normal....maybe its the o-rings // maybe need some new piston rings? Idk..
Old 07-29-2018, 01:05 PM   #4
marko16
Master Member
How's oil consumption, I doubt you need those as well. I've been sent to save you money. A good sense of condition is to always monitor mpg and fluid levels. Vacuum and airflow things like air filter need to be maintained. A small leak and Idle air control can lead to higher idle. Good you noticed, but check the general maintenance things first. The idle can be maintained on a very worn motor, when it can't then check the easy things first. The misfire code indicates an issue which may cause the idle to not be maintained properly.
Reply
Bookmarks
appreciated , fuel , injectors , time
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
