05 type s control arms - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Suspension, Chassis & Brakes
Old 11-08-2018, 02:33 PM   #1
05rsx911
05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx 05rsx911 is a jewel in the rough of c-rsx
Has anyone replaced the whole control arm on their 05-06 type s ..I'm being lazy and don't wanna press bushings in and out...rather just replace the whole arm so it's just bolt on ...I see their is really one option the Moog RK642167 and RK642167 ..but I'm seeing some people say the hole the ball joint stud goes through is to small and won't work ...anyone have experience with this or used these arms
05rsx911 is offline   Reply With Quote
Old 11-08-2018, 05:36 PM   #2
remyrounds
Site Sponsor
remyrounds's Avatar
remyrounds is an unknown quantity on c-rsx
As long as you get the arms made for the 05-06 they bolt right on. I just replaced my 02-04 with arms like that and they went on no issues.
The True Original | Established 2001
Kseriesparts.com
remyrounds is offline   Reply With Quote
Old 11-08-2018, 05:50 PM   #3
05rsx911
Ya I know I was just seeing some people say the ones listed for the 05-06 didn't fit and was seeing if anyone has used these on their 05-06
Old 11-09-2018, 07:08 AM   #4
KingMaiya
KingMaiya's Avatar
KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx
https://www.flickr.com/gp/125459578@N07/32rC7c
I just ordered some for mine for 05-06 type s, havenít checked if my new ball joints fit or not but I hope thatís not the case. I installed the the arms on the car and it lines up perfect .
XB1 Gamertag [ iLoyal Ranger ]
06 RSX-S|HKS|
MUGEN|RPF1
Instagram : Deemossi
KingMaiya is offline   Reply With Quote
Old 11-09-2018, 09:25 AM   #5
marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx
It won't fit because those are for a base or 02 04 type s. Not sure on the type s, but those control arms won't work. If you get the smaller ball joint it will fall right out of the knuckle as the ball joints are smaller in every demension. I gave up sourcing the control arms and put in aftermarket bushings and new hardrace ball joints.
Old 11-09-2018, 06:16 PM   #6
KingMaiya
KingMaiya's Avatar
i purchased it off moogs website and it states its 2005 2006 types s only, i checked it out today and ball joints seem to line up well, the ball joints have a slight taper to it ,so it kinda has to be forced in a bit i think, more than half of the stud on the ball joint goes in ,
ill update if it does or doesnt work,
06 RSX-S|HKS|
MUGEN|RPF1
Old 11-09-2018, 07:06 PM   #7
If it fits you'll be able to see some threads, I think the smaller you couldn't even begin to thread the ball joint into it.
Old 11-09-2018, 08:02 PM   #8
KingMaiya
KingMaiya's Avatar
i think im good then, you can def see more than half the threads on the other side when you slide the ball joint stud into the arm hole.
06 RSX-S|HKS|
MUGEN|RPF1
Old 11-10-2018, 08:54 AM   #9
Sounds right
Old 11-11-2018, 01:15 AM   #10
05rsx911
So the RK642167 and 168 are for 02-04 ...moogs site says 05-06 type s??
Old 11-14-2018, 04:45 PM   #11
Dizzyaznboy
Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx Dizzyaznboy is a jewel in the rough of c-rsx
Hey if you want a nice ride, do a search on how to push them out its definitely worth it if your switching to polyurethane bushings, and dont use the cheap stuff. Energy Suspension makes the real ones. https://www.ebay.com/itm/Energy-Susp...06uV:rk:3:pf:0
Dizzyaznboy is offline   Reply With Quote
Old 11-14-2018, 09:24 PM   #12
KingMaiya
KingMaiya's Avatar
The part numbers you listed are only for 05-06 type s only , search on their site for the ones your looking for , Iím sure they have it .
Also I ordered mine from rock auto , great prices , cheapest Iíve seen. Just got to know what your ordering . Get your part number from Moog website and then search for it .
Easy .
Good luck
Sent from my iPhone using Tapatalk
06 RSX-S|HKS|
MUGEN|RPF1
Old 11-21-2018, 07:54 PM   #13
KingMaiya
KingMaiya's Avatar
so update on these arms, i had the arms installed on the car for a month , finally was going to put everything back together and........
the arms do not work,
i ordered it from moog and its for a 2005-2006 acura rsx type s. exact fit to oem, thats what it said
like stated above the hole for the ball joint is too small,
i apologize to whoever had asked and i confirmed it worked by just looking at it.
i compared oem to the moog and moog is much smaller..
now i called moog corporate and they were pretty bad service. he would not accept the fact that their product is wrong. he blamed me and my ball joints were wrong. he also said that it could have gotten swaped out in shipping or in factory.
also said that according to his records , im the first ever to complain about this. lol
anyway im returning them and i found someone close by thats parting out. so i lucked out.
SO YES STAY AWAY FROM MOOG FOR YOUR LOWER ARMS!!!!
also , forgot to mention , i even tried to force my ball joints on and i snapped both of them,
so dont even try to do it lol ,
good thing im returning all this shit
06 RSX-S|HKS|
MUGEN|RPF1
Old 11-21-2018, 10:23 PM   #14
I couldn't find any and replace the bushings with energy suspension and ball joint with hard race.
Old 12-10-2018, 08:01 PM   #15
aviationfrk
aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx aviationfrk is a jewel in the rough of c-rsx
Since we are on the topic, I just purchased the hard race ball joints for my '06 type-s.
Could anyone confirm is this the right part number for the energy suspension lca bushings for an '06 type-s? (OEM LCA) (Different websites say it does or doesn't fit so not sure)
16.3116G
aviationfrk is offline   Reply With Quote
arms , control , type
