best run at the track 15.2 - Page 2 - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Nitrous Oxide RSX
Old 11-19-2003, 04:04 AM   #26
po9i
ex-celica owner
po9i's Avatar
po9i is an unknown quantity on c-rsx
did the bottle have nitrous in it?
po9i is offline   Reply With Quote
Old 11-19-2003, 05:39 AM   #27
WarmPepsi
WarmPepsi's Avatar
WarmPepsi is an unknown quantity on c-rsx
nah, i'm just not gonna go out and dig through my stuff to find jet settings for you.
WarmPepsi is offline   Reply With Quote
Old 11-19-2003, 05:53 AM   #28
WarmPepsi
WarmPepsi's Avatar
actually, i went into the archives and found it, the sticky is now updated.
NX Kit Nozzle Settings for the RSX(N/F)
35: 31/18
50: 35/20
75: 41/24
100: 52/31
Old 11-19-2003, 12:48 PM   #29
Platinum linx
Platinum linx is an unknown quantity on c-rsx
what do you mean how do you launch @ 5500 .. shit where the hell are you comming from .. .. try launching @ 5500 .. only thing is traction .. say you got slow 60's b/c of traction your trap speed will be high .. traction aint nuttin more than rear mounts .. and good wheels .. and to be more serious .. full mounts and lsd ..
Platinum linx is offline   Reply With Quote
Old 11-19-2003, 07:42 PM   #30
MrBurner
Traction is for pussies
MrBurner's Avatar
MrBurner is an unknown quantity on c-rsx
i really disagree with everyone who says it is the 60' time...when i went to the track for my first time in this car, i had never even launched it and my best run that time was a 14.7 w/ a 2.5...that was above sea level and with correction that is a 14.2 with a 2.5 60' with only intake and exhaust
i honestly think it is either
a) his driving
b) his driving
c) his driving
d) nitrous pressure was too low
but as i said, i'd bet on that whole "his driving" thing because i can score under 10 second 1/8 mile runs with that kind of 60' with no nitrous
was that the first time you have sprayed? did it feel MUCH faster than stock? if not, you should make sure your nitrous solenoid isn't fried or something...if your bottle was full, you shouldn't really have to worry about the pressure seeing as a full bottle even at that temp should give you > 1000psi (at least it does for me)
so solutions could be
a) learn how to drive a little better, launch better, shift faster etc.
b) hook the solenoids upto ground/power (the 2 wires coming off of them) to make sure they are both opening (you will hear a fairly loud click when it is touching both power and ground)
c) make sure the jets are correct
d) make sure the bottle pressure is correct
e) race your friend that was there with you again...maybe this time from a roll (after you have checked everything above) or maybe race someone else with an rsx
Turbo Forum Moderator
Car is totalled - everything must go
EVERYTHING IS FOR SALE - NEW FOR SALE PAGE JUST CREATED 01/28/06 - TONS OF RSX PARTS FOR SALE OFF MY TOTALLED TURBOCHARGED RSX-S
www.mrburner.com
KPRO IS SOLD
MrBurner is offline   Reply With Quote
Old 11-19-2003, 07:46 PM   #31
WarmPepsi
WarmPepsi's Avatar
i give little merit to the corrections..... because if you would have had a 2.2, theres no way in hell you're running a 13.6 with i/e. however, 14.1 with a good 2.2 60' is definatly beleiveable.
also, where was the run at?
Old 11-19-2003, 07:49 PM   #32
MrBurner
MrBurner's Avatar
dragway 42 in ohio
www.mrburner.com
KPRO IS SOLD
Old 11-19-2003, 07:54 PM   #33
MrBurner
MrBurner's Avatar
oh man, nevermind...i told my times to a friend of mine who said he plugged it in and that was what he got...i just looked it up and it isn't even close to that
but i still stand by my 14.7 w/ a 2.5 60' with only intake and exhaust showing that the 60' time doesn't necessarily mean it will be such a shitty run
www.mrburner.com
KPRO IS SOLD
Old 11-19-2003, 08:28 PM   #34
nsimbu
nsimbu is an unknown quantity on c-rsx
I got a 2.3 60foot and only got a 15.127 at dragway 42. I trapped at 93mph. Then again when I shift into second it spins so if i get better tires im sure 14's are there.
FS: 2 2002 Wheels w/ Azenis. NX Wet Kit/Purge/RPM stuff/Electronic WOT/ yadda yadda. 2 Rear Koni Yellows.
02' Arctic Blue RSX Type-S [Sold]
'07 WDP TL w/ Navi
nsimbu is offline   Reply With Quote
Old 11-19-2003, 11:14 PM   #35
blazinrsx329
cracker jack box driver
blazinrsx329's Avatar
blazinrsx329 is an unknown quantity on c-rsx
yea im gonna rip out the jets tomorrow and check them along with checking the plugs and i have to get a psi gauge as well... it was my first time at the track. and i dont think my tires are that great im running konig holes with yoko avid h4 tires...
screwed for life
blazinrsx329 is offline   Reply With Quote
Old 11-20-2003, 12:23 AM   #36
blazinrsx329
does it do a lot of damage spraying with low pressure??
screwed for life
Old 11-20-2003, 05:37 AM   #37
WarmPepsi
WarmPepsi's Avatar
you're basically just throwing fuel into the engine. great way to blacken your plugs. you'd rather throw in more fuel than not throw in enough, but even at 1000 psi + the nx jets are still geared fuel rich.
the higher the bottle pressure, the more nitrous is going to go into the engine when you're spraying. the perfect mix is between 1000-1050. anything less, and you have too much fuel.
Old 11-20-2003, 11:22 AM   #38
Platinum linx
i think as much as we speculate what the issue is .. we agree with one of the problems
Driver .. * get more practice man .. it's your first time at the track don't expect too much .. like someone said .. run it stock .. and see what kind of times you get ..
Old 11-20-2003, 08:44 PM   #39
TheSilverBullet
Speedy
TheSilverBullet's Avatar
TheSilverBullet has been a little shit in the past
don't worry dude - my first trip to the track i pulled 16.55 @ 86 w/2.5 sixty all stock. i managed to pull that down to 15 flat all stock. after a few runs....
you should be able to tell if it's spraying not...
make a pass wo/ spraying and that will answer that question....
i like to launch high as well ~4.5-.55k - nothing wrong there hell you are going to spin out off the line but it can't be crazy like shit,
and you're running the bitch hard to near fuel cut (8.1k) off right?????? bounce the bitch off the limiter-
on stock wheels?
taking the spare and jack out?
2010 g37
2007 SilverStone S2K w/ flashpro, 70mm Berk 3" TP Headerback, AEM V3 cai, JVT header, T1R-Ti ball, CDV delete.
2007 CR-V 4WD EX-L, 2003 S10HyperTech
2002 SatinSilver RSX-S /i/e/rh/kpro/enjo/ss
2002 DesertSilver RSX AUTO Leather
TheSilverBullet is offline   Reply With Quote
Old 11-20-2003, 08:47 PM   #40
TheSilverBullet
Speedy
your 17" are not helping matters either... put the stock wheels back on for the track.........
you're not bogging the bitch down off the line are you?
2010 g37
Old 11-22-2003, 01:47 PM   #41
blazinrsx329
no yea i launched at 4500 the first 2 pass's then i launched at 3500 the last 2 pass's... i know its my driving...but i was expecting at least to break into the 14s o well better luck for me next time
screwed for life
Old 11-23-2003, 08:46 PM   #42
excess
excess is an unknown quantity on c-rsx
with a 50 shot I ran 13.8 @ 102 theres no reason no matter how bad of a driver you are to run that low of a mile an hour with your mods, something doesn't sound right.
excess is offline   Reply With Quote
Old 11-24-2003, 01:01 AM   #43
blazinrsx329
me and my mechanic went to fill our bottles today cause he ran at englishtown with his yellow celica today and he realized that there was nothing really in the bottle that i used for my first 2 pass's so thats part of the explenation...i dont know again hopefully everything will be checked out tomorrow...and once i get everything done im gonna throw a 75 shot and run my friends sti
screwed for life
Old 11-24-2003, 08:14 AM   #44
excess
If there was nothing in the bottle it just sprayed fuel making the car run extremely rich and you had to of noticed it, the car starts to bog out and runs like shit
Old 11-24-2003, 04:35 PM   #45
WarmPepsi
WarmPepsi's Avatar
i'll vouch for said...... i made a pass with my bottle closed..... i had 1000 psi to start....... and nearly nothing at the end....... needless to say, it was a shat pass.
don't do it.
Old 11-24-2003, 07:39 PM   #46
Alpha Zero
JLA Bitches!
Alpha Zero's Avatar
Alpha Zero has a clean start Alpha Zero has a clean start Alpha Zero has a clean start Alpha Zero has a clean start
practice, practice, and more practice. that's the only way to get good times. dragging NA and dragging with nitrous requires a different racing technique. too bad I was never able to run with the nitrous in my car, but all stock, i was able to pull off a 14.8 @ about 80ft. above sea level. Stock tires too mind you.
Random Thoughts and Rants
Please learn to read before trying to reply to threads. Thank you.
^Punch^
Alpha Zero is offline   Reply With Quote
Old 11-25-2003, 12:37 AM   #47
blazinrsx329
i got the remote bottle opener installed today ill take pics of everything again once everything is installed
screwed for life
152 , run , track
