settings for TEIN SS? - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Auto X & Road Racing
Old 07-26-2004, 09:44 PM   #1
rjfan91
Who you callin' a member?
rjfan91's Avatar
rjfan91 has been a little shit in the past
I just bought the Tein SS coilovers with the ingalls cambar kit. I am wondering what settings current Tein autox'ers are using.
2003 NBP Type-S
K24a2, Shorty CAI, Hondata k-pro, JDM rear sway, Mugen replica front & rear strut, Neuspeed X-brace, B&M Short Shift, Tein SS coilover, Ingalls camber kit front/rear, 18" Enkei RS7, Comptech exhaust, comptech shorty header, random tech high-flow cat, comptech lightweight flywheel, Act clutch/pressure plate
rjfan91 is offline   Reply With Quote
Old 01-28-2015, 01:29 PM   #2
AllMotorRsx001
AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx AllMotorRsx001 is a jewel in the rough of c-rsx
bump this
AllMotorRsx001 is offline   Reply With Quote
Old 02-13-2015, 11:52 PM   #3
NoseGoblin
NoseGoblin's Avatar
NoseGoblin is an unknown quantity on c-rsx
You always want the fronts at a harder setting than the rear. Along with a bigger rear sway bar, this has made my RSXs handling really neutral with the rear ever so slightly over steering. Also running 225/40r18 wheels and tires on Hankook Ventus v12s with -1.75 camber front and -.5 in rear. This setup has worked perfectly for my auto x and track events. You also want to run about 5 more PSI on the front tires than the rear -- something you want to play with.
NoseGoblin is offline   Reply With Quote
Old 02-28-2015, 07:09 AM   #4
AllMotorRsx001
How much height?
Old 02-28-2015, 12:28 PM   #5
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx
Japanese pro gymkhana driver helped me set up my damper settings. I'm at 13/20 rear and 6/20 in the front on my Ohlins DFVs. My car is as neutral as neutral can get.
1996 Integra Type R sedan
1991 Civic DX wagon.
Koopa Troopa is offline   Reply With Quote
Old 03-17-2015, 12:40 PM   #6
AllMotorRsx001
So you're front is softer? I thought the more clicks to the right is stiffer
Old 03-17-2015, 01:27 PM   #7
Zzyzx
Late Apexer
Zzyzx's Avatar
Zzyzx is an unknown quantity on c-rsx
General rule on tuning. *the stiffer end of the car will lose grip first. (this goes for damper rates, spring rates, anti-roll bars...)
So, if the car is under steering, then either stiffen the rear dampers or soften the front dampers.
More importantly... whats your alignment set to?
Note: I reserve the right to replace "Hella" with "Smurf", or any of its variations, where ever "hella" is encountered.
“There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.”
— Ed Howdershelt
Zzyzx is offline   Reply With Quote
Old 03-17-2015, 01:55 PM   #8
AllMotorRsx001
My alignment is the spec for a rsx type s on tein ss suspension. Ride height is highest spec
Old 03-17-2015, 01:57 PM   #9
AllMotorRsx001
I have 15 clicks front, 20 rear
Old 03-17-2015, 02:44 PM   #10
Zzyzx
Late Apexer
Zzyzx's Avatar
so an OEM alignment? If so, changing that should be priority #1
— Ed Howdershelt
Old 03-17-2015, 03:42 PM   #11
AllMotorRsx001
I guess I would have to make the car a dedicated track car, this my daily driver, weekend warrior. Was hoping I could make my tires last a tad longer
Old 03-17-2015, 05:39 PM   #12
Zzyzx
Late Apexer
Zzyzx's Avatar
Running between -1.5 and -2 deg camber on the nose isn't going to cut in to tire life any real amount. What you have to watch out for is toe.
http://forums.clubrsx.com/showthread.php?t=408267
— Ed Howdershelt
Old 03-31-2015, 01:30 PM   #13
AllMotorRsx001
what are you thoughts on ingalls camber adjusting bolts, camber plates are out of my price range right now. I want to do that high performance alignment
Old 04-01-2015, 10:50 AM   #14
Zzyzx
Late Apexer
Zzyzx's Avatar
they are not as stable as camber plates, but set up correctly will do the job just fine.
— Ed Howdershelt
Old 04-08-2015, 02:26 PM   #15
AllMotorRsx001
I bought 2 sets, so hopefully i get as close to 3 degree of camber. Running hp plus, goodridge ss brake lines and super blue dot 4. Auto x prep!
Old 04-13-2015, 10:00 PM   #16
AllMotorRsx001
Alright guys so i ended up with 2.7 negative camber front, negative 1.3 camber rear, -1/32 front toe, 1/16 toe, thoughts?
settings , tein
