Shift light killin me - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Nitrous Oxide RSX
Old 03-15-2003, 07:18 PM   #1
RSX Factor
this is my inner child
RSX Factor's Avatar
RSX Factor is an unknown quantity on c-rsx
I have everything hooked up but I'm not getting a light at my set rpm. Doesn't the blue wire under the hood that I can use for my rpms has a plastic connector at the end of so a tech can connect to it?
CRSX Louisiana...blocking traffic and getting dirty looks since 12/19 /04
RSX Factor is offline   Reply With Quote
Old 03-20-2003, 12:10 PM   #2
Dehalorespire
Dehalorespire is an unknown quantity on c-rsx
That is correct.
Make sure that the tach wire is seated well in metal clips in the plastic connector. Maybe, try different pills to make sure the pill is not bad. If all your pills are bad then the light is probalby not hooked up right. Make sure your got a good ground.
Dehalorespire is offline   Reply With Quote
Old 03-21-2003, 09:59 AM   #3
RSX Factor
RSX Factor's Avatar
Actually mine doesn't have pills. I just program it for say 7400 and it's set. Monday I notice the light did come on at like 8200 when I had it set for 7700. So last night I set it to 7400 and tried it this morning on the way to work and it didn't work.
I'm about to pull the whole thing out and set fire to it.
Old 03-21-2003, 10:38 AM   #4
Dehalorespire
So, is this one of those ones that you set manually by revving the engine to, say 7400 and pushing a button, or turning a nob? If so, those are nasty to set up.
Old 03-21-2003, 11:30 AM   #5
RSX Factor
RSX Factor's Avatar
No, I basically punch in the RPM I want the light to come on. I don't have to rev the car to desire rpm and then hit a button. Works kinda of like setting an alarm for an alarm clock.
killin , light , shift
