Stainless exhaust pics - Page 6 - Club RSX Message Board
Go Back   Club RSX Message Board > ADVANCED PERFORMANCE > Welding, Fabrication, & Tools
Reply
Thread Tools
Old 03-01-2009, 12:17 PM   #126
turbo rsx
get your stacks up
turbo rsx's Avatar
turbo rsx is an unknown quantity on c-rsx
yea
Originally Posted by 9bells View Post
I would give the slight nod to the new dynasty 200dx, but if it's not brand new, the lincoln v-205t ac/dc is better.
Either of those machines will thrill you in ways only a top-notch welder can.
yea thats true. i like buying good stuff the frist time instead of buying cheap shit and then up and buying a new one weeks later..but i like the lincoln but the 200dx display look jus like the thermal arc400. the one i use at work all day. so i might just stick with the 200dx
turbo rsx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-02-2009, 03:53 PM   #127
nateap88
Senior Member
nateap88's Avatar
nateap88 is an unknown quantity on c-rsx
i have mixed thoughts. it definitely looks good but i don't know if the fact that the piping doesn't look the same on both sides is my taste. one of those things that you see and it's awesome but i'd probably want something different if i had a 350. but hardcore props to you. looks clean as fuck
cai, megan rh, stage 2 clutch & flywheel, kpro
13.98 @ 101mph
peakboost going in soon
Zombie Eradication Team Member #16
nateap88 is offline   Reply With Quote
Old 03-07-2009, 03:03 PM   #128
9bells
RSX fanboy supreme
9bells's Avatar
9bells is an unknown quantity on c-rsx
First aluminum mufflers are on a toyota Soarer. I really like the car, and he chose the right colour.
The sound is so nice I can't believe it. The mufflers kept it very deep at idle, and make it sound so smooth during WOT sweeps!!!
Doesn't sound like a jet anymore, sounds very nice.
Decibel testing tonight with buddies before the fight. I suspect it dropped 6dB, maybe more.
Since I know it will get asked, I doubt I'll get any sound clips...
13.5@101.5 @3500ft
unobtainium.ca
9bells is offline   Reply With Quote
Old 03-07-2009, 03:17 PM   #129
K20A2
Internet Crack Dealer
K20A2's Avatar
K20A2 might be well recognized one day on c-rsx K20A2 might be well recognized one day on c-rsx K20A2 might be well recognized one day on c-rsx K20A2 might be well recognized one day on c-rsx K20A2 might be well recognized one day on c-rsx K20A2 might be well recognized one day on c-rsx
so these are ones that you made? the look good and your alignment is dead on
Chris Dye
The Founder of Club RSX
http://www.kseriesparts.com
K20A2 is offline   Reply With Quote
Old 03-07-2009, 03:20 PM   #130
BD2002
BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more
BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more BD2002 is a super person....that needs to get out more
Backpurged with Argon
What does this mean?
BD2002 is offline   Reply With Quote
Old 03-07-2009, 03:24 PM   #131
K20A2
K20A2's Avatar
when you welding something like stainless you need to project the backside of the weld from oxygen. Argon displaces oxygen in the tube for a better and cleaner weld. If you have oxygen in the stainless, titanium, and a few other metals then it is a weak weld and can crack and break. Often times, if you have oxygen in the weld there is a crack in it right away.
Chris Dye
Old 03-07-2009, 03:27 PM   #132
BD2002
So you fill the exhaust with argon and then seal it up and then weld it? So its just for making a better weld? And stainless steel is the best for exhausts right? What are stock exhausts made of if they arent stainless? Thanks . So many questions.
Old 03-07-2009, 03:32 PM   #133
K20A2
K20A2's Avatar
you don't seal it, you put in a line off your argon tank and let the argon flow continuously through the pipe. I normally use some steel wool to hold the line in, tape the other side and poke some holes in it. When you do it right, the welds on the backside often look better than the outside welds.
the give you an idea on why they don't use stainless. I called a place this week and steel was around 1.70/ft and stainless was 9.80/ft.
Chris Dye
Old 03-07-2009, 03:34 PM   #134
9bells
RSX fanboy supreme
9bells's Avatar
Yes, these are the same ones.
Yes, got the tips pretty good. They work more than I thought they would. Only 3/4" of stainless wool inside all the way around. Using a 6" can instead of a 4.5" would have made it way too quiet.
Yes, filling the tubes with argon ensures the strongest welds. Stainless is a good choice for exhaust, most OEM manufacturers use 409 stainless(ferritic) to make exhaust due to cost. I use 304L for my exhaust, as it maintains a nicer look.
13.5@101.5 @3500ft
unobtainium.ca
Old 03-07-2009, 03:37 PM   #135
BD2002
Thanks a lot guys. Apprecieate it.
Old 03-07-2009, 03:39 PM   #136
K20A2
K20A2's Avatar
that is super cool, I might have to try that one day. Did you make the aluminum into the tube or did it come that way?
Chris Dye
Old 03-07-2009, 04:38 PM   #137
9bells
RSX fanboy supreme
9bells's Avatar
Not sure what you mean, but I fabbed everything from scratch except the perf tube, which I ordered.
13.5@101.5 @3500ft
unobtainium.ca
Old 03-07-2009, 04:47 PM   #138
vash_the_stampede
popcorn playa
vash_the_stampede's Avatar
vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore
vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore vash_the_stampede Golden Rep Whore
great work
IDGAF
/anime crew#4/lefty crew #1/ Late Night Crew#10/All Motor Crew #21/vAsh vAse cR3w! #1 TcK~!!!!
Originally Posted by SEvoIX View Post
I want cream cheese on my baked potato
vash_the_stampede is offline   Reply With Quote
Old 03-07-2009, 04:54 PM   #139
K20A2
K20A2's Avatar
I was just curious if it was made from a flat sheet or from tubing.
Chris Dye
Old 04-24-2009, 07:12 PM   #140
dobbs02si
Member
dobbs02si's Avatar
dobbs02si is an unknown quantity on c-rsx
Forgive me if im cluttering the this section, but I showed these pics to my boss and his son and he demand I ask what tungsten your using for stainless. Any help is greatly appreciated!
dobbs02si is offline   Reply With Quote
Old 04-24-2009, 10:29 PM   #141
9bells
RSX fanboy supreme
9bells's Avatar
Sorry for not replying Chris.
Yes, it's just aluminum tube.
As for the tungsten, most of that was welded with Ceriated(orange), since it has a high emission rate of electrons, it requires less amperage to start and run.
It is a good choice for low-amperage work like that of stainless tube.
13.5@101.5 @3500ft
unobtainium.ca
Old 04-25-2009, 09:55 AM   #142
K20A2
K20A2's Avatar
bleh, I hated orange and love to use red. With thin wall stuff don't be afraid to step down to a 1/16 tungsten from a 3/32.
Chris Dye
Old 04-25-2009, 10:41 AM   #143
9bells
RSX fanboy supreme
9bells's Avatar
Yes, tungsten size, like filler rod, has a large effect on the weld bead.
I use the smallest one I can. On the thin tubing, I use .040".
Always use the smallest filler rod possible aswell. Never, ever bigger than the base metal.
13.5@101.5 @3500ft
unobtainium.ca
Old 04-29-2009, 08:02 PM   #144
JO_TECH
JO_TECH is an unknown quantity on c-rsx
Sick work!!!!!!!!
JO_TECH is offline   Reply With Quote
Old 05-02-2009, 05:36 PM   #145
dobbs02si
Member
dobbs02si's Avatar
Well ive got some 1/16 orange on the way, apparently its a north vs south thing lol. The local welding shop owner is from PA and he said orange is all they used up there, now red is the only thing he sells here. He said I guess the southerners dont care about the radiation, or even know for that matter.
Old 05-13-2009, 07:08 PM   #146
dobbs02si
Member
dobbs02si's Avatar
Well I finally got to use the orange this week and I love it! It doesnt blow the end off welding aluminum now, im amazed by that alone lol. Same way with stainless though, I welded for about 30 mins and never had to sharpen it one time..needless to say im sold. Thanks for your help!
Old 05-14-2009, 09:24 AM   #147
K20A2
K20A2's Avatar
I always use green for aluminum
Chris Dye
Old 05-15-2009, 06:57 PM   #148
dobbs02si
Member
dobbs02si's Avatar
So use pure on aluminum?
Old 05-16-2009, 12:27 PM   #149
w00ter
w00ter is an unknown quantity on c-rsx
Yeah your suposed to use pure on aluminum, I like when you have a machine that can allow you to use 2% Thoriated for aluminum, with a lower angle for better cleaning. (45-60degrees)
w00ter is offline   Reply With Quote
Old 05-17-2009, 09:15 PM   #150
dobbs02si
Member
dobbs02si's Avatar
The shop machine is an older lincoln. It will run the thoriated but it will burn the tip off on heavier(1/4" and up) aluminum. The ceriated has worked on ss and alum very nicely so far. We have green but the boss man is to impatient to change it when he swaps material..oh well.
Reply
Bookmarks
exhaust , pics , stainless
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
