Circuit's Silver 2002 RSX Type-S - Page 3 - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Member Show-Off RSX
Old 07-09-2017, 11:57 PM   #51
black dc5
black dc5's Avatar
black dc5 is an unknown quantity on c-rsx
Originally Posted by Circuit View Post
Thanks! The front is pretty much perfect. Rubs the fender liners even though they're cut. That could be resolved by raising the car, or letting it fix itself . I'll be doing the latter. I do wish the rear were higher offset so I could run the same amount of camber all around. Maybe go +25 front and +40 rear with a 5mm spacer to clear the trailing arm?
If it's only the liners, perfect!
The x9 et35 may still rub depending on height. When I had x10 et25 up front, these x9 et35 were in the rear, I needed a 3mm spacer to clear the RLCA. More of a problem with ride height though.
I am on a more conservative alignment now, -1.3* front but if -2.0* clears x9 et25 maybe I'll go to -2.0 again.
:::black dc5 / silver NA6 garage:::
Got wide wheels/low offset? CLICK ME!!!:
http://forums.clubrsx.com/showthread.php?t=525211
black dc5 is offline   Reply With Quote
Old 07-10-2017, 01:14 AM   #52
Circuit
Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx
I'll try to get a "down the line" shot in the next couple days!
02 Type-S build thread | @chris_mtechnica on Instagram
Circuit is offline   Reply With Quote
Old 08-11-2017, 11:24 PM   #53
Circuit
Some updates!
New pads (Hawk Ceramic) and rotors (Adams Rotors Drag 2 pattern)
Got a bunch of body parts painted and installed
ASpec front lip (rep)
Type-R side skirts (OEM)
ASpec wing (OEM)
Aspec rear lip (to be installed)
Need to find a replacement hood with better paint, repaint this hood, or find a carbon one?
Old 08-11-2017, 11:42 PM   #54
InZain08
InZain08's Avatar
InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx
Congratulations, Circuit! She looks great!
I've never seen a rotor pattern like yours; do you know what it's called and how it helps expel gases under breaking?
Looks like your body shop did good work on your pieces. What kind of hardware did you use for installation?
You beat me to it; I have some pieces that are currently with a local shop getting worked on.
Too bad we are on opposite ends of Cali. Both of our cars have come a long way in a short time!
InZain08 is offline   Reply With Quote
Old 08-12-2017, 12:38 AM   #55
Circuit
The rotors are from www.adamsrotors.com. Its a norcal based company that is more popular in the Euro crowd, but they make rotors for almost any car. Its their Drag 2 pattern. Not sure how much better than normal slots they perform, but they sure look cool
Front lip - 3M double-sided on all the flat portions and self tapping screws in the fender wells
Side skirts - All OEM clips
Rear wing - Had to actually drill out all the rivet nuts and install new ones. Used stainless M6 hardware.
Rear lip - I bought all new OEM hardware from Honda. Also got new bumper support plastics since mine are busted up and the bumper is all out of shape.
I plan to make a trip to LA at some point. We should meet up when I do! Want to visit all the famous car spots for photos - Neptune's nest, Toretto's deli, Toretto's house, Angeles Crest highway turn off (Matt Farah), Bob's donuts, etc. etc.
Old 08-12-2017, 12:52 AM   #56
InZain08
InZain08's Avatar
Let me know when you're planning to make the trip and we can figure it out!
Old 08-13-2017, 11:49 AM   #57
InZain08
InZain08's Avatar
Post some pictures of your rear lip installed!
Old 08-20-2017, 04:40 AM   #58
alexEF
alexEF's Avatar
alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx
that rotors are interesting
alexEF is offline   Reply With Quote
Old 04-23-2018, 01:36 PM   #59
Circuit
Wow buying a house certainly slows car build progress Here's a ton of updates over the last couple months. I picked up replacement front fenders and a hood in much better paint condition than my originals, but no photos of those.
Spoon Oil drain plug, oil cap, and radiator caps
Picked up a bunch of Comptech stuff for an awesome deal with trades for stock parts
Replaced all 4 motor mounts with Hardrace (#6676). Rear was the worst. The DIY on here helped a ton.
While the bottom half of the header was out, I figured I'd install the DC Sports RH I had sitting around as well
Current state after a fresh wash
I have a Casale Design low rise wing that needs paint and am waiting on a CF exhaust shield for the a-spec rear lip to finish off the exterior. K-pro and I will be at a good stopping point for this daily Well ... maybe some seats
Old 04-27-2018, 11:06 AM   #60
rizz
rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx rizz is a jewel in the rough of c-rsx
nice build bay area represent!......
rizz is offline   Reply With Quote
Old 05-15-2018, 03:39 PM   #61
Dat5er
Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx Dat5er is a jewel in the rough of c-rsx
Nice
Dat5er is offline   Reply With Quote
Old 05-20-2018, 09:24 PM   #62
Circuit
Originally Posted by Dat5er View Post
Nice
Thanks guys!
Got the A-Spec rear lip installed with ParadigmPCF CF heat sheild
Old 05-25-2018, 04:00 PM   #63
Circuit
Now with Casale Design wing!
Old 05-26-2018, 02:56 AM   #64
Pghpunkid
Glutton for Punishment
Pghpunkid's Avatar
Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx Pghpunkid is a jewel in the rough of c-rsx
I have never seen that Casale Design spoiler before, but I think I like it more than that A-Spec wing.. however I don't have any spoiler at the moment so anything is better to me lol.
Looks good! If you wanna sell your A-Spec wing, let me know!
2002 RSX Type-S SSM
Currently saving an orphaned K20A2 with intent to boost.
Pghpunkid is offline   Reply With Quote
Old 08-31-2018, 02:08 AM   #65
DamienGraves
DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx DamienGraves is a jewel in the rough of c-rsx
Wow!! Incredible build. She looks beautiful! I'm just starting my journey with RSX. It looks like you easily soaked a good chunk of coin into it. May I ask roughly how much you've put into all that work?
DamienGraves is offline   Reply With Quote
Old 08-31-2018, 07:08 PM   #66
05xS
05xS's Avatar
05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx 05xS is a jewel in the rough of c-rsx
Just broken in @248k. I have an 05 with 383k and motor has never been apart!!
05xS is offline   Reply With Quote
Old 09-24-2018, 12:24 AM   #67
Circuit
Less than I would have spent building the E36 I almost bought before this
At 275k now! Haha
Some recent photos. Have a few issues to take care of, then time for kpro.
Old 09-24-2018, 10:22 AM   #68
SanDiegoLoCo
I can get that for you
SanDiegoLoCo's Avatar
SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx SanDiegoLoCo is a jewel in the rough of c-rsx
That wing/spoiler is NICE I like that a lot better than the aspec wing!!
Sent from my iPhone using Tapatalk
SanDiegoLoCo is offline   Reply With Quote
Old 09-24-2018, 12:09 PM   #69
G3min1
Curious Gooner
G3min1's Avatar
G3min1 is on a distinguished road G3min1 is on a distinguished road G3min1 is on a distinguished road
Love the build and love updates man! Keep up the good work!
Originally Posted by krystar View Post
Turbo Pros: You get a BlowOff Valve PSHSHHHHHH
Cons: Your car can blow up
Supercharger Pros: You get that distinctive supercharger whine going down the street.
"Beating a Dead Horse Crew " Member #1
G3min1 is offline   Reply With Quote
Old 09-28-2018, 03:27 AM   #70
lasvegasdc5
lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx lasvegasdc5 is a jewel in the rough of c-rsx
Love your build.. This is truly an RSX resurrection. This thread is uplifting motivation for me to finish my build on my 02 RSX-S.
lasvegasdc5 is offline   Reply With Quote
Old 10-05-2018, 12:21 AM   #71
black dc5
black dc5's Avatar
that spoiler looks great. i should consider it. my 05 oem spoiler's double sided tape is giving up on the sides...
Old 10-07-2018, 06:52 AM   #72
Circuit
Thank you!
Yeah I like it a lot. It uses the same holes as the OEM wings, so if you only have the lip spoiler, you will have to drill holes.
2002 , circuit , rsx , silver , types
