Circuit's Silver 2002 RSX Type-S - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Member Show-Off RSX
Reply
Thread Tools
Old 02-05-2017, 10:53 PM   #1
Circuit
Member
Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx Circuit is a jewel in the rough of c-rsx
Hi Everyone! I just introduced myself over in the noob section, so I figured I'd start my build thread!
I'm starting with a 2002 RSX Type-S with 248k miles that I bought from a good friend for $1000! (story in my intro thread).
My last build (2003 Mazda Protege5): https://www.mazdas247.com/forum/show...-03-5-Protege5
My instagram: https://www.instagram.com/chris_mtechnica/
I am a partner at MemoryFab / MTechnica and will be running a set of our wheels.
Car came with:
  • Injen SRI that supposedly did not have the right CARB number
  • Tanabe Racing Medalion with Hello Kitty tip and aftermarket cat not CARB approved for the Type-S
  • Full Polk Audio/Kicker/Pioneer stereo system and Python alarm installed by my team and I when I worked at Circuit City about 10 years ago (told you we were good friends)
  • Some ricey black 17" wheels
  • A pool in the spare tire well
  • A dead battery
  • A nasty dent/scrape on the driver side rear fender
  • A flickering battery light on deceleration (after the battery replacement). I've read a bit on here that it could be the charge harness, serpentine belt, auto tensioner, and/or the alternator.
Photos:
So now what?!?!
I had to purchase an OEM cat and Injen CAI to pass smog. I also replaced the exhaust with a Tanabe Touring Medalion since the Hello Kitty tip was killing my street cred and was just too loud.
(check out that sweet condensation in the reverse light)
Plans for the car are:
1. Restore/replace/upgrade all the old, faded, worn-out, broken bits with new OEM or aftermarket (where applicable)
2. Build a fun daily driver in an OEM+ style
3. Have fun and don't go too far!(I definitely went too far on my Protege5 and it was no longer fun to drive except to and from shows/meets)
I've got the following on order:
  • Tail light gaskets
  • Cargo cover rubber grommets
  • OEM Honda Transmission fluid
  • OEM Honda Cabin Air filter
I found this list in another intro thread and will definitely be looking closely at all these things
-Coolant Flush - Should I just stick with OEM coolant? Anything to upgrade when I do this? I was told the radiator was replaced in the last year
-Oil Change - Hamp filters on order, will pick up oil locally - Done
-Tranny fluid change - On order - Replaced with new OEM
-Air filter - New Injen CAI installed
-Air cabin filter - On order - Done
-Spark Plugs - NGK (7746) IFR7G-11KS on order - Done
-Lube hinges and latches
-Inspect brake hoses
-Bleed brakefluid and replace with new Heavy Duty Dot3
-Inspect all fluid levels (Brake, Clutch, Power Steering, Coolant Level)
-Check suspension bolts and tighten as necessary
-Inspect autotensioner and replace as necessary - Working fine
-Inspect serpentine belt and replace as necessary - Replaced with new OEM
-Inspect CV joint boots and replace if cracked or worn
-Replace front and rear brake pads
-Silicon spray all door and trunk seals
-Inspect lightbulbs - Replaced with new OEM or upgrade
-Valve adjustment
-Rotate and balance tires
-Recharge R134a refrigerant if your A/C is not blowing as cold as it used to be
-Adjust Parking Brake (if not fully engaged within 7-9 clicks)
-Replace Battery (it may be nearing the end of its useful life) Done
-Inspect and adjust idle RPM
-Replace water pump
-Replace starter (if you get that scratchy sound on cold startups) - Getting the scratchy sound. New alternator received, waiting on IM gaskets to replace
-Replace Oxygen Sensor (even if its not giving you a check engine light, replacing it at your mileage will almost certainly give you better fuel economy) - Replaced with new Denso
did i mention motor mounts in there somewhere? i would take a look at them too to see if any needs replacing. also trunk and sunroof for leaks, i know the older rsx have troubles with the seal being bad or need changing.
Planned mods after all maintenance is done:
  • New or refinished bumpers
  • Type-R or some other lip kit
  • Type-R wing or shaved trunk with 05-06 lip spoiler
  • 17x9 +25 MTechnica Aero with 245/40 tires
  • BC Racing coilovers with 10/16k Swift Springs
  • Race Header
  • Kpro
  • Little OEM+/JDM/Mugen bits here and there
Circuit is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-05-2017, 11:00 PM   #2
mq1193
𝓟𝓻𝓸𝓹𝓮𝓻.
mq1193's Avatar
mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx mq1193 is a jewel in the rough of c-rsx
Looks like its going to be fun
Post the results afterwards!
mq1193 is offline   Reply With Quote
Old 02-05-2017, 11:11 PM   #3
Circuit
Member
Definitely! I'll be constantly updating this thread as the build progresses
Old 02-18-2017, 10:29 PM   #4
Circuit
Member
Here's some all around photos as a good starting point.
Day 1 of maintenance!
Got the following done:
  • New front wiper blades
  • Rear wiper delete with OEM plug
  • Replaced driver's side tail light gasket and upgraded bulbs to LEDs (passenger side story below)
  • Replaced front O2 sensor because of "slow to respond" CEL
  • Replaced cabin air filter (and learned there's 2, so another is on order)
  • Filled windshield wiper fliud (it was empty from the CAI install)
  • Attempted the red overlays and totally screwed up. Need to order another set.
  • Changed out spark plugs only to find the current set in there was exactly the same as I put in. Only thing I noticed is that 3 were super loose, so at least there's new plugs that are in there tight.
Issues I ran into today:
  • Passenger tail light had at least 5oz of water in it. Poured/soaked as much as I could until I found the side marker light was a large bulb and totally melted the housing. Ordered replacement OEM tail light
  • Drained oil but the drain plug was something I've never seen before. It looked so sketch and I didn't want to put it back on the car. I didn't have another car so I ordered one off Amazon that will be here tomorrow.
  • Learned that my auto-tensioner marking was way out of spec, so I'll be ordering a new serpentine belt as well
Here's some photos of the drain plug
I also picked up an A-Spec rear lip for $100 today. Will be storing it till I can source the rest of the kit and Type-R wing and get the whole car painted or wrapped.
More to come tomorrow!
Old 03-06-2017, 12:25 AM   #5
Circuit
Member
Turns out the oil drain plug was completely stripped so I had a new oil pan installed at a local shop. I read the how-to and just didn't have time to tackle dropping the subframe.
I installed the replacement passenger tail light as well.
Yesterday I tackled another batch of parts!
  • New OEM Serpentine belt
  • New rear O2 sensor
  • New Alternator
  • ITR brake ducts (withtout the tube since it would hit my CAI anyways)
  • Depo blacked out headlights
  • All new bumper hardware
  • New OEM driver's side fender liner
The starter I am saving for another day since the gasket for the intake manifold (hondata) and throttle body (hybrid racing) have yet to arrive.
The alternator came out fairly easily thanks to the how-to! the main issue I had was getting the 10mm nut off and back the ground line.
Seprentine belt was cake thanks to the how-to and removal tool I got from Amazon.
Old destroyed vs new OEM fender liner
Newly refreshed front end
Old 03-26-2017, 12:03 PM   #6
RajSX_TypeS
Member
RajSX_TypeS's Avatar
RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx
should chill one these days union city krispy kream
Daily - SSM 2005 RSX TypeS
Instagram - raj_dc5
build thread http://forums.clubrsx.com/showthread.php?t=1120202
RajSX_TypeS is offline   Reply With Quote
Old 03-26-2017, 04:53 PM   #7
dc5luis
Master N00b Member
dc5luis's Avatar
dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx
Garage
nothing better than getting new and quality parts.
dc5luis is offline   Reply With Quote
Old 03-26-2017, 11:51 PM   #8
Circuit
Member
Once I get some more work into her. I'm too embarrassed to bring her out in this state
You know it!
Old 03-27-2017, 11:26 AM   #9
Dad
Master Member
Dad's Avatar
Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own
Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own Dad must be an admin because here is no way they could have reached this amount on their own
Awesome job!!!
Everyones Favorite Brit
My WTB Thread
Dad is offline   Reply With Quote
Old 03-28-2017, 06:30 PM   #10
Circuit
Member
Originally Posted by Dad View Post
Awesome job!!!
Thanks Dad.
Old 03-29-2017, 09:00 AM   #11
Dad
Master Member
Dad's Avatar
You're welcome my son
My WTB Thread
Old 03-29-2017, 10:29 AM   #12
MollMan
Member
MollMan's Avatar
MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx MollMan is a jewel in the rough of c-rsx
Garage
Didn't see you list it but decent racing seats since typically the leather stock seats are shot. Especially at your mileage. Hows the interior look on this?
MollMan is offline   Reply With Quote
Old 03-29-2017, 02:18 PM   #13
InZain08
Senior Member
InZain08's Avatar
InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx
Those DEPO headlights look pretty cool! I've heard that they are hit or miss in terms of the housing seal so you may want to add some epoxy or reseal them yourself.
You've done a good job so far! Keep it up!
InZain08 is offline   Reply With Quote
Old 03-29-2017, 07:23 PM   #14
Circuit
Member
The interior is in OK condition. The front seats are both tearing on the bottom where they all tear at the seams. I had Evo 9 Recaros in my last build and would love another set. Not a priority right now.
I read that too, added clear sealant around the entire edge, and they still fog up with rain . Eventually I'll get a set retrofitted with projectors.
Old 04-03-2017, 10:49 PM   #15
Circuit
Member
Rear view mirror was all gross on the edges so I got a Spoon wide angle mirror.
Pulled the IM to replace the starter
Found a PRC on local craigslist so I dropped that in with Hondata and Hybrid Racing thermal gaskets while replacing the starter.
Old 04-12-2017, 11:12 PM   #16
black dc5
Master Member
black dc5's Avatar
black dc5 is an unknown quantity on c-rsx
Wow 248k is probably the highest mile K20 i've seen. Def interested in the updates. List of parts so far show this is gonna be a good build.
Do you know what has been done to the engine thus far to survive 248k miles? Timing chain replaced? Any other details on that?
:::black dc5 / silver NA6 garage:::
Got wide wheels/low offset? CLICK ME!!!:
http://forums.clubrsx.com/showthread.php?t=525211
black dc5 is offline   Reply With Quote
Old 04-12-2017, 11:43 PM   #17
Circuit
Member
Thanks! I just confirmed with my friend that the timing chain is STOCK . I've been assuming it was and am looking into local shops to replace it (along with a Hybrid Racing tensioner).
Better shot of the Spoon mirror without fingerprints LOL:
Today I replaced the radio for a newer one with Bluetooth (stereo was from 10+ years ago when I worked at Circuit City). Also tossed in an EP3 hazard switch while I had the dash kit out.
I have a TON of suspension parts coming together to do a full overhaul. Here's everything received/ordered so far:
  • BC Racing coilovers - Extereme Drop Kit w/ 10k front, 16k rear Swift springs
  • ES Black poly bushing kit
  • Whiteline rear upper knuckle bushings (only bushing ES kit is missing)
  • Ingalls Front and Rear Endlinks
  • Ingalls rear camber arms
  • New OEM tie rod ends and hardware
  • Todd's adjustable tie rods (back ordered)
  • Hardrace extended ball joints / roll center adjusters (back ordered, instead of Buddy Club since they don't have the locking ring and that's scary to me)
  • Hardrace rear trailing arms (rubber bushing)
  • Used OEM front and rear control arms so I can have a shop press in the bushings with minimal down time
Old 04-14-2017, 12:19 PM   #18
T.Y.
Member
T.Y.'s Avatar
T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx T.Y. is a jewel in the rough of c-rsx
Awesome updates! lets meet up sometime!
T.Y. is offline   Reply With Quote
Old 04-14-2017, 12:25 PM   #19
Circuit
Member
Thanks! Definitely once I get her in a better state.
Last night I ordered all OEM parts for a timing chain replacement:
  • Timing Chain
  • Timing chain tensioner
  • All 3 timing chain guides
  • Water pump
  • Oil cooler water lines
  • Water pump gasket and o-rings
Old 04-17-2017, 12:49 PM   #20
black dc5
Master Member
black dc5's Avatar
I have a Z3 (or was it TSX?) longer top chain guide which I still haven't installed. LOL.
Old 04-17-2017, 01:33 PM   #21
Circuit
Member
LOL thankfully this is one of those jobs I am paying someone to do, so I won't have it sitting for a long time. Good thing RCrew Racing is nearby to work his magic.
Old 04-17-2017, 07:08 PM   #22
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx
Garage
From what I've read and from my experience the stock chain tensioner performs well with stock cams. Someday if you go with aftermarket cams you will experience that any make of chain tensioner will live a shorter life.
DC5Sandbag is offline   Reply With Quote
Old 04-18-2017, 01:14 PM   #23
Circuit
Member
Yeah I was reading the same when deciding between OEM and aftermarket. No plans for cams as there's a lot more to do first, so I stuck with OEM.
Old 04-18-2017, 08:59 PM   #24
Rsxdippin
New Member
Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx Rsxdippin is a jewel in the rough of c-rsx
Good work! Subscribing for motivation!
Rsxdippin is offline   Reply With Quote
Old 04-18-2017, 09:20 PM   #25
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
Garage
[/QUOTE]
The front end looks a lot better. You're off to a good start in having a reliable fun car to drive. Sooner or later you're going to have the urge to tweak the ECU tune - it will feel like your engine is a 1000k miles newer.
Reply
Bookmarks
2002 , circuit , rsx , silver , types
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
