/*** nats007ís 02 NBP DC-5 K24 JRSC build/progress ***/ - Page 3 - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Member Show-Off RSX
Reply
Thread Tools
Old 07-03-2014, 07:58 PM   #51
nats007
Always on TDY...
nats007's Avatar
nats007 is on a distinguished road
Garage
sneak peek of what's to come
slight change of plans due to recent mishaps led to this...
2002 NHBP RSX-S | K-Pro v3 | 2006 K24a2 | JRSC (K24a2 CP + 3" BP) | MercRacing Inlet
FIC 775cc | AEM W/M (1000cc/min) | 3" Custom SRI | OBX v1 RH | 2.5" Custom Catback
nats007's DC5 progression
nats007 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-04-2014, 10:49 AM   #52
KingMaiya
Senior Member
KingMaiya's Avatar
KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx KingMaiya is a jewel in the rough of c-rsx
good luck !
XB1 Gamertag [ iLoyal Ranger ]
06 RSX-S|HKS|
MUGEN|RPF1
Instagram : Deemossi
KingMaiya is offline   Reply With Quote
Old 09-20-2014, 08:31 PM   #53
nats007
Always on TDY...
nats007's Avatar
Garage
K24 + JRSC content
After a few months of collecting parts, I finally got my swap going.
I got the car towed over to my installer and work began...
K20 REMOVED
K24 getting inspected and installing a 4130 Fabrication modified K20 oil pump
Transmission inspection and installation of MFactory LSD with new bearings
K24 with JRSC installed
Up and running
At this point, I was glad to see it in and the car running again. Little did I know that I'd be battling overheating for the next month
So, as I proceed to bleed the coolant system, I noticed my flywheel was exposed
So, I got the TSX engine stiffener
Old 09-20-2014, 08:46 PM   #54
nats007
Always on TDY...
nats007's Avatar
Garage
Then I tried every trick out there to bleed the coolant system. Its known that the K24 stills taller, so it's a bitch to burp air out of the system. I bleed the system for 3 weeks ( to include investing in a compressor, coolant vacuum filler, and lisle funnel) and it was still overheating. Then I figured it was a bad thermostat. I bought a new one, installed it, and it was still overheating repeating all the tips (car jacked up, pressure tested coolant system, vacuum filled coolant, and burped until no bubbles). My issue was the thermostat would not stay open. It will open when holding the rev around 3K, but close when you left off. Again, I bled for another week with the new thermostat with no success.
I even pulled this coolant line to help bleed and still no success other than gush coolant all over my garage
I gave up on the damn thermostat and deleted it.
I live in FL, so I don't really have any major concerns running without a thermostat. Rebleed the system and finally no overheating
Fan cycles on and off as it should... Heat works, A/C works... so things are finally looking normal.
Now that was sorted out, onto the exhaust. I'm running a custom 2.5" with a Flowmaster HP2 as the resonator and a Dynomax Super Turbo Muffler in the back. This catback is mated to a OBX v1 RH. The car sounds quiet at idle and under 2K, but a nice, deep tone when opened up that is not obnoxiously loud. I was against getting a exhaust and was going to keep my 06 Type S exhaust, but I have no complaints with setup and appreciate the recommendations from the supercharged crew!
I'm still running off my old tune, but the car definitely feels stronger. I'm still in the break in period for the LSD and new clutch. I'm hoping to get tuned in the near future, but kind of depleted funds in completing this swap. All in all, glad it's done and I can drive my car again.
I'll update the mod list with final setup
Old 10-04-2014, 01:47 PM   #55
nats007
Always on TDY...
nats007's Avatar
Garage
updated first post with mods for current setup
Sound clip of my 2.5" custom exhaust setup: http://youtu.be/Ab2ctToK-70
Old 10-31-2014, 07:19 AM   #56
nats007
Always on TDY...
nats007's Avatar
Garage
BUMP... Doing some dyno pulls tomorrow for base numbers prior to tune in the next few months. Will post results
Old 10-31-2014, 11:50 PM   #57
Luna
Tuna Luna
Luna's Avatar
Luna is on a distinguished road
Subscribed
Originally Posted by crod06 View Post
Some say his tooth is black because it's rotten, I believe the devil lives in there
Luna is offline   Reply With Quote
Old 11-19-2014, 06:28 PM   #58
xxyauxxdc5
DC5
xxyauxxdc5's Avatar
xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx xxyauxxdc5 is a jewel in the rough of c-rsx
subscribed. are u running a stock k24 long block?
xxyauxxdc5 is offline   Reply With Quote
Old 11-19-2014, 07:46 PM   #59
nats007
Always on TDY...
nats007's Avatar
Garage
Originally Posted by Luna View Post
Subscribed
yes, stock K24a2 with a modified K20 oil pump.
Update:
I meant to update this but I need a tune for my new setup. My car hits lean cut at 6K revs on a 4th gear pull. Made a strong 228 which still beat out quite a few S2Ks that were there. I was kind of expecting this to happen but was hoping to get a baseline before my next tune.
I plan on getting tuned in January. Will post updates as I make progress with it.
Old 11-19-2014, 08:09 PM   #60
nats007
Always on TDY...
nats007's Avatar
Garage
Most recent shots from my backyard
Currently have a oil leak at the oil pan through the seal, so I have to get that resealed with my next oil change
Old 11-20-2014, 12:54 AM   #61
xxyauxxdc5
DC5
xxyauxxdc5's Avatar
no more high compression k24 supercharged?
Old 11-20-2014, 07:04 AM   #62
nats007
Always on TDY...
nats007's Avatar
Garage
Stock 10.5:1 for K24. I was stock at 11.0:1 on the K20 setup as well.
Old 02-16-2015, 07:10 PM   #63
nats007
Always on TDY...
nats007's Avatar
Garage
Update coming soon...
Old 04-04-2015, 04:56 PM   #64
nats007
Always on TDY...
nats007's Avatar
Garage
UPDATE: Got tuned back a couple month back. Car made 268whp / 213 wtq on 5 PSI. at 7600rpm.
Backstory: I did not realize that my crank pulley was swapped from the k24a2 (6.125") to the K20a2 (5.80") until the week before my tune. If I had the k24 crank pulley on, I would have made around 7-8 psi with the 3.2" boost pulley and make 290+ whp.
Other than that, the car has been driving great. I was able to source my k24a2 crank pulley back and will install this summer with EPS.
Here is how the car currently sits:
I'm getting my A-Spec front lip, A-Spec rear lip, ITR side skirts, and front bumper resprayed soon and then a proper shoot
Old 04-23-2015, 07:28 PM   #65
nats007
Always on TDY...
nats007's Avatar
Garage
first post updated and some pics here
and the Mrs X Tech / family hauler with dual RES
Old 06-16-2015, 10:46 PM   #66
nats007
Always on TDY...
nats007's Avatar
Garage
cleaned my headlights
before
after
Old 06-17-2015, 02:23 AM   #67
RajSX_TypeS
Member
RajSX_TypeS's Avatar
RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx RajSX_TypeS is a jewel in the rough of c-rsx
nice build yo man your previous full k20 jrsc made nice power got me thinking about SC
Daily - SSM 2005 RSX TypeS
Instagram - raj_dc5
build thread http://forums.clubrsx.com/showthread.php?t=1120202
RajSX_TypeS is offline   Reply With Quote
Old 06-17-2015, 08:39 AM   #68
nats007
Always on TDY...
nats007's Avatar
Garage
You won't be disappointed if you do
Old 07-05-2015, 09:56 AM   #69
MYK20
Senior Member
MYK20's Avatar
MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx MYK20 is a jewel in the rough of c-rsx
anymore updates?i always always curious if the S/C of the k20 would have some clearance issues bolting on a k24. Guess not
MYK20 is offline   Reply With Quote
Old 07-05-2015, 04:26 PM   #70
nats007
Always on TDY...
nats007's Avatar
Garage
No real updates at this time. Just been driving and enjoying it. No issues with fitting the JRSC onto the K24. The only problem I have is hood clearance with the p/s pump. Going EPS is the best solution, but I haven't pulled the trigger on that yet.
Old 07-06-2015, 07:34 AM   #71
nats007
Always on TDY...
nats007's Avatar
Garage
Latest bay shot... Getting ready to change up the VC
Old 07-11-2015, 12:00 AM   #72
speedfreak0920
Member
speedfreak0920's Avatar
speedfreak0920 is an unknown quantity on c-rsx
Nice and clean. Looks like you put a lot of hard work in the car. I'm digging the Aspec kit and wheels.
Any new dyno #'s with the new pulley ?
speedfreak0920 is offline   Reply With Quote
Old 07-19-2015, 02:27 PM   #73
nats007
Always on TDY...
nats007's Avatar
Garage
Thank you and yes, it's been a lot of work, especially with my limited time to work on it.
No new dyno numbers yet. I needed to handle some maintenance work on my beater and just got that running today.
The RSX needs new rotors, brake pads, tires and a radiator upgrade (car gets hot here in FL). Once those are sorted out, I'll swap the crank pulley and get re-tuned.
Old 07-24-2015, 09:14 PM   #74
JustDoingMe
These hoes ain't loyal
JustDoingMe's Avatar
JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx JustDoingMe is a jewel in the rough of c-rsx
fck the car, show us tour of house
JustDoingMe is offline   Reply With Quote
Old 10-15-2015, 09:08 PM   #75
nats007
Always on TDY...
nats007's Avatar
Garage
Recent acquisitions
Reply
Bookmarks
build , build or progress , commenced or , dc5 , jrsc , k24 , nats007ís , nbp , or nats007ís , s or c , showoff , thread or
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
