some guy in the forum tried to install it on the 05 but he couldnt , i dont remembr why i think it was beccuase the sensores on the 05 was relocated so. go search ...
I think he tried to install an 02-04 PRC Type R intake manifold on an 05 US Type S, he noticed the sensors had been moved onto different spots. We don't know about the 05 PRC Type R manifold yet.
i've been wondering the same damn thing. i want to get the itr manifold for my 05, but where the hell can i get a 05 itr manifold? i'm pretty sure the one on rsxmotorsports.com is the 02-04 one.
To use an 02-04 ITR IM, you need a throttle body off of an 02-04 as well. The 05 Type S IM is a revision of the 02-04 Type S IM and is NOT an ITR IM. That said, the 05 ITR IM may be a similar revision of the 02-04 ITR IM, but I for one haven't seen one.
The cams in the 05 Type S are a variant of the 02-04 ITR cams. But they're not the same and it is a mistake to state so.
To use an 02-04 ITT IM on 05-06 Type S you DO NOT need the 02-04 Throttle Body.
To make it work all you need to do is make a slit in the TB gasket right below the MAP hole.
But the part number on the 05 type s cams are listed as PRC (i was under the impression that PRC is type R only), maybe they are not identical to 02-04 ITR cams but maybe they are the exact same ones on the 05 ITR. :dontknow:
Anybody have part numbers for the 05 JDM ITR Cams that we can cross reference?
Related Threads
29.7M posts
179.4K members
Since 2001
