S2000 Project - Club RSX Message Board
Go Back   Club RSX Message Board > OTHER CARS > Honda S2000
Reply
Thread Tools
Old 04-03-2012, 03:35 PM   #1
0x64
New Member
0x64's Avatar
0x64 is an unknown quantity on c-rsx
S2000 Project
I've been meaning to post this but wanted to wait until we got a little further along. We still have a lot of work left to do. I will update this as things move along and I get time to.
We originally got this car with what was suppose to be an AEM Series 2 and Ferrea valve train. We found an AEM Version 1 and Supertech valve train with stock valves, stock keepers and some broken titanium retainers. The exhaust valves were severely bent. Compression came out to 181.5, 157.0, 159.0, 181.5 and leakdown came out to 2%, 36%, 30%, 5%. The engine had less than 500 miles on it.
Out with the old in with the new We pulled the engine. Tore it down. Sent it to our machine shop for a fresh hone, deck surface and polished the crank journals. Fitted the rear of the car with a Ford 8.8 rear end and Drive Shaft Shop 5.9 axles from Full Blown Motorsports and a Toyota V160 transmission we rebuilt with zero miles.
- AP1 Benson sleeved block
- Honda crank polished and balanced
- CP forged pistons with upgraded wrist pins and custom piston rings
- Pauter forged rods
- Honda rod/main/thrust bearings
- A1 Technologies H11/L19 headstuds
- Honda main bolts (brand new)
- Full Blown Motorsports S2000 rear end kit with 5.9 upgrade
- Full Blown Motorsports S2000 rear end with Eaton posi lsd
- Full Blown Motorsports S2000 S2KV160 adapter plate, shifter and transmission mount
- Full Blown Motorsports S2000 Clutchmasters custom twin disc for V160-S2K swap
- Avid Racing differential mounts
- Induction Performance Stage 2 port and polish
- Induction Performance valve job
- Ferrea Competition Plus 1mm over intake valves
- Ferrea Competition Plus 1mm over exhaust valves
- Ferrea Dual Spring Special Alloy Turbo valve springs
- Ferrea Titanium retainers
- Ferrea seat locators
- Ferrea 1mm over intake bronze valve guides
- Ferrea 1mm over exhaust bronze valve guides
- Ferrea valve stem seals
- Ferrea steel valve locks
- Sidewinder exhaust manifold
- Custom catch can
- Injector Dynamics 2200cc fuel injectors
- Inline Pro intake manifold
... more to come
We have a lot of plans for the car. We're going to be fitting it with a ProEFI Pro 128 engine management system with fuel pressure feedback, full flex fuel feedback, traction control and more. The car is going into paint.
- Induction Performance Tampa Florida 813.443.5064
0x64 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-03-2012, 03:35 PM   #2
0x64
New Member
0x64's Avatar
An engine stand opened up and it made it onto the stand
Old 04-03-2012, 03:36 PM   #3
0x64
New Member
0x64's Avatar
Shortblock is together. We should be done with the head work by the end of next week.
Old 04-03-2012, 03:36 PM   #4
0x64
New Member
0x64's Avatar
A little more updating. The cylinder head is finished The engine bay body work is coming along. I will try to take a couple pictures tomorrow.
Old 04-03-2012, 03:37 PM   #5
0x64
New Member
0x64's Avatar
Engine bay should be filled, touched up and painted by tomorrow
Old 04-03-2012, 03:37 PM   #6
0x64
New Member
0x64's Avatar
Engine bay is almost done
Old 04-03-2012, 03:49 PM   #7
itskien
Doesn't Give A F*ck
itskien's Avatar
itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with itskien is a name not to mess with
looking good
Empty Tank Crew #1
Twitter: KiensAJauk
Instagram / Snapchat: ItsKien
Originally Posted by AzianK View Post
kien you fat fuck, no set of wings can lift your cinna bun ass up to heaven anyway.
itskien is offline   Reply With Quote
Old 04-04-2012, 01:07 PM   #8
White_02
White_02's Avatar
White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own
White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own White_02 must be an admin because here is no way they could have reached this amount on their own
Shit, with all that, why not just go with a V8?
Nice progress though. Every time I see a tuck, I want to do it to mine but no reason yet
White_02 is offline   Reply With Quote
Old 04-04-2012, 02:12 PM   #9
0x64
New Member
0x64's Avatar
Thanks itskien
You would spend a little more doing a 1000+whp V8. If we were going to stuff anything in it then we would stuff a 2JZ-GTE in it Thanks
Old 04-04-2012, 09:14 PM   #10
Cochino
Cochino's Avatar
Cochino is an unknown quantity on c-rsx
05 corolla s: dd.
07 S2000- D3 Performance Engineering Tuned-700rwhp
08 z06-i/h/c- new toy
Fast and cheap won't be reliable. Cheap and reliable won't be fast. Fast and reliable won't be cheap.
Cochino is offline   Reply With Quote
Old 04-04-2012, 09:40 PM   #11
AxelTaylor
Master Member
AxelTaylor's Avatar
AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though AxelTaylor is cool, not as cool as some though
Awesome build. This going to be a purpose built drag car or what?
AxelTaylor is offline   Reply With Quote
Old 04-05-2012, 09:16 AM   #12
0x64
New Member
0x64's Avatar
For now the plan is for it to be a street car. The goal is 1000whp and to run 8's. The ecu being used will allow it to be driven on pump fuel and any mixture of ethanol without a laptop or any adjustments.
Reply
Bookmarks
project , s2000
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
