Wanting too many things at once... - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Bolt-On Basics: RSX (Base)
Old 03-20-2019, 05:17 PM   #1
nhbp.rsx
nhbp.rsx's Avatar
nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx nhbp.rsx is a jewel in the rough of c-rsx
It's time... after about 3 years, I think it's time for a first proper mod. (aside from some nice summer preformance tires)
05' base 5spd. Still new to this, so any help would be great.
My plan is to switch out the stock exhaust but after some research I would need to switch out the header for a type S header & ALSO switch out the motor mounts. Doing the work myself would save me money since it doesn't look like an insane job but now my question is what to do first... Money is a little tigher than I thoguth right now at least until I get that tax return...
I was looking towards: invidia Q300 with the invidia header
and if possible Hasport motor mounts.
the mounts alone are about $500 cdn (for 62A or 70A) I think 70a should more than enough for daily driving & some night runs
the header from what I've seen is $900+ and the exhaust is about 750...
I can't go the Header/mounts option cuz I can't run the stock exhaust with them, trying to find a type-s cat back might be difficult.
So is it possible go with headers/exhaust and wait on the motor mounts? or am I asking for trouble with a cracked new header.
The car is still stock
nhbp.rsx is offline   Reply With Quote
Old 03-20-2019, 09:35 PM   #2
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx
Motor mount inserts will work well and I believe they still cost less than $40.00. My engine generates 360hp and my inserts are performing just fine.
DC5Sandbag is offline   Reply With Quote
Old 03-20-2019, 11:26 PM   #3
Since you’re getting a race header and exhaust, I recommend you get Kpro or ktuner, or at least a race header specific reflash. I’m sure there will be gains, but it could make you lean at WOT. Getting tuned will allow you to take full advantage of the increase in exhaust flow. An intake wouldn’t be a bad idea either.
mfarmakas17 is online now   Reply With Quote
Old 03-29-2019, 07:13 PM   #4
nhbp.rsx
nhbp.rsx's Avatar
Thanks for the reply guys. If you don’t mind me asking what kinda mounts do you have? What grade (still new to mounts)
As for the tune thanks for the recommendation, I haven’t done any research as of yet on those ecu tuners but I’m assuming it won’t be cheap, if I got the header/exhaust/mounts would I be doing damage by doing pulls every now and then?
Any key tips or do’s / do not, when switching out header/exhaust?
Didn’t notice you said mount inserts, those are the cheaper route right? How long have you had your inserts?
Old 03-29-2019, 08:03 PM   #5
It's possible that you can damage something, but you really won't know unless you're monitoring your A/F ratio. I've read posts on here where people are lean after installing a race header, and others are fine.
Becase you have an 05, Ktuner will be cheaper than Kpro. As far as I know, they both have all of the same features, but Kpro has a larger support base as it's been around longer. Think I paid $500 and sent in my ECU to be modified. Turbogixxer Tuning offers a Ktuner reflash for intake/header/exhaust for $295. With both of these options though, you'll be without a vehicle until you get your ECU back. You can also get an ECU that's already prepped with Ktuner, but that's a couple hundred extra bucks.
As for the exhaust, just make sure you don't bottle neck it. What I mean by that is don't get an exhaust that has a smaller diameter pipe than the collector on the race header. It'll impede exhaust flow and render any gains from the header obsolete.
Old 03-30-2019, 12:45 PM   #6
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
^x2. To be on the safe side, replace the engine's stainless steel exhaust manifold gasket with a new one to avoid leaks. Torque bolts/nuts starting from the middle and working your way to the outside ones. Tighten gasket bolts a little bit at a time so that the gasket is compressed evenly. The worst thing you could do is tighten a bolt/nut completely before moving onto the next one.
Old 04-01-2019, 06:39 PM   #7
Kevink121
#Inkpot
Kevink121's Avatar
Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member Kevink121 is a glorious c-rsx member
Just my opinion here but I've read over and over that you can run the header back without a tune fairly safely. Its when you get into an intake manifold that you really have to get a safer tune.
The q300 is a great exhaust, I had it and loved it compared to what everyone else had on theor cars.
Id say get the plm header for a lot cheaper but the fitmemt with the q300 is... less than ideal(shit) as I had that as well. Perhaps the dc header is less of a pain in the ass with the q300. You should be able to find the q300 used for a decent price.
All this said and done, if its the base rsx, Id just throw on some eBay short headers and the cat back. When your able to afford it later, get the iTunes and maybe a tune will give you a nice boost with a lower vtec engagement point.
Again just my opinion. But I definitely reccomend the q300.
[youtube/youtube]
This little baby car Do you even Miata, bro?
PERMANENT Arcade Champion
Kevink121 is offline   Reply With Quote
Old 04-10-2019, 08:20 AM   #8
nhbp.rsx
nhbp.rsx's Avatar
For the bottle neck thing, that seems pretty straight forward, Iíll have to double check the sizes but Iím sure if I pair the Invidia header with the Invidia exhaust it would be fine. For ktuner Iíll keep that in mind, I still have the stock air box at the moment though. I donít know much on those reflashes, it pretty much changes my a/f ratio and when vtec can engage right?
Thanks for that, donít have a torque wrench for we job sadly, making them snug will be fine I hope. Not sure if most companies provide the header gasket but worst case sernario I can hit up a Honda shop.
Yeah thanks bro, most def going with the q300. I thought about the cheaper route but Iíd rather swap the old with something good while I have money now tbh lol. The tune or ktuner will most likely have to come later on.
Old 04-10-2019, 08:35 AM   #9
nhbp.rsx
nhbp.rsx's Avatar
On a side note, I was planning to trying new, mainly just to make sure I get all the parts I need.
Old 04-10-2019, 08:57 AM   #10
Kevink121
#Inkpot
Kevink121's Avatar
O_o
When I wrote "iTunes" Im guessing I meant ktuner
[youtube/youtube]
Old 06-03-2019, 08:21 PM   #11
nhbp.rsx
nhbp.rsx's Avatar
Well shoot, I got my tax return and ending up buying a bunch of shit ha... Not completely broke but almost... anyways
I bought K-Tuned K1 coilovers
K-tuned header
K-tuned 3" catback exhaust
camber bolts & a rear camber arms/kit
Old 06-03-2019, 08:29 PM   #12
nhbp.rsx
nhbp.rsx's Avatar
Attempted to install the mounts today but I couldn't get one of the nuts off the driver side mount stud, I also tried to remove the battery and still couldn't get a good angle on it, tried to take off the battery tray but couldn't fully get it off... found a third bolt below the tray and i was gonna try to take it off but it looked rusted af & rounded so I said screw it, I'd rather keep it there and make sure I can put the battery back in and have it secure.
Going to try to get the mounts in this week again, then hopefully the header and exhaust (still kinda scared, thinking that the header wont fit for some reason) then after the power mods, get the coilovers on, camber kit & get the alignment the following day or the next day.
Still need to replace my rotors as well and look up more info on tuning/ecu stuff.
Old 06-08-2019, 07:56 AM   #13
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
Installing new mods on your RSX equals fun times. How much were thinking of dropping the ride height?
Old 06-11-2019, 07:43 PM   #14
nhbp.rsx
nhbp.rsx's Avatar
tbh not much lower, some of these roads around downtown toronto are ass so I'm 100% not going for the slammed style (might be the opposite in the next year or two lol)
So far I got the motor mounts in solo and then the next day me and a friend tackled the header/exhaust setup. Also helped him install his new intercooler on his mini cooper
As for the coilovers maybe 1.5 inches maybe?
things , wanting
Oboma / Military Destroying once fired Brass Government Stops Once Fired Brass Sales The Tech-1 The Great Outdoors 49 03-27-2009 05:16 PM
How many miles is too many miles? G8way General RSX Discussion 34 04-28-2008 01:46 AM
miss my car too(man too many rsx's are going down) stillstock Problems & Solutions RSX 40 08-14-2007 01:59 PM
How many miles is too many to add a supercharger Fanatik Supercharging RSX 19 03-14-2005 04:24 PM
