Supercharged *CHAT* CXV - The S/C crew resurrection - Page 34 - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Supercharging RSX
Reply
Thread Tools
Old 09-20-2017, 07:41 PM   #826
nats007
Always on TDY...
nats007's Avatar
nats007 is on a distinguished road nats007 is on a distinguished road
Garage
^ I need to do something similar as well...
2002 NHBP RSX-S | K-Pro v3 | 2006 K24a2 | JRSC (K24a2 CP + 3" BP) | MercRacing Inlet
FIC 775cc | AEM W/M (1000cc/min) | 3" Custom SRI | OBX v1 RH | 2.5" Custom Catback
nats007's DC5 progression
nats007 is online now   Reply With Quote
Sponsored Links
Advertisement
Old 09-22-2017, 10:15 PM   #827
abpRSX-S
Senior Member
abpRSX-S's Avatar
abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx abpRSX-S is a jewel in the rough of c-rsx
I believe my second gear or second gear syncro may have bit the dust. I can put it in second but sounds chunky and vibrates. Crazy thing is I wasn't even beating on it. Drove to the gym and it was fine. Came out and bam second gear started making some crazy sounds.
This isn't where i parked my car....
-Broke Student Crew #25-
-335whp JRSC RSX
abpRSX-S is offline   Reply With Quote
Old 09-24-2017, 11:20 AM   #828
nats007
Always on TDY...
nats007's Avatar
Garage
^ interesting... Experienced it again? Have you changed your transmission fluid? Thinking may be worth a shot
Old 09-24-2017, 11:56 AM   #829
abpRSX-S
Senior Member
abpRSX-S's Avatar
Yeah does it every time I shift into second. Sounds like the gears aren't meshing together right. Going to change fluid and check for metal as soon as I get some time. Drove it yesterday just skipping 2nd and it was fine. It's just annoying to ride first out to 4k and then shift to 3rd at 1.5-2k
-335whp JRSC RSX
Old 09-24-2017, 12:05 PM   #830
abpRSX-S
Senior Member
abpRSX-S's Avatar
Its just weird cuz it shifts into 2nd fine it's just chunky once you let off the clutch and start driving in second. Then the way it happened was weird too. Didn't beat on my car or anything. Drove to the gym everything was fine left the gym and it was acting up.
-335whp JRSC RSX
Old 09-24-2017, 12:06 PM   #831
nats007
Always on TDY...
nats007's Avatar
Garage
Damn, that is annoying. Keep us posted on the results Sir
Old 09-24-2017, 12:09 PM   #832
nats007
Always on TDY...
nats007's Avatar
Garage
Hopefully fluid change fixes it... No grinding right
Old 09-24-2017, 12:15 PM   #833
abpRSX-S
Senior Member
abpRSX-S's Avatar
No no grinding shifting onto gear only grinds when I'm in gear and driving. I'll def keep you guys up to date on it
-335whp JRSC RSX
Old 09-25-2017, 07:37 AM   #834
nats007
Always on TDY...
nats007's Avatar
Garage
Morning
Heading off to D.C. area for work... Didn't get to work on the cars as I hoped. I did remove a ton of water out of the Mazda3 door and wetvac the rear as water got in during the hurricane
Old 09-28-2017, 08:32 AM   #835
nats007
Always on TDY...
nats007's Avatar
Garage
Finally thinking about getting the AEM Uego...
https://www.amazon.com/gp/aw/d/B00N3...o+wideband+kit
This is the one I believe most folks run and requires no open air calibration, correct? I'll probably bypass connecting it to kpro as it will only support datalogging. The primary O2 sensor will still provide AFR readings to kpro and this is more as a failsafe so I'm aware if I get too rich or lean since I don't ride around with a laptop everyday.
Old 09-28-2017, 02:47 PM   #836
abpRSX-S
Senior Member
abpRSX-S's Avatar
Changed the trans fluid today and had zero metallics in the fluid. Pretty sure the 2nd gear syncro is bad. If I'm at a stop and go to put it into second it'll grind..... and continue to grind the whole time you're in second
-335whp JRSC RSX
Old 09-28-2017, 03:18 PM   #837
abpRSX-S
Senior Member
abpRSX-S's Avatar
Yeah I'm pretty sure I remember reading that's the open air calibration sensor. I have a carbon fiber autometer wideband in my car.
Also found a guy that will rebuild my trans for 200, I need 2nd and 3rd synchros, is there anything else that is recommended. Do I need the gears too or should just synchros be fine?
-335whp JRSC RSX
Old 09-28-2017, 04:09 PM   #838
nats007
Always on TDY...
nats007's Avatar
Garage
Thanks! From this article is where I thought it didn't require open air calibration: https://www.google.com/amp/s/10carbe...and-gauges/amp
For your transmission, that's a good sign with no metallic shavings in the oil. It's hard to tell until it's opened up. One recommendation would be to check the diff bearings.
I'm realizing today I have some maintenance to do on the RSX... It's getting hot w/ AC on and starts overheating... Temps drop when I take the AC off, so I assume there is still air bubbles in the system
Old 09-28-2017, 06:45 PM   #839
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx DC5Sandbag might be well recognized one day on c-rsx
Garage
Yes that's the right unit. The gauge comes pre calibrated with its controller built into it and its own O2 sensor. I recommend that you unplug the OEM sensor and install the AEM unit as your primary sensor. All you will need to do is run the gauge’s ground wire to the engine block, provide a 12v power source to it, next connect the remaining wires to Kpro using one of the pigtails that was shipped with your Kpro. Its that easy. Last thing you will need to is go into Kmanager and change the O2 sensor setting. To help you out, when you get ready to do is install one I will take some pictures of my setup including the ECU wiring.
DC5Sandbag is offline   Reply With Quote
Old 09-28-2017, 08:28 PM   #840
nats007
Always on TDY...
nats007's Avatar
Garage
Cool... I'll see if I still have said pigtails. If I don't have to splice wires, I'll be for running it to kpro (I have v3). I'll probably buy one in the next few months
Old 09-28-2017, 09:08 PM   #841
DC5Sandbag
Past Driverís Ed
DC5Sandbag's Avatar
Garage
Sorry my mistake. For easy installation you need Kpro v4. If I remember correctly that was one of the advantages v4 had over v3. I believe it $270 to upgrade v3 to v4.
Old 09-28-2017, 10:48 PM   #842
Luna
Tuna Luna
Luna's Avatar
Luna is on a distinguished road
$300 shipped and returned for that service is what I paid.
Originally Posted by crod06 View Post
Some say his tooth is black because it's rotten, I believe the devil lives in there
Luna is offline   Reply With Quote
Old 09-29-2017, 06:38 AM   #843
nats007
Always on TDY...
nats007's Avatar
Garage
^^^ ahhh... Thanks for the clarification!
Well that adjust the priority list for v4 need.
Old 09-30-2017, 07:05 AM   #844
nats007
Always on TDY...
nats007's Avatar
Garage
So I just stumbled upon this: http://forums.clubrsx.com/showthread.ph ... r+boundary
I'm trying the closed loop change recommended (change 87kPa to 102kPa) to see if that improves gas mileage. I'll keep my VTEC (lower and upper) at 98kPa for now, but I'm interested in reading your VTEC engagement settings.
Right now, I'm set at the following:
Lower Boundary = 3200rpm @ 98kPa
Upper Boundary = 5200rpm @ 98kPa
I was thinking about changing lower to 3500rpm since I cruise around ~3200rpm on the hwy. I thought this meant I cruising in high cam all the time, but this may not be the case.
After more digging, I'm going to try lower = 3000rpm @ 98kPa and upper = 5000rpm @ 87kPa...
The kPA is what I'm interested in reading for what you guys have set on the upper boundary. It's not clear to me as see various S/C kals with it set the same kPa and others with lower at 98kPa and upper at a lower kPa (e.g., 24, 50, 87, and even 90)???
Old 10-02-2017, 07:27 AM   #845
nats007
Always on TDY...
nats007's Avatar
Garage
Morning gents
So I tweaked my tune a bit and learning my foot is heavier than I thought. Currently at 180 miles right under 1/2 tank. I guess wanting to spray to keep intake temps down is no bueno for mpgs lol
Old 10-09-2017, 08:40 PM   #846
FuknRSX
Member
FuknRSX is an unknown quantity on c-rsx
Garage
Morning gents
im lucky to get 180 miles on a full tank. count yourself lucky. maybe i need to upgrade my kpro v3 to v4 and get it rewired to use my aem uego. then def would get re-tuned by someone different than the last place.
replaced my exedy stage 1 with an action stage 3 and action lightweight flywheel. shortly after the clutch started feeling "loose" meaning not taking a lot work to press it. hard parked her in the garage for the last month. finally got around to diagnosing the problem and it ended up being the k-tuned slave cylinder with a bad o-ring. replaced it with a civic unit and its back to brand new.
k-tuned is on my shit list now.
2005 JGM Acura RSX Type-S CT Supercharged
SOLD 4/7/2018
FuknRSX is offline   Reply With Quote
Old 10-10-2017, 05:45 AM   #847
nats007
Always on TDY...
nats007's Avatar
Garage
Lol... Normally get 180-200 per tank. Biggest change for me was driving style to get to 250. Staying out of boost and being light on the throttle was key. It was too much work being cautious like that, so I'm just glad to see it can be done.
I think if you upgrade, go v4. I have v3 and you can't run Uego with that version. For clutches, CSC, CMCs I dealt with that years back. Did all OEM except for running the exedy organic clutch w/ no complaints.
Old 10-10-2017, 05:49 AM   #848
nats007
Always on TDY...
nats007's Avatar
Garage
Morning
Cooler weather starting up... Still high 70s-80s here in FL, but I'm heading to west coast and see low 30s at night
Old 10-10-2017, 05:36 PM   #849
torresa009
Member
torresa009's Avatar
torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx
Morning
same here in california. we are getting some colder nights. my tune does not like colder weather, its not compensating enough for the 60* temps, and my fuel system is already maxed out. I'm working on a fuel return system to free up some injector duty cycle and add more fuel
torresa009 is offline   Reply With Quote
Old 10-10-2017, 05:44 PM   #850
torresa009
Member
torresa009's Avatar
So pretty much everyone here knows MercRacing; we are trying to setup a group buy for a MercRacing fuel rail. the details are below. these fuel rails are a limited production so this is the chance to get one (who knows when there will be another batch)
"Looking to set up a group buy for MercRacing fuel rails. We need 10 people to commit to put the order through.
Those interested should email Jose at jmercado@mercracing.net
Pricing for a batch of 10 would be $250 SHIPPED per rail. Those in Canada will be looking at a little extra to compensate.
He'll send you an invoice, which will be refunded if the 10 piece minimum is not met."
Reply
Bookmarks
crew , cxv , resurrection , s or c , supercharged
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © 2001-2012, Club RSX, Inc. All rights reserved worldwide.
