Mechanical O2 Sensor Simulator with PICS. - Page 2 - Club RSX Message Board
Reply
Thread Tools
Old 10-26-2005, 11:55 PM   #26
spd579
Master Member
spd579's Avatar
spd579 has been a little shit in the past
why would you want to if you do both it will mess up your air/fuel readings
05 RSX-S DD
89 Miata--400 hp go-cart
03 350Z Track--In between ride
spd579 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-27-2005, 12:04 AM   #27
BryanP
BryanP is an unknown quantity on c-rsx
a/f is monitored by the first sensor.
he's talking about having BOTH defoulers being used on the 2nd sensor as told by the instructions. i threw a CEL (every 100 or so miles) using one defouler so I'm gonna get my second one installed tomorrow and see if it can go away.
BryanP is offline   Reply With Quote
Old 10-27-2005, 12:09 AM   #28
spd579
Master Member
spd579's Avatar
where can you get the defoulers? I have a DCRH on the way and I hve no Idea. local parts store or what?
05 RSX-S DD
Old 10-27-2005, 01:16 AM   #29
BryanP
yeah, go to autozone and get the Help brand one model 42009
i only used 1 because my friend used it... i'm gonna use 2... pretty sure the problem will go away for a long time because it barely comes on with 1 in there and it works pretty well. (i just resetted and so far no CEL with 40 miles)
Old 10-27-2005, 08:04 PM   #30
BryanP
ok i'm using 2 now and no CEL with 30 miles of driving so far... don't expect it to come on anytime soon either.
Old 10-30-2005, 10:59 PM   #31
BryanP
hasn't gone on yet (over 100 miles)
edit: 150+ miles no CEL
Old 11-07-2005, 02:22 AM   #32
rsxnky02
Master Member
rsxnky02's Avatar
rsxnky02 is an unknown quantity on c-rsx
so a test pipe and two of these things are all you need to get rid of that damn cat? sosojeff- that pipe is sexy. where did you get it, how much? do i need anything else to get rid of that cat?
rsxnky02 is offline   Reply With Quote
Old 11-07-2005, 02:32 AM   #33
BryanP
what do you mean cat... are u talking about cel?
to get rid of cat just replace it with something that fills it in lol. you put the o2 sensors in the bungs that the pipes usually have. the defoulers help in keeping the chemicals away from the sensor itself so you don't get a cat failure CEL. its safe and under WOT it doesn't fail. i've WOTd a lot since I had my testpipe on and I've had it for around 200 miles with no CEL yet. I got it the first time installed however, (in 40 miles it came on) but after I reset the ECU (disconnected negative terminal in battery... made sure that shit was all gone lol so I left it off for 10 minutes), CEL hasn't come on since...
Old 11-18-2005, 09:04 PM   #34
JonJonEDogg
Senior Member
JonJonEDogg's Avatar
JonJonEDogg is an unknown quantity on c-rsx
ADVICE: ESMM, DCRH, and Front Sway Bar install (same time)
I will be installing the said parts next week all at the same time. Does anyone have any tips on this? I have read and re-read all the DIYs on these and think that I am ready. Anyone have any suggestions as to what order I should do things? Any help would be greatly appreciated! Thanks. PS. Is it ok that I will be doing everything by myself or is it mandatory to have an extra set of hands? Thanks again!
JonJonEDogg is offline   Reply With Quote
Old 11-18-2005, 09:05 PM   #35
JonJonEDogg
Senior Member
oOPs damn that was supposed to be a new thread...damn sorry guys
Old 11-19-2005, 06:06 PM   #36
llyden
AINOKEA
llyden's Avatar
llyden is an unknown quantity on c-rsx
So, on the Megan test pipe...insert the primary o2 sensor into the resonator inlet correct? And then aplly the defoulers to the secondary inlet, which is the one on the piping correct?
llyden is offline   Reply With Quote
Old 12-06-2005, 05:16 PM   #37
RSXESS
Newbie
RSXESS's Avatar
RSXESS is an unknown quantity on c-rsx
okey, i went to the p[art store and get defouler, part no 420002, but i saw u guys using 420009 are they the same? and is it okey if i sue 420002 one?
RSXESS is offline   Reply With Quote
Old 12-08-2005, 09:21 PM   #38
BryanP
use the one listed on the DIY. diff part numbers = diff models
Old 12-10-2005, 03:16 PM   #39
PSI
PSI is an unknown quantity on c-rsx
pull the fuse under the hood
PSI is offline   Reply With Quote
Old 12-12-2005, 10:46 PM   #40
rsx_2k5
rsx_2k5 is an unknown quantity on c-rsx
awesome guys... Im going to do mine sometime this week. great post!
rsx_2k5 is offline   Reply With Quote
Old 12-12-2005, 10:48 PM   #41
rsx_2k5
Hey I hear this all the time. do you have a picture of that Fuse or be more specific where to find it? again, thanks.
Old 12-15-2005, 10:19 PM   #42
BryanP
the schematic should be in the fuse box.
Old 12-15-2005, 10:20 PM   #43
BryanP
the secondary goes onto the one closest to the rear = on the resonator. the one closest to the header is the bung for the primary sensor.
Old 12-19-2005, 01:43 PM   #44
PaPaBear
formerly known as Ratio
PaPaBear's Avatar
PaPaBear is an unknown quantity on c-rsx
Great post. Very helpful. Thanks
2005 NBP RSX Type S
Peep it....
http://www.cardomain.com/ride/2504178
PaPaBear is offline   Reply With Quote
Old 01-10-2006, 02:24 PM   #45
Kingsta18
Kingsta18 is an unknown quantity on c-rsx
Will This work on any car? Ex 96 Turbo Talon AWD?
Kingsta18 is offline   Reply With Quote
Old 01-12-2006, 08:59 PM   #46
Kingsta18
Bump for help guys?
Old 01-16-2006, 02:01 AM   #47
RichthePoser
RichthePoser is an unknown quantity on c-rsx
Works on WRX's too... Perrin Performance's manual fix.
Rich
RichthePoser is offline   Reply With Quote
Old 01-17-2006, 09:09 PM   #48
EnJaNir
EnJaNir is an unknown quantity on c-rsx
Not to be an jerk but you blantantly ripped off my DIY sticky from ephatch without giving any credit what so ever.
Normally I wouldn't care, since I did the diy and posted it for others, however individuals on other forums at least had enough courtesy to contact me personally first and ask if it was ok to put up and use my information and pictures. I'm glad people found my work helpful, but I don't care for other people taking credit for someone else's work.
I first linked members here to my sticky on ephatch in the following thread post number 54
http://forums.clubrsx.com/showthread...=197788&page=3
EnJaNir is offline   Reply With Quote
Old 01-17-2006, 09:26 PM   #49
arz
14.2@95 N/A a3
arz's Avatar
arz is an unknown quantity on c-rsx
arz is offline   Reply With Quote
Old 01-17-2006, 09:26 PM   #50
Kingsta18
Not to start anything either but I'm sure you are not the original idealist. Many companies have made the exact same thing.
On the other hand, you may have been the first one to use the Motormite part. It is one thing if he used your pictures but if those are his authentic pics than he didn't steal anything. He made it applicable for the RSX.
Since you have done it though, can you tell me if it will work on any vehicle turbo or non-turbo?
Thanks (no offense intended)
Reply
Bookmarks
mechanical , pics , sensor , simulator
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
