***List of Wheel Sizes, Offsets, and Tire Sizes for RSX. - Page 55 - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Wheels & Tires
Reply
Thread Tools
Old 07-04-2014, 05:52 PM   #1351
K20ghost
Member
K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx K20ghost is a jewel in the rough of c-rsx
dang so i would need to get a rear camber kit then? i was thinking 17x9 +35 with 235/40/17's then, maybe even 245's.
so basically any 17x9 will rub..
"Victory needs no explanation; defeat allows none."
"Success is commemorated, failure merely remembered."
K20ghost is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-04-2014, 05:58 PM   #1352
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
Yeah you'll need a rear camber kit. With a 245 or larger I almost guarantee you'll have to roll your rear fenders. 235 maybe not but with how much the shocks travel you should roll them to be safe. Here's a bad photo of my setup, 17x9 +35 255/40 -2F/-1R camber
dan_nguyen is offline   Reply With Quote
Old 07-04-2014, 06:02 PM   #1353
K20ghost
Member
thanks alot for the info has been very very helpful. if i go 17x8+35 will i have the same potential rubbing/camber issue?
Old 07-04-2014, 06:05 PM   #1354
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
My friend ran 17x8.5 +30 225/45 (should have went with a 40 profile), no rear camber kit, dropped on springs, so about 1.5-2 finger gap all around and had no issues with rubbing. I think depending on the tire (some run wider than others, some narrower) he probably could've done a 235/40 without rolling the rears. He was probably at -2 to -2.5 rear camber, just because when you lower the car you get negative camber as a result of the suspension geometry
My two cents, and take it as you will, just roll the rear and get a camber kit, even if you run a smaller size it allows the flexibility of upgrading to a bigger setup later on.
Old 07-04-2014, 06:06 PM   #1355
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
Both front and rear goes negative when the shock compresses so your fine even if you run a little bit of camber.
Dan prob needs a bit more rear camber. I used to run -1.5 and it didnt wear out the tires or anything.
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Old 07-04-2014, 06:10 PM   #1356
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
When I first lowered the car I didn't have a rear camber kit and I was at -3 rear camber lol. I still have those tires, the toe was always in spec so I didn't have any major wear issues. Next alignment I'll add a little bit more negative camber though, probably -2.5F/1.25R, perhaps a little toe in on the rear axle
Old 07-04-2014, 06:48 PM   #1357
bluej511
Name's Vic
bluej511's Avatar
Rear toe should be 0 if you know how to drive. Toeing in the rear makes the car understeer. The front should be toed out for track racing. Rear toe is set in a bit to make the car understeer but it sucks
Old 07-04-2014, 09:28 PM   #1358
nutsfu
Member
nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx nutsfu is a jewel in the rough of c-rsx
I am trying to decide between two different sets of wheels but I need some advice on fitment. I have an 06 with A-spec suspension. I am considering one set that is 18x9 +35 and another that is 18x9 +26. The winning set will be paired with either 235/35/R18 or 245/35/R18 (no stretched tires).
I really want to avoid adding camber.
Will I be able to fit them with no rubbing if I roll and/or pull the fenders (and don't add camber)?
I am leaning heavily towards the 18x9 +26 (VS-XX)
nutsfu is offline   Reply With Quote
Old 07-04-2014, 11:36 PM   #1359
K20ghost
Member
After much looking around looks like im getting some 17x8.25 +35. Should hopefully be fine on those with 225 or 235/40/17's. Hopefully no rubbing lol
Old 07-04-2014, 11:39 PM   #1360
Moises's_Rsx
DC5 Gang***ger
Moises's_Rsx's Avatar
Moises's_Rsx No words can describe Moises's_Rsx No words can describe
Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe Moises's_Rsx No words can describe
225/45/17 & 235/40/17 goes well with 17x8-8.5
PSN: MoisesTazzGaming
2006 Custom Milano Red Base Power
|ThePremSociety|
Originally Posted by RecarosCostTooMuch View Post
Vote DJ for most disappointing build in recent CRSX history.
Moises's_Rsx is offline   Reply With Quote
Old 07-05-2014, 12:50 AM   #1361
salsa4u
Member
salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx salsa4u is a jewel in the rough of c-rsx
18x8.75 +20 offset flush and no wheel gap
Anyone have an answer to this??????
salsa4u is offline   Reply With Quote
Old 07-05-2014, 02:14 AM   #1362
Waleed786
Senior Member
Waleed786's Avatar
Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx Waleed786 is a jewel in the rough of c-rsx
9" +35 if you didn't learn anything from the first page. +26 will require more camber
Sent from AutoGuide.com App
Waleed786 is offline   Reply With Quote
Old 07-05-2014, 08:22 AM   #1363
salsa4u
Member
235/35/R18 or 245/35/R18 (no stretched tires)?????
Need tire size to be flushed with A-Spec suspension:
235/35/R18 or 245/35/R18 or 235/40/18 or 235/45/18 or 240/40/18 or 245/40/18 or 245/46/18 (NO stretched tires) - which one will be close to flush?????
Old 07-05-2014, 09:32 AM   #1364
salsa4u
Member
Aspec drop with xxr 527 18x8.75
Also trying to get no wheel gap, thanks
Old 07-05-2014, 08:37 PM   #1365
Waleed786
Senior Member
Waleed786's Avatar
Dont understand what the heck you're saying. How can a tire be flush with a strut/shock?
Wheel gap depends on your suspension.
Also, do some reading on what the numbers in tire sizes mean
Old 07-05-2014, 08:39 PM   #1366
bluej511
Name's Vic
bluej511's Avatar
He means flush with the wheel. All someone has to do is check what size tire for a 9in wheel.
Old 07-05-2014, 08:47 PM   #1367
Moises's_Rsx
DC5 Gang***ger
i mean aspec suspension is not that low, just one inch right ?. so i think maybe a 245/40/18 or you can do 255/35/18
|ThePremSociety|
Old 07-08-2014, 10:54 AM   #1368
FerociouS
Senior Member
FerociouS's Avatar
FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx FerociouS is a jewel in the rough of c-rsx
Would I need to run spacers on 17x9 +40 wheels all around?
FerociouS is offline   Reply With Quote
Old 07-08-2014, 12:03 PM   #1369
IronGumby
05 Type S RH Reflash LSD
IronGumby's Avatar
IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx IronGumby is a jewel in the rough of c-rsx
I think you need +35 at minimum, so 5mm spacers. People usually go with +35 or +30
IronGumby is offline   Reply With Quote
Old 07-08-2014, 12:05 PM   #1370
Moises's_Rsx
DC5 Gang***ger
Im running 17x9 +38 with no spacers at all, no problems
|ThePremSociety|
Old 07-08-2014, 12:51 PM   #1371
FerociouS
Senior Member
FerociouS's Avatar
How low are you? I might need 5 mm spacers just to make sure
Old 07-08-2014, 01:37 PM   #1372
Moises's_Rsx
DC5 Gang***ger
Im 2" low
|ThePremSociety|
Old 08-23-2014, 11:28 AM   #1373
dc5_dy
is John
dc5_dy's Avatar
dc5_dy is an unknown quantity on c-rsx
17x8 +45 on 245/40 tires. will it rub? I'm on A-SPEC suspension.
dc5_dy is offline   Reply With Quote
Old 08-23-2014, 04:04 PM   #1374
Moises's_Rsx
DC5 Gang***ger
Not at all
Edit: trailing arm maybe because size and offset too high
|ThePremSociety|
Old 08-23-2014, 06:38 PM   #1375
bluej511
Name's Vic
bluej511's Avatar
For an 8in wheel that might be a bit too inside as far as offset goes. Might rub on the rear control arm or inner fender wheels. Search online theres a way to measure where your wheel will sit with offset.
8in with that offest might be 5in inwards from the hub or 6in or wtv it is.
Reply
Bookmarks
list , offsets , rsx , sizes , tire , wheel
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
