Wheres the DIY guide to flush the brake fluid? - Page 2 - Club RSX Message Board
Reply
Thread Tools
Old 09-05-2008, 06:02 PM   #26
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
that's for sure. the brake lines going from the master cylinder into and then out of the ABS unit would also be a dead give-away. each caliper has a small fluid reservoir inside the ABS unit.
'06 black type-s.
rensoyka is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-05-2008, 06:27 PM   #27
drumnatural
I can drive up your rsx
drumnatural's Avatar
drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though
As per the helms manual it's LF, RF, RR, LR. I did it myself on my car and another with no issues.
You treat your car like your girlfriend...Tender loving care along with giving her some WOT
[SIGPIC][/SIGPIC]
drumnatural is offline   Reply With Quote
Old 09-06-2008, 04:24 PM   #28
wketchin
Seņior Memberish
wketchin's Avatar
wketchin has a clean start wketchin has a clean start wketchin has a clean start wketchin has a clean start
How would you go about switching to synthetic brake fluid? would it be bad to mix the two during the bleed process? i just have a few bottles of synthetic brake fluid laying around, and i was curious.
wketchin is offline   Reply With Quote
Old 09-06-2008, 04:39 PM   #29
cryptic
Former 240sx GURU
cryptic's Avatar
cryptic is an unknown quantity on c-rsx
your suppose to bleed furthest back.. for switching to synthetic i would drain the system, remove the BMC, clean it and do a bench bleed on the BMC then do a typical bleed to the rest of the sytem.. just dont reuse the fluid.
so
1) remove the fluid by opening RR and drain all fuid, repeat with LR, LF and RF untill complete
2) remove the stock brake lines on BMC and remove BMC, clean with water and degreaser.. let dry 100%.
3. reinstall BMC and attach new Brake line to the BMC that are just long enough to go up and nto the resiviour below the full mark..
4) fill with fluid and pump the brakes so it recirulates the air out of the new fluid..
when all the air is gone attach the stock brake line back to the BMC and bleed as per helm..
cryptic is offline   Reply With Quote
Old 09-06-2008, 04:53 PM   #30
wketchin
Seņior Memberish
wketchin's Avatar
hm. i might just stick to regular dot
Old 09-07-2008, 02:12 AM   #31
platinumrsx
Member
platinumrsx's Avatar
platinumrsx is an unknown quantity on c-rsx
ok never bleed brakes before, i have the helms manual and i've been doing reading but i just want to make sure im doing the right thing before i do it here. so what i'm going to do is bleed a wheel (i'm not gonna specify which wheel due to all the arguments on that here) then fill the reservoir, then bleed another wheel followed by the reservoir again and repeat until complete? Please no flaming i just want to make sure i'm right. these are BRAKES we're talking about here.
Installed:Injen CAI, Skunk2 IM, CRSX SS RH, Greddy RS Exhaust, Tein Street Coilovers, SPC Camber Kit, Sparco Assetto Gara wheels, Continental ExtremeContact DWS tires, PowerSlot Slotted Rotors, Hawk HPS brake pads, Buddy Club Racing Spec Shift Kit, ESMM
Awaiting Install: K-PRO
platinumrsx is offline   Reply With Quote
Old 09-07-2008, 02:44 AM   #32
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
Make sure its full to begin with, have someone pump the brakes then hold it, while there holding you crack open the bleeder just a bit and let fluid out, tell whoever is pumping the pedal not to let it go to the floor and do not, i repeat DO NOT let the pedal come back up until you tell him to do so. Check after every corner you bleed, do each corner 3-4 times then check the master.
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Old 09-19-2008, 08:16 PM   #33
aso
aso is an unknown quantity on c-rsx
just follow the helm LF, RF, RR, LR....im certified Acura tech...
aso is offline   Reply With Quote
Old 10-08-2008, 12:34 AM   #34
aso
or buy this stuff work great!...http://cgi.ebay.com/ebaymotors/Mityv...mZ170269954268
Old 10-08-2008, 08:09 AM   #35
Redline10000
Thats my shorty
Redline10000's Avatar
Redline10000 is an unknown quantity on c-rsx
so
What happens if you don't do that and just bleed it by flushing out the old one with the new stuff. Ie the motul synthetic that says it safe for dot 3 and 4 systems
04' RSX base - Sold
Super Black 350z
Mods: RBC, Type-s tb, CC stage 4, GT2871r, 3" Kteller exhaust, HKS Carbon TI muffler, greddy fmic and 75a motor mounts
303whp 268lb/tq @ 14.5psi D-rob tuned
Redline10000 is offline   Reply With Quote
Old 10-11-2008, 12:57 PM   #36
XzYBiT
Custom JDM Badges Maker
XzYBiT's Avatar
XzYBiT is an unknown quantity on c-rsx
Where can I get the clear plastic hose to do this? Walmart? Kragen's?
Custom JDM Badges For Sale - http://forums.clubrsx.com/showthread.php?t=616674
Last known pics of my ABP...
http://forums.clubrsx.com/showthread.php?t=641166
XzYBiT is offline   Reply With Quote
Old 10-11-2008, 02:02 PM   #37
mxlu
HONDA PACT
mxlu's Avatar
mxlu is an unknown quantity on c-rsx
go to pet store and get a hose from the fish area, or you can go to your local hardware store and go in the plumbing section. for the bottle, just use a regular water bottle.
mxlu is offline   Reply With Quote
Old 10-16-2008, 08:04 PM   #38
aso
Anybody know where to get a T wrench (Honda Part 07HAA-SG00101) for bleeding the high pressure fluid from the ABS system?
Old 11-08-2008, 03:55 AM   #39
XzYBiT
XzYBiT's Avatar
bleeder screw is the one with the rubber cap right?
Old 11-23-2008, 01:43 AM   #40
HurriSkiest
2night I wear a small hat
HurriSkiest's Avatar
HurriSkiest is a name not to mess with
HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with HurriSkiest is a name not to mess with
yup
Fuck A/C Windows Down Crew #10
735whp/470tq @ 27psi on e55-60
684whp/480tq @ 32psi on Q16
PPG BW TS 8374 Tuned by Jeff Evans @ Locash Racing
HurriSkiest is offline   Reply With Quote
Old 03-29-2009, 08:52 PM   #41
pacheco dc5
Coming soon!
pacheco dc5's Avatar
pacheco dc5 is an unknown quantity on c-rsx
I relaced my calipers and rotors, i have started to bled the system and have not got any pressure. I tried many methods. I do get this lil air noise from the abs pump so IDK if it got messed up or not. I was told to get a new abs pump so i got a new one and nothing. I have not moved the car as I gave up I tried it all all ready. DOes it matter if the car is on to turn on the abs or what am I doing wrong, I have a thread about this so IF you can help i would apricaite it thanks.
pacheco dc5 is offline   Reply With Quote
Old 03-29-2009, 08:56 PM   #42
bluej511
Name's Vic
bluej511's Avatar
the car shouldnt be on, you might be screwed since you put an abs pump on the pump and abs system now might have air in it so.
Old 03-29-2009, 09:27 PM   #43
pacheco dc5
Coming soon!
idk what u said, i put an abs pump on the pump? how do i get the air out of the abs pump?
Old 03-29-2009, 09:36 PM   #44
upshotunity
Get of My Nuts
upshotunity's Avatar
upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx upshotunity is a jewel in the rough of c-rsx
Originally Posted by Blown_Type_S View Post
That's the standard way of bleeding the brakes, but the above mentioned procedure is straight from the Helm. Maybe it has to do with ABS. I heard of people doing it both ways and workin fine.
Yes both way do work fine.
I prefer farthest from mc first, thats the way its been done since before i was born, so i tend to lean toward that.
And not too sure how to get air out of the abs system. sorry!
upshotunity is offline   Reply With Quote
Old 04-28-2009, 09:15 AM   #45
RSX-Served
Member
RSX-Served's Avatar
RSX-Served is an unknown quantity on c-rsx
Thread bump
My brake fluid is really dirty and needs to be flushed. I'm going to try to flush it this weekend. From what I gathered in this thread, I want to make sure I have this procedure correct.
-Pump dirty fluid out of reservoir until the Min line is reached
-Fill reservoir to Max line with new brake fluid
-Bleed brakes at each corner (LF, RF, LR, RR)
-Continue to fill reservoir with new fluid to Max line after bleeding each corner
Is that it?
2012 BWP TSX Special Edition
RSX-Served is offline   Reply With Quote
Old 04-28-2009, 05:09 PM   #46
upshotunity
Get of My Nuts
Originally Posted by RSX-Served View Post
Thread bump
Is that it?
Correct, but i would reccomend that you start furthest from the reservoir. RR,LR,RF,LF
Old 04-29-2009, 10:24 AM   #47
RSX-Served
Member
RSX-Served's Avatar
Thanks man
How many times should I bleed each corner?
Old 04-29-2009, 10:26 AM   #48
upshotunity
Get of My Nuts
until you get clear fluid from them. Do it to each corner until it is clear.
Old 05-31-2009, 08:48 PM   #49
Matrix86
WE GOT DEBRIS!
Matrix86's Avatar
Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though Matrix86 is cool, not as cool as some though
So would a speed bleeder be worth getting?
[SIGPIC][/SIGPIC]
06 VBP type-s Š| Ingalls TD | Greddy SP2 | DCRH | PureVision Hids | Ingalls front/rear camber kit | Fujita F5 CAI | Comptech SS | HONDATA | WedsSports Sa-70 | Progress Rear Sway | Buddy Club N+ | JDM Visors | Dunlop Direzza Z1 Star Spec | Stop Tech Stage One
Matrix86 is offline   Reply With Quote
Old 05-31-2009, 11:03 PM   #50
upshotunity
Get of My Nuts
Oh yeah! Eliminates need for second person.
Reply
Bookmarks
brake , diy , fluid , flush , guide
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright Š 2001-2012, Club RSX, Inc. All rights reserved worldwide.
