Exhaust diameter - Page 2 - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Supercharging RSX
Reply
Thread Tools
Old 10-29-2008, 01:34 PM   #26
tanabersx
Blown!!
tanabersx's Avatar
tanabersx has been a little shit in the past
I'm running JRSC@9psi, DCRH & skunk2 70mm (2.75") megapower, works great, gain 7hp from my Tanabe 2.25" exhaust. And know a couple of blown guys runnin 3" custom exhausts with no problems. They say that's how they got the max hp's, runnin 3" but I'm skeptical about it so just went with 2.75".
Before you attempt to beat the odds, make sure you can survive the odds beating you...
tanabersx is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-28-2008, 11:00 AM   #27
benjoewoo
Member
benjoewoo is an unknown quantity on c-rsx
Erm not sure if I'm actually contributing anything and I'm sure loza or some other vets of the forum can probably say something more detailed with better descriptions of the physics, but my 2 cents would be the quote from Conrad, at the time quoting WDsonny in the description for the JRSC FAQ. I'm kinda lazy so I'll paraphrase: every 100hp requires 1" +. With that in mind, in theory wouldn't a 3" offer less restriction, resulting in more HP? I'm not saying it'll be all that noticeable and it may be a difference negligible enough that weather conditions or an uncontrollable variable may negate. All things equal, however, in theory it'd be better.
I remember Raz posted a long thread detailing his raz exhaust and he explained something contrary to that thought. Again paraphrasing I think he said that unlike NA S/C peeps can deal with a bit of blockage because S/C set ups don't need to scavenge that HP. His focus was albeit more focused on his header and ultimately noise reduction, but his point seems applicable. On a side note I kinda wanna ask why he didn't just get a huge ass resonator to negate sound instead of going with his exhaust? I thought you could control sound based on things like the resonator size and all that.
Nothing is really my thinking, just citing what other contributing board members post.
benjoewoo is offline   Reply With Quote
Old 11-28-2008, 11:27 AM   #28
2010 admin
Guest
Posts: n/a
I have a theory about this: Bigger diameter tubes are more critical to N-A applications than Roots-blown ones and I think that if you have a street-driven car, then there may be such thing as "too big".
The reason for that is one that we often overlook: While a 3" (or whatever diameter...) may be optimal for peak power, you and I are only in boost maybe 20% of the time. And for the remaining 80% of the time, your car is basically and N-A RSX and needs both exhaust scavenging and velocity.
The prime example of this is Wayne's car. His shorty header and 3" setup is great for WOT, but low-speed performance and fuel economy are inferior to the car with, say, a more vanilla header and exhaust.
This is the part I will never understand about many of us here: We tend to be sheep and blindly follow whatever the conventional wisdom about this or that. I am as guilty of that as anyone and have wasted several thousand dollars over the last four years buying headers or cat-backs that "everyone else" said would be great.
My point is that you need to keep things in context. If you have a strip-only car, then by all means, get that 3" exhaust and you will make plenty of power.
If you have a daily driver, ask yourself how many times a day you are boosting to max pressure versus the rest of the percentage that your car is in vacuum. I am typing from Starbucks right now and can tell you that in the 15 or so miles it took me to get here on the highway, I was in vacuum most of the time and what I would consider "light boost" the rest. Could a 3" straight-through exhaust make me a bit more power than the 2.5" setup I have now? Sure. Would I see any benefit from a 3" exhaust in my daily routine? No.
I am just saying that a max-power setup may not be what you want and you need to realize that what one guy says is the "only way to go" might actually hinder your performance. Just my opinions and best of luck to you all.
Old 11-28-2008, 02:05 PM   #29
Agent Smith
It is inevitable
Agent Smith's Avatar
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more Agent Smith is a super person....that needs to get out more
^ i agree with this... the smaller the diameter the higher the velocity can stay at a lower rpm (of course can work as a restriction at higher rpm/higher power.) not only is it due to the scavenging effect of the low pressure (back) of the exhaust pulse attracting the high pressure side (front) of the following exhaust pulse... but turbulence at merges play a role as well. exhaust pulse really aren't just straight pulses moving through the exhaust, but at merges there is turbulence where part of the exhaust pulse makes a slight circular motion due to a vacuum effect right after the merge. this helps increase the speed of the pulses, and one of the contributing factors to a smaller diameter not hindering bottom end.
Originally Posted by waltMA70 View Post
The thing I like best about camaros is that they come new from the factory smelling like winston cigarettes.
S/C Crew Member #7 CRSX Zombie Eradication Team Member #10|Anime Crew 三番
http://i2.photobucket.com/albums/y41/Xinu38/Untitled-2_zpsceedtb4z.gif
Agent Smith is offline   Reply With Quote
Old 11-29-2011, 01:18 PM   #30
Jgm99
New Member
Jgm99's Avatar
Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx Jgm99 is a jewel in the rough of c-rsx
^understood .. but what about a e-cut out .. header>2.5 test pipe>e-cut out .. the problem is how would this effect the superchargers performance or will it enhance it ,,,or is a full exhaust needed to keep enough pressure
Jgm99 is offline   Reply With Quote
Old 11-29-2011, 01:23 PM   #31
stwatson
Meth Blow Speed = my life
stwatson's Avatar
stwatson gets around and is known
stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known stwatson gets around and is known
5" exhaust is needed.
AFTERCOOLED AND WAITING FOR 12'S
Supercharged, Aftercooled, and Alcohol Injected!
348whp/240wtq
13.0 @ 113mph (Traction is not my friend)
stwatson is offline   Reply With Quote
Old 11-29-2011, 01:23 PM   #32
2010 admin
Guest
Posts: n/a
If the exhaust system is reasonably unrestrictive, then there is not a lot of point to the e-cutout.
Old 11-29-2011, 03:35 PM   #33
rsamd
Member
rsamd is an unknown quantity on c-rsx
a guy in the uk forum just changed from 70mm skunk2 to a custom 3'' and gained 18hp. mase tuned it both times on the same rollers. 8psi i think.
http://www.civictype-r.co.uk/forum/v...?f=59&t=246186
JRSC
rsamd is offline   Reply With Quote
Old 11-29-2011, 06:19 PM   #34
Agent Smith
It is inevitable
people shouldn't bump threads that show i used to try to help people
Old 11-29-2011, 06:38 PM   #35
03ssmrsx
Blown
03ssmrsx's Avatar
03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx 03ssmrsx is a jewel in the rough of c-rsx
Junk2
03ssmrsx is offline   Reply With Quote
Old 11-29-2011, 08:51 PM   #36
2010 admin
Guest
Posts: n/a
20hp seems like a lot for just another 5mm of exhaust diameter.
Old 11-29-2011, 11:53 PM   #37
Dickbowlmidz
Still here
Dickbowlmidz's Avatar
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
InFamous / ThePremSociety / Hellafunctional
Dickbowlmidz is offline   Reply With Quote
Old 11-30-2011, 06:39 AM   #38
rsamd
Member
don't know if the skunk2 is a true 70mm ID exhaust may be 66mm ID, if a true 76mm ID exhaust was fitted now its like 10mm difference which is a bit.
JRSC
Old 11-30-2011, 08:10 AM   #39
hondaluver
Bar'd TWICE
hondaluver's Avatar
hondaluver is an unknown quantity on c-rsx
ugh
01 SSM em2 built turbo k24 bar'd twice. Old 10:1 NA tune...240.7 hp and 190.9 tq. C38-91 Rotrex build FS Thread
09 Toyota Pruis Full Loaded(Navi and leather) rolling @48.6mpg
hondaluver is offline   Reply With Quote
Reply
Bookmarks
diameter , exhaust
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
