D.I.Y Electronic Power Steering - Page 3 - Club RSX Message Board
Reply
Thread Tools
Old 06-01-2012, 04:07 PM   #51
2010 admin
Guest
Posts: n/a
You can't "not have" the BCU. It is required.
Sponsored Links
Advertisement
Old 06-01-2012, 11:09 PM   #52
'02WhiteTypeS
0 to 1320...
'02WhiteTypeS's Avatar
'02WhiteTypeS is an unknown quantity on c-rsx
so what will happen if i just ran power to the pump without the bcu?
WWW.TEAMXXXRACING.COM
'02 RSX-S Turbo :: 9.96 @ 155
Facebook | YouTube
'02WhiteTypeS is offline   Reply With Quote
Old 06-02-2012, 12:55 AM   #53
futuremonster
Master Member
futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx futuremonster is a jewel in the rough of c-rsx
futuremonster is offline   Reply With Quote
Old 06-02-2012, 01:03 AM   #54
ycgold123
Master Member
ycgold123's Avatar
ycgold123 has been a little shit in the past
you need the bcu. it knows what your rps are, speed, and so fort
ycgold123 is offline   Reply With Quote
Old 06-02-2012, 01:06 AM   #55
futuremonster
Master Member
that does no explain anything
Old 06-02-2012, 04:24 AM   #56
ycgold123
Master Member
ycgold123's Avatar
it regulates the amount of power needed to send to the system based on the factors I mentioned earlier. Without it, it might be over powered or underpowered.
Why dont you try it.
Old 06-27-2012, 11:36 PM   #57
SHOGUNN
Master Member
SHOGUNN's Avatar
SHOGUNN has been a little shit in the past
uhhhh....so I just installed my EPS rack..upon first start up, the car ran for about 5 seconds then the steering wheel began shacking uncontrollably....scared the shit out of me. All the wire connections were made using this DIY...anything off the top of your head??
Mag Tuned
SHOGUNN is offline   Reply With Quote
Old 06-27-2012, 11:38 PM   #58
Ukinayo_DC5
SOFAKINGDOM
Ukinayo_DC5's Avatar
Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx Ukinayo_DC5 is a jewel in the rough of c-rsx
did the car die? i tried wiring up how spaz did but it didnt work for me, im still stuck and thinking my BCU went out..
Ukinayo_DC5 is offline   Reply With Quote
Old 06-27-2012, 11:41 PM   #59
SHOGUNN
Master Member
SHOGUNN's Avatar
no...car was running just fine but the shaking scared the shit out of me so I just shut the car off.... My BCU is brand new!
Mag Tuned
Old 06-27-2012, 11:46 PM   #60
Ukinayo_DC5
SOFAKINGDOM
how much did you get your bcu for? and how do you have it wired up to the ecu? A18,E26,E9?
Old 06-27-2012, 11:47 PM   #61
futuremonster
Master Member
Check your wiring again. I did check it 2 time and i didnt find out i had bad wiring until i check the the third time
Old 06-27-2012, 11:50 PM   #62
SHOGUNN
Master Member
SHOGUNN's Avatar
Ukinayo...yeh man...Ill go see what i got along with the wire colors to see if its correct. I used the pin out found on the Hondata site...thats gotta be the issue i guess....
futuremonster...Ill check it
Mag Tuned
Old 06-27-2012, 11:53 PM   #63
Ukinayo_DC5
SOFAKINGDOM
when you had yours installed did you have Power steering right away when your car is on a dead stop?
Old 06-28-2012, 12:00 AM   #64
SHOGUNN
Master Member
SHOGUNN's Avatar
ok...heres what i got
BCU Side ....... ECU
Blue to Blue
Blue w/ white to White w/ green
Yellow to Black w/yellow
these were all the pins described in the pin out.
Mag Tuned
Old 06-28-2012, 12:22 AM   #65
SHOGUNN
Master Member
SHOGUNN's Avatar
what were the symptoms of your bad wiring???
Mag Tuned
Old 06-28-2012, 11:16 PM   #66
Ukinayo_DC5
SOFAKINGDOM
Blue to Blue
the blue w/white to white w/green??
what pin out is that on what ecu connector?
Old 06-28-2012, 11:22 PM   #67
futuremonster
Master Member
just was not working at all because i had the Yellow that goes to pin E9 IGN power (this is IGN to let the BCU know when engine is running)miss placed
Old 06-29-2012, 12:51 AM   #68
SHOGUNN
Master Member
SHOGUNN's Avatar
that is the wire that was on the pin per the pin out on the Hondata site...when looking at the connector from the wire side, the clip is supposted to be on top of the connector with respect to the pic?...just making sure because thats what i did and those were the wires i came up with...
this is the pin out diagram i used
http://www.hondata.com/help/kmanager/
Ok...well mine is doing something...just not what its supposed to do...
Mag Tuned
Old 06-29-2012, 01:07 AM   #69
futuremonster
Master Member
well if you need a bcu i have one pm me
Old 07-01-2012, 10:16 AM   #70
Ukinayo_DC5
SOFAKINGDOM
have you found your problem?
Old 07-01-2012, 07:09 PM   #71
SHOGUNN
Master Member
SHOGUNN's Avatar
not yet but I havnt really had time to troubleshoot it...My wiring is correct however so im not sure...
Mag Tuned
Old 07-01-2012, 10:04 PM   #72
SHOGUNN
Master Member
SHOGUNN's Avatar
so I tried it out....kinda...
I went over all the wires, good voltage and runs good up on jack stands and put it in gear and no issues....
I need to man up and put it on the ground and see what she does...I'll report back when I test it out...
Mag Tuned
Old 08-27-2012, 02:54 PM   #73
'02WhiteTypeS
0 to 1320...
Anyone have better pics of the how they powered the control module? this initial post says they "made a custom plug into the factory plug" -- what does that look like??
Facebook | YouTube
Old 08-27-2012, 02:59 PM   #74
2010 admin
Guest
Posts: n/a
I used a barrel fuse holder as the connector, then a 4GA cable to the battery for power.
Old 08-27-2012, 04:55 PM   #75
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
I have it all apart I will snap a picture... it's just a regular O-Ring connector and I cut the sides down to fit into the plug.
** Ivy is official SOLD **
Good buy RSX World.....
Type-Spaz is online now   Reply With Quote
Reply
Bookmarks
diy , electronic , power , steering
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
