Can valve cover breather hose stay open? - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Bolt-On Basics: RSX Type-S
Old 05-14-2019, 08:22 PM   #1
andezack
andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx andezack is a jewel in the rough of c-rsx
So I’m wondering if it’s ok to Put on one of those small filters or just run it open. The tubing won’t fit..I’m just wondering if doing this will harm my engine in someway
andezack is offline   Reply With Quote
Old 05-14-2019, 08:41 PM   #2
It won't cause damage necessarily, but there won't be clean air to cycle blowby gasses out of the crank case. It can contaminate the oil (by my understanding) but that's easily remedied by more frequent oil changes.
An oil catch can in conjunction with a breather filter would be the proper way of doing it. Personally, I don't see the point other than engine bay bling. The amount of oil sucked into the intake is so minimal that you won't notice any difference in power.
Old 05-15-2019, 01:05 PM   #3
Yeah by running that open, that PCV breather is gonna suck unfiltered air into your crankcase. Now sure, it's not being combusted in any way but it is coming in direct contact with your engine oil and everything outside the cylinders.
If you pay for synthetic oil and good oil filters and air filters and so on, to me it would make sense to add this additional protection to your engine so you're filtering it at all entry points.
Name:	PCV breather.PNG
For an RSX I think you need a 0.75" ID one, like:
https://www.kseriesparts.com/VIB-2164.html
https://www.kseriesparts.com/KN-62-1360.html
Old 05-15-2019, 03:22 PM   #4
andezack
Yea I ordered one of those..I may sound stupid but when I turned on the car it was pushing air out of the hole not sucking in
Old 05-16-2019, 12:42 PM   #5
I don't claim to fully understand it, but, the PCV loop is using that port as an intake during the conditions that incur blow-by, which is during WOT (at least). So during idle, yes, apparently the vacuum isn't present and thus there is air coming out, but that is not the path of the oil vapors (it's in through the port over by the alternator that runs to the intake manifold).
breather , cover , hose , open , stay , valve
AEM V2 Installation: Possible to use stock thermal hose and breather hose??? NewRSX02 Bolt-On Basics: RSX (Base) 2 01-15-2009 11:44 PM
Breather hose wont stay on nismo4life All Motor RSX 14 03-22-2008 02:07 PM
Valve cover breather water bypass hose. dan_wheeler All Motor RSX 6 05-30-2006 03:16 PM
