OBX vs PLM headers - Club RSX Message Board
Go Back   Club RSX Message Board > PERFORMANCE BASICS RSX > Bolt-On Basics: RSX Type-S
Old 11-14-2016, 04:47 AM   #1
albundy1
albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx albundy1 is a jewel in the rough of c-rsx
OBX vs PLM headers
like the title says which of these twos headers would you guys recommend? Is a PLM header really worth 100$ more than a obx header?
albundy1 is offline   Reply With Quote
Old 11-14-2016, 11:56 AM   #2
They *seem* to make more power, but it's marginal. For most intents and purposes, you'll be just as well off with the OBX, and possibly even more so, since many PLM headers leak and they always hang real low.
Honestly if I could do it over again, I would've gone with a solid one like Invidia (double the price though). Depends what you're looking to get out of it
edit: oh, shoot! OBX is solid? Dang, just do it then, lol
Old 11-14-2016, 02:00 PM   #3
AyeeDoniss
AyeeDoniss's Avatar
AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx AyeeDoniss is a jewel in the rough of c-rsx
My PLM header tuned gained me +24hp +20tq
Numbers before header - 190hp, 158tq
After header- 214hp , 178tq
Mods- k24a2, custom 3" intake, PLM header, custom 3" exhaust piping to Megan drift spec exhaust. Stock 25* VTC, RBB manifold
I really like this header the welds and fabrication are perfect and for the price you can't beat it. To fix the "leaking" issue, a vibrant gasket should be used. I have no leaks up until now and I had the header for almost 6 months with the test pipe.
AyeeDoniss is offline   Reply With Quote
Old 11-14-2016, 02:25 PM   #4
torresa009
torresa009's Avatar
torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx torresa009 is a jewel in the rough of c-rsx
the obx has a smaller diameter from the primaries up to the collector. box are also known to crack. 350 is not a lot for a decent RH.
torresa009 is offline   Reply With Quote
Old 11-15-2016, 02:41 PM   #5
albundy1
owned my RSX for about 3 years with stock power mods and i recently broke my cat due to low life problems lol so i figured its time time for a racing header but i have being considering a obx since haven't read anything negative about them
Old 11-16-2016, 06:50 AM   #6
CyborgGT
CyborgGT's Avatar
CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx CyborgGT is a jewel in the rough of c-rsx
^ The post above you is negative.
Project CB9 AeroR start-up: ////////// Slowly but surely...
2002 RSX b/a - daily
CyborgGT is offline   Reply With Quote
Old 11-16-2016, 07:01 PM   #7
albundy1
Which gasket from them? Can you give me a link to it?
Old 11-16-2016, 07:01 PM   #8
albundy1
Elaborate?
Old 11-16-2016, 08:55 PM   #9
CyborgGT
CyborgGT's Avatar
1. Having smaller diameter piping is usually a bad thing. Less air flow means less power. Why spend the money to gain nothing?
2. Being "known to crack" is a bad thing. Points to poor build quality. Why spend the money on something that's likely to fail on you before long, when what you've got is perfectly solid?
Simply replace your broken cat with standard exhaust pipe. Costs about $90 at an exhaust shop, and since the cat is actually worth something to a recycler, you'll be able to get some of that money back. If you want to gain power, don't get something that isn't an improvement over stock.
Old 11-17-2016, 02:45 AM   #10
torresa009
torresa009's Avatar
thats what i meant in my post. as far as price i was referring to the PLM only costing $350 now instead of 500 earlier in the year. the PLM is a huge step over stock system.i made 202 with exhaust and RH only on a basemap. after tuned and an RBC i was making 216.
theres a huge number of old discussion threads on the OBX RH.
Old 11-18-2016, 04:33 PM   #11
remyrounds
Site Sponsor
remyrounds's Avatar
remyrounds is an unknown quantity on c-rsx
I can only speak from my experiences and say this.
The PLM headers truly do make good power for the price. I made 220/160 with bolt-ons tuned, on a 05 RSX.
remyrounds is offline   Reply With Quote
Old 10-08-2019, 07:13 PM   #12
Dafirsdon
Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx Dafirsdon is a jewel in the rough of c-rsx
I know this is an old thread but here is a little new info for people looking at the obx header. Just got the obx v2 race header a couple weeks ago. Read mixed reviews but went with them anyway. So far, so good. Install and fitment are fine. Did not need to change my front swaybar or get o2 wire extensions. Did buy the defouler even though I have kpro. No CEL. Wrapped them in titanium heat wrap. That might be why I have heard no banging or noise from them hitting something. With that said, still running stock motor mounts also. Maybe I got lucky or not. I did have a couple issues. No gasket or hardware to attach to exhaust flange. For some reason obx didn't bore out the holes enough for the hardware to connect collector to the down pipe or supplied too big of bolts. Trip to the local hardware store cured that. Slight annoyance. Also the manifold gasket was sh#@! Just reused oem. No leaks. Fitment states bolts up to stock exhaust. I do not have a stock exhaust. Flanges matched up great but extra i.d. material in the down pipe flange opening is giving me some funny vaccuum like noise. Also no big deal. I will remove the down pipe and dremel the material out. I would buy these again.
Dafirsdon is offline   Reply With Quote
Old 10-11-2019, 12:24 PM   #13
Great input! Some people say you don't actually need upgraded motor mounts because the header collector has a donut gasket / bell connection but I don't know
Anyways, titanium heat wrap?! wow!
Good supplied hardware is hard to come by nowadays. 'Tis stupid.
Are you sure the vacuum sound isn't thee most desirable header scavenging sound?! I love that sound, like this: https://youtu.be/n60a_Sulm3c?t=27s
headers , obx , plm
