I have just a tiny bit of clearance between the pully and the pass. headlight. I shaved the healight tabs and there is still minimal clearance. Do I have to worry about it???
I had this problem in the beginning what it turn out to be was the belt was not properly installed..Once is was put the way it should of been no more problem.Ghost323F said:I have just a tiny bit of clearance between the pully and the pass. headlight. I shaved the healight tabs and there is still minimal clearance. Do I have to worry about it???
wdsonny said:If you followed the instructions then no. I would take off a bit more just in case.
I installed engine mounts aftermarket to solve that problem...Benefits are no movement of the engine and shift were alot better..Down side a little more vib's from the engine.Ghost323F said:Acura installed it. I was just lookin at some vids and it shouldnt as the engine rocks backwards instead of into the front. Thanx~!
Yea, and IMO with a supercharger they are mandatory.Ghost323F said:Yea I had the Ingalls TD, but I couldnt keep it due to the SC. I was looking at the Energy MM inserts that are sold here on CRSX. Has anyone installed these?
I dont have any yet. Will the stock MM work for now? Looks like there will be a couple of weeks before I can get them.Oside Jimc said:Yea, and IMO with a supercharger they are mandatory.
