Well all of you......ok well most of you already know that i bought archulls' car. But since i have owned the car i have made a few changes and I'm still making changes haha.
I had the car and wasnt self assured with the paint on it. Too many rock chips in the front, a few dings here and there, and scratched to hell. I worked in a body shop so it was basically free. I did all the bodywork on it. Just paid for materials.
I had decided to go E85 so i upgraded to some ID 1000cc injectors, which are soooo tiny compared to RC750's.
I do everything on this car maintenance wise and upgrade wise. I build the transmission when it breaks, breaks quite often too. On my 3rd one over a time frame of 3 years.
I do all my DIY's. I'm sure that's spaz approved:thumbsup:
Peakboost Turbo kit
T3/44 Sidemount stainless steel Turbo Manifold (Coated by HPC)
44mm Dumptube (Coated by HPC)
3' Stainless 2 pc downpipe w v-band (Coated by HPC)
Garrett GT3076 turbo (.82 AR, .60trim, S-cover)(Exhaust housing Coated by HPC)
Tial 44mm Wastegate
Tial 50mm Blow off valve
PWR 6' x 23.5' x 3' vertical flow intercooler core(total height is 12') (anodized black)
2.5' Aluminum chargepipe kit with PWR Silicon Couplers & t-bolt clamps (Piping powder coated black)
Steel braided oil/feed return lines
All installation hardware, gaskets, & heatwrap
K&N Intake filter
Goodies:
-Hondata Kpro EMS
-GM 3bar map sensor
-Mac boost control solenoid
-Peakboost Vac Block
-Billet battery tray
-Odyssey battery (model # PC680MJ)
-Innovative Motor Mounts
-CC stage 4 clutch
-Custom Geared Transmission
-Oil sandwich plate adapter
-hondata intake manifold gasket
-Open downpipe (custom fender exit or hood exit coming soon)
-NKG BKR9EIX plugs
-Walbro intank fuel pump
-Bosch 044 inline
-AEM fuel rail
-Aeromotive FPR
-I.D. 1000cc injectors
--8an stainless fuel feed lines & -6an return lines all with Earls & Russel fittings
-Aeromotive 10 micron inline fuel filter
-RBC intake manifold
-P2R RBC adapter
Suspension:
-Tein Flex Coilovers
-Ingals rear camber kit
-Ksport LCA's
-P2R lower tie bar
Wheels & Tires:
-Volk Racing CE28N (18x8.5' 40mm offset in flat black
-Nitto Invo tires (255/35ZR18) Front
-Nitto NT555 (225/40ZR18) in the rear
-Team Dynamics Racing Pro-Race 1 wheels (matte black in 15x7.5" 35mm offset) wrapped in M&H Race Master Slicks (24.5"X10"X15")
Other
-DC5 JDM Type-R Recaro seats
-Autometer Ultralite Full Sweep Electronic gauges (Oil Pressure & boost)
-AEM Eugo wideband (also wired into engine management for datalogging)
Exterior:
-Custom lambo paint job, Nero Pagaso metallic
-Shaved engine bay same color as the car
Saving for
-Albins gear set
-Cams
This is how the car looked when i got it.
Then the paint process began. I had a plastic bag blanket covering the engine.
Some of these pics are just of the 1st coat of metal glaze.
I deleted the rear emblem. CLEAN.
Then the final product right out of the paint booth
Everything ready to be buffed and assembled
Buffed and washed
OOOooooOoOOO
Peakboost Turbo kit
Tial 44mm Wastegate
K&N Intake filter
Goodies:
-Hondata Kpro EMS
-GM 3bar map sensor
-CC stage 4 clutch
-NKG BKR9EIX plugs
-Bosch 044 inline
-AEM fuel rail
-Aeromotive FPR
-P2R RBC adapter
Suspension:
-Ksport LCA's
-P2R lower tie bar
Wheels & Tires:
Other
Exterior:
Saving for
-Albins gear set
-Cams
Buffed and washed
OOOooooOoOOO
