06 Type S Spacer Question - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Wheels & Tires
Old 09-08-2018, 07:59 AM   #1
Remzo
Remzo's Avatar
Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx Remzo is a jewel in the rough of c-rsx
Finally upgraded to an Avid1 06 18x8, 114.3, 73.1, 225/40/18 - can't seem to find a straight answer on spacer measurement.
Can anyone help with a definitive answer and source?
Remzo
Remzo is offline   Reply With Quote
Old 09-08-2018, 01:07 PM   #2
ali626
ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx ali626 is a jewel in the rough of c-rsx
the hell is your offset
ali626 is offline   Reply With Quote
Old 09-08-2018, 04:10 PM   #3
Remzo
Remzo's Avatar
+42
Old 09-09-2018, 11:16 AM   #4
Remzo
Remzo's Avatar
no one can answer this? No wonder I can't find the information online anywhere.
Old 09-09-2018, 12:39 PM   #5
marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx marko16 is a jewel in the rough of c-rsx
Your question sucks, what spacer info do you want. Do want to be flush or what? Do you want a brand recommendation, do you need help measuring spacers? State what you want clearly and we'll measure up
Old 09-09-2018, 02:34 PM   #6
Remzo
Remzo's Avatar
Wow. Senior member with a reply like that huh. Sit and spin buddy.
Old 09-09-2018, 08:31 PM   #7
https://forums.clubrsx.com/showthread.php?t=368629
Old 09-09-2018, 08:41 PM   #8
Everything kind of depends on everything else. +32 works well up to a 9in rim. As you go wide, you may need to roll the fenders or get a narrower tire, or just run the suspension higher. Some run wider but may need spacers between the wheel and hub. You get too far out and then you can't lower it as much. All depends on the look you are going for. 45 is stock and the 42 is just a couple of mm farther out. You could add spacers if you wan't a flush look. There are rules for spacers as some come with studs and many will recomend longer studs instead of stud spacers. Look over the pics here and see what you like and usually someone has a similar set up and can offer a guide as to what you might need.
In a nutshell, there is something to accomplish the look you want.
Old 09-12-2018, 02:07 AM   #9
dopeyrsx
dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx dopeyrsx is a jewel in the rough of c-rsx
Why do you need spacers? Do you want a flush look or something?
dopeyrsx is offline   Reply With Quote
Old 09-12-2018, 01:39 PM   #10
BrutalB83
WILDCARD!
BrutalB83's Avatar
BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx BrutalB83 is a jewel in the rough of c-rsx
He's not wrong. You didn't tell us what you are actually trying to accomplish here.
BrutalB83 is offline   Reply With Quote
Old 09-12-2018, 02:25 PM   #11
G3min1
Curious Gooner
G3min1's Avatar
G3min1 is on a distinguished road G3min1 is on a distinguished road G3min1 is on a distinguished road
Remzo
Dude you never asked a question... how is anyone supposed to help when you didn't ask anything.
EDIT: "Can anyone help with a definitive answer and source?" Answer to what?
Originally Posted by krystar View Post
Turbo Pros: You get a BlowOff Valve PSHSHHHHHH
Cons: Your car can blow up
Supercharger Pros: You get that distinctive supercharger whine going down the street.
"Beating a Dead Horse Crew " Member #1
G3min1 is offline   Reply With Quote
Old 09-12-2018, 05:02 PM   #12
Originally Posted by bigwheel View Post
Good to see you back! If that doesn't answer the question that any of us seem too know? I don't know what will? I say stuff it in, If It's like throwing a hotdog down a hallway? Then you know....
Back? I was unaware that I ever left lol
question , spacer , type
