Window jamming - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Care RSX
Old 12-26-2018, 11:24 PM   #1
Neilaki
Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx Neilaki is a jewel in the rough of c-rsx
Window jamming
Hi. So my passenger side window starts to angle a bit & won't close completely unless I grab the top of the window & pull twards the rear of the car while rolling up? It seems to work fine when it's raining outside. Any ideas would be much appreciated!
Sent from my LM-Q710(FGN) using Tapatalk
Neilaki is offline   Reply With Quote
Old 12-27-2018, 10:15 PM   #2
TheRickster
TheRickster's Avatar
TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx TheRickster is a jewel in the rough of c-rsx
I have this same problem with my drivers side. I've taken the side off but can't really make sense of it because of the door inner panels and sheet metal being in the way.
I read some people have to replace the entire window and motor assembly because of a broken piece though... :\ But not sure if that's MY problem or not.
02 RSX Type-S
09 Pontiac G6 v6
TheRickster is offline   Reply With Quote
Old 12-27-2018, 10:58 PM   #3
Neilaki
Yeah I think I read that somewhere as well. Like a broken tab or somthing? I also remember someone had a way of fixing it without replacing things. It seems like greasing somthing up might work as it works when wet. *Hopefully someone chimes in.
Old 12-27-2018, 11:23 PM   #4
TheRickster
Yeah, not sure if that's what's wrong with mine or not. I have had some luck cleaning the side channels where it slides and lubricating everything, but it's only lasted for a few days at most if that.
Also if you don't hold the window, or someone else doesn't know about it (like if you have a shop work on the car) they will have to remove the entire door panel to get the glass back on it's track. So make sure you're always vigil about it and also leave a sticky note on the gauges/wheel so people don't roll it down or roll it up if it's already down.
02 RSX Type-S
09 Pontiac G6 v6
Old 12-28-2018, 12:01 AM   #5
Neilaki
Ok, I think these shed some light! Watch the youtube & then read the forum page.
Old 12-28-2018, 12:22 AM   #6
TheRickster
Yeah, I tried greasing up the rails but it didn't really help much. I'll try it again when it gets warmer out, I think I've only tried it with wd40.
02 RSX Type-S
09 Pontiac G6 v6
Old 12-28-2018, 12:33 AM   #7
Neilaki
I think at least with mine is it needs to be epoxyed at the corner base of the window. It was mentioned in the thread & the guy in the video did a poor job at it using JB Weld.
Old 12-28-2018, 12:44 AM   #8
TheRickster
Definitely update with some pics and what kind of epoxy you're using.
02 RSX Type-S
09 Pontiac G6 v6
Old 12-28-2018, 12:50 AM   #9
Neilaki
For Sure
jamming , window
