#701 |
Member
http://www.crutchfield.com/S-BjbH5Gd...g-Harness.html
After you get the Harness, Reset the HU Again. Been through this lol ![]() |
Sponsored Links | |||
Advertisement
#703 | |
Member
I also found miztahsparklez's method of bypassing the amp only for the speakers, so you still use it for the sub. BUT...doesn't that result in using already amplified signals (which drive the speakers) as inputs to the front amp, thus amplifying the signal to the sub twice (in HU and rear amp), resulting in too much bass, and potentially damaging the sub? It seems to me that the right way to do it would be to bypass the front amp, and run a new cable from the preamp sub output on the HU to the rear/sub amp. You'd have to rig up another harness for that. Right? Last edited by sparky.engr; 01-04-2016 at 02:11 AM.. Reason: better link text |
#704 |
New Member
bose amp bypass
i followed the diagram below but for some reason my front left speaker doesn't work. all the others do. i noticed that the front left speaker requires for you to splice the ban and Lt Grn together but i saw two browns and two Lt GRN's one with a gray dot on it.
#706 |
Member
I am also having issues with the front right speaker (driver's) speaker as no sound is coming from it. Are there any solutions to this as I see a couple people had this problem.
After work I will check the wiring based upon there being two BRN and two LT GRN wires to see if I used to correct ones. |
#708 | |
m0o0o0o000?
The side effect of amping the signal twice is that the bass is that much louder. Believe me, the little Bose sub thumped well on its way when it was wired this way. Will it blow eventually? Maybe... At that point it would be worth doing aftermarket. They make a harness that uses your low level signal and feeds it to the Bose amp. The result is the same poor sound that you had before. Sent from my iPhone using Tapatalk
MoooOoOooo... 2002 Acura RSX Type-S Desert Silver Metallic ![]() LOADS OF EXTRA PARTS FOR RSX! Interior, sways, header, etc! PM for details! FOR SALE: Tan interior items + audio stuff PM FOR INFO! |
#709 |
Senior Member
I hate to beat a dead horse but I'm going to be doing this in a few days and just want to make sure I have the correct procedure:
7 | RED | Audio unit - Right Rear (-) 14 | BLU/YEL | Right Rear Speaker (-) 9 | BLK | Audio unit - Left Rear (-) 13 | BLU/BLK | Left Rear Speaker (-) 15 | PNK | Right Rear Speaker (+) 20 | YEL | Audio Unit - Right Rear (+) 22 | WHT | Audio unit - Left Rear (+) 12 | BLU/ WHT | Left Rear Speaker (+) 21 | ORN | Audio unit - Right Front (+) 2 | GRN/YEL | Passenger's Door Speaker (+), Right weeter (+) 8 | GRN | Audio unit - Right Front (-) 1 | GRY/RED | Passenger's Door Speaker (-), Right tweeter (-) 23 | BLU | Audio unit - Left Front (+) 26 | GRN/BLK | Driver's Door Speaker (+), Left Tweeter (+) 10 | BRN | Audio unit - Left Front (-) 25 | LT GRN | Left Tweeter (-) drivers door speaker (-) Last edited by InZain08; 07-12-2017 at 03:24 PM.. |
#713 |
Member
adding to the longest thread ever.... I'm going to attempt to use the integration harness (first) to connect my HU (Alpine UTE-62BT) to everything else stock.
Questions: 1)If that produces noise then why can't I just unplug the RCAs and do the bypass? It looks like the 70-1725 harness just splices the existing speaker wires at the harness level. If i just unplug the RCAs, won't that effectively change the 70-1725 into a 70-1721? 2)If the bypass should need to occur, can I use RCAs on my stock sub to aquire HU control. Could I do this at the line input at the sub in the trunk (lgt-grn/grn-wht). Or would this not be a strong enough signal since it would normally get its signal from the amp? 3)If that method of signal is too weak... could I splice the ends of the RCA outputs from the HU into the chopped wires coming out of the under seat amp input lines (4+ and 4-)? It makes sense to me that this would create the perfect signal strength and give you complete sub control from the HU. TIA |
#714 | |
New Member
Stick to the 70-1721, just have to do remote amp turn on, RCA will lower vol because that's a low input
for a woofer use RCA out, if you're going aftermarket woofer Quote:
#715 |
Member
#716 |
New Member
Before I bypassed my stock amp, I used the Speaker wires into the harness, and maintained stock woofer (Bose amp filters signals automatically), Vol was low, so if you spice RCA into the factory amp, it will be an even lower signal caused by the RCA output being a lower one to begin with, that's just my personal experience.
#717 |
New Member
Old thread but found this when looking into this issue, going to order it and give it a shot
https://www.amazon.com/gp/product/B0...9K72U9P2&psc=1
Tap water builds character |
#718 | |
m0o0o0o000?
Sent from my MI MIX using Tapatalk
Bookmarks |
Tags |
amphere , bose , bypass |
Thread Tools | |
