Bought not built N/A K24 DC5 Integra Type R - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Member Show-Off RSX
Reply
Thread Tools
Old 12-29-2014, 02:33 AM   #1
Koopa Troopa
Master Member
Koopa Troopa's Avatar
Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx Koopa Troopa might be well recognized one day on c-rsx
I bought this car from a friend in Tokyo and these hard parking stats are a combination of what he sent me (he didn't give me much of a detailed parts list) and what I've found on the car.*
*Stuff with an asterisk is stuff I've added
Engine:
KMod Stage 3 N/A K24 (I'm not going to bother listing what the parts entail because that can be pulled from their site)
Dyno'd at 290whp/ 215 ft/lbs of torque on KMod's dyno
Stock PRB-1 head with K20Z1/ITR cams*
K24A1 block
12.5:1 compression 87.5mm Supertech pistons
K1 rods
K24A2 crank
Skunk 2 70mm throttle body
RBC intake manifold
Injen Polished Mega Ram Intake
ASP big tube header
Greddy 70mm cat
BluePrint oil pan baffle
Toda oil pan*
K-Tuned upper coolant housing*
Hybrid Racing chain tensioner back exhaust
Hondata K-Pro
Combination of two window weld filled engine mounts, one Hasport 70A, and a stock engine mount.
Drivetrain:
FD2 final drive
TSX 6th gear
ATS carbon single plate clutch
SynchroTech Pro-Series carbon synchros*
Cusco Type MZ 1 way LSD
Hybrid Racing shift cables
K-Tuned billet shifter*
605g Karcepts shift knob*
Cooling:
Mishimoto oil cooler
Aluminum radiator of some sort
Suspension and chassis:
Ohlins DFV coilovers
Buddy Club roll center adjusters
Buddy Club rear lower control arms
Buddy Club rear camber kit
Hotchkis front sway bar end links (the bushings are toast so they will be replaced with some heim joint end links)
Improved Racing end links for a Miata*
Prothane sway bar bushings*
Carbing front strut tower brace
Wheels, brakes and tires:
Stock 17x8.5 +50 Mazda RX-7 wheels
Toyo R1R 245/40/17*
Hawk DTC-30 front*
Winmax RM2 rear*
Endless steel braided brake lines
Dixcel PD rotors*
Exterior:
Stock and it's staying that way
Interior:
PCI seat rail*
OMP AR-S bucket seat*
350mm Personal Trophy steering wheel*
25mm steering wheel spacer*
Defi Advance CR 52mm oil pressure, oil temp, water temp gauges*
This is the video of the engine on KMod's dyno
http://youtu.be/XBcO3Mdfz1Y
Sorry for the GoPro pictures, but it's the only camera I have that isn't a cell phone. I plan on buying a D7000 sometime after my savings account recovers from buying this car.
Koopa Troopa is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-29-2014, 05:55 AM   #2
dan_nguyen
Vietnamese Singer
dan_nguyen's Avatar
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own dan_nguyen must be an admin because here is no way they could have reached this amount on their own
Previous owner spent a whole ton of money building it the right way... Prepare for all the JDM fanboys to drool over your car lol.
dan_nguyen is offline   Reply With Quote
Old 12-29-2014, 06:11 AM   #3
Koopa Troopa
Master Member
Yeah, he said he was questioning himself on why the hell he even sold it when he was dropping it off at the port. I could do without the engine though. My plan with the engine is to just drive it till it blows up and then swap in a stock K24 from an Odyssey Absolute.
It's always fun to be able to beat people at red lights at night, but we don't have a road course on this island so I really have no actual use or desire for 290whp. All we have for motorsports on this island is gymkhana and an abandoned military runway that's used for 1/8 mile drag races and is on an outlaying island. The track surface of the place we do gymkhana at is a mixture of ice and glass, so this engine plus the track conditions should definitely be interesting frustrating.
Old 12-29-2014, 12:43 PM   #4
DC5_Trendy
Officially Amused ;P
DC5_Trendy's Avatar
DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx DC5_Trendy is a jewel in the rough of c-rsx
type r's at work
DC5_Trendy is offline   Reply With Quote
Old 12-29-2014, 01:11 PM   #5
Teggyk20
New Member
Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx Teggyk20 is a jewel in the rough of c-rsx
Lucky ass mutha****
Teggyk20 is offline   Reply With Quote
Old 12-29-2014, 10:37 PM   #6
ohsnapzitzmeng
Master Member
ohsnapzitzmeng's Avatar
ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx ohsnapzitzmeng is a jewel in the rough of c-rsx
how much did you get it for
ohsnapzitzmeng is offline   Reply With Quote
Old 12-29-2014, 11:00 PM   #7
Koopa Troopa
Master Member
Cheap enough to where my friend didn't want me to tell anyone what I paid for it. Lets just say that I bought a KMod stage 3 N/A crate engine and got a DC5R for free.
Old 12-29-2014, 11:23 PM   #8
RSlowXS
Master Member
RSlowXS's Avatar
RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx RSlowXS is a jewel in the rough of c-rsx
bought not built, aint even mad
2003 NHBP Type S
Missouri Crew
Follow Me On Instagram: Greggogrecco
RSlowXS is offline   Reply With Quote
Old 12-29-2014, 11:26 PM   #9
alexEF
Master Member
alexEF's Avatar
alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx alexEF is a jewel in the rough of c-rsx
must be really fun to use in the track.
alexEF is offline   Reply With Quote
Old 12-29-2014, 11:56 PM   #10
Koopa Troopa
Master Member
That's kinda why I bought it. Most of everything has already been taken care of so I didn't need to do anything to it. Then when I got it home, I looked at it and immediately drafted up plans to change damn near everything. Funny how that works.
Honestly I just bought it because of the Ohlins and the transmission. Dude tried to keep the trans and put a stock one from an EP3 CTR on it and I told him that's a deal breaker. I drive gymkhana, and that Cusco LSD with the 5.0 final is definitely more than desirable for the kind of driving I do. Is it weird that I told him to keep the engine if he wants to keep something?
Wish I could say yes, but I've only driven this car all of twice. The first time was an hour in bumper to bumper traffic where I never got the room to go faster than 50 km/h. The second time was to take the car to get a quote for the registration process, and then I took it to some twisty roads, but I'm too afraid of the car to really drive it. I've never gone WOT in it, and I think I only went over 5k RPM once.
The tires are dead, the brake pads don't like to brake, and I don't know how the car behaves, so I took it easy. The only track we have is a kart track that was repurposed for gymkhana use. The track surface is so old that the tarmac has worn down to a combination of ice and glass so the car should be interesting out there. However, there is a two day gymkhana event at the airstrip on the neighboring island of Izena, so I am really looking forward to that. Hopefully I'll have some tires and brake pads by then. I'm always a run what you brung type of guy, but it's beyond frustrating when you're at a very competitive event like our gymkhana events and your car just doesn't want to rotate.
If I can get some new e-brake cables, and brake rotors on the car before the 24th then I'll be golden. Tires are whatever, I'm more concerned with the brakes functioning and the ability of the rear wheels to lock than I am with how well my tires work. I can work around shitty tires, but I can't work around bad brakes.
Old 01-03-2015, 08:52 PM   #11
Koopa Troopa
Master Member
Notched the hood, still wouldn't close, so I cut that section of the skeleton out. Still wouldn't close, so I pulled the grill off to adjust the latch. Found out that the reason why the fucking hood won't close is because the core support is twisted and was only being held in with like 1.5 bolts. I say 1.5 because one of the bolts wasn't even tightened down.
RIP hood. Your death was in vain.
Better shot of the cleaned up passenger side.
For comparison, this is what I started with:
Old 01-03-2015, 08:59 PM   #12
RecarosCostTooMuch
RecarosCostTooMuch's Avatar
RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe
RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe RecarosCostTooMuch No words can describe
DC5R glove boxes don't have locks?
🔫\_(ツ)_/💰
04 NHBP Base
Slow Forever Crew |Hollaaaa|
|Broke Student Crew|
|Bitch Crew|
RecarosCostTooMuch is offline   Reply With Quote
Old 01-03-2015, 09:04 PM   #13
Koopa Troopa
Master Member
Nope. Only time I've seen a glove box with a lock on it in Japan was on my MR-S.
Old 01-03-2015, 09:06 PM   #14
RecarosCostTooMuch
Hmmm, saves some weight I guess. I think they also saved some weight by not having as much sound deadening pads as the USDM counterparts.
🔫\_(ツ)_/💰
04 NHBP Base
|Broke Student Crew|
|Bitch Crew|
Old 01-03-2015, 09:08 PM   #15
Koopa Troopa
Master Member
I don't think they have any sound deadening in them. JDM Type Rs have always been absurdly loud on the inside.
Old 01-03-2015, 09:10 PM   #16
RecarosCostTooMuch
Yeah kind of sucks if you daily them.
🔫\_(ツ)_/💰
04 NHBP Base
|Broke Student Crew|
|Bitch Crew|
Old 01-03-2015, 09:41 PM   #17
Koopa Troopa
Master Member
Yeah, I'll either get used to it, or get really pissed off at this car and buy a Vitz.
Old 01-03-2015, 10:07 PM   #18
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
title made me laugh pretty good lol
** Ivy is official SOLD **
Good buy RSX World.....
Type-Spaz is offline   Reply With Quote
Old 01-04-2015, 07:43 AM   #19
RSlowXS
Master Member
RSlowXS's Avatar
just something about that red on red interior makes me
2003 NHBP Type S
Missouri Crew
Old 01-04-2015, 10:55 AM   #20
Koopa Troopa
Master Member
I hate it. It looks tacky. Honda might as well have paint matched the interior trim.
Old 01-04-2015, 11:13 AM   #21
RSlowXS
Master Member
RSlowXS's Avatar
ill gladly trade you my black carpet and mats for yours
2003 NHBP Type S
Missouri Crew
Old 01-04-2015, 11:31 AM   #22
Koopa Troopa
Master Member
If you were local then I'd gladly make that trade.
Old 01-06-2015, 04:01 PM   #23
SA_DC5_NW
How You DOOIN
SA_DC5_NW's Avatar
SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx SA_DC5_NW is a jewel in the rough of c-rsx
Car needs a very good cleaning inside and out. Nice pick up. NOW MAKE it your own. Change a few things and make it a different car
SA_DC5_NW is offline   Reply With Quote
Old 01-07-2015, 09:46 AM   #24
Koopa Troopa
Master Member
The car sat for 3 months, went on a boat, got picked up from the docks, and then sat for another month. It needs a lot more than a cleaning.
I'm not looking to make it my own, I'm looking to drive the piss out of it. It will become "mine" inadvertently as I find ways to make it and myself faster at gymkhana.
Old 01-11-2015, 05:11 AM   #25
Koopa Troopa
Master Member
Car will be done by NLT Wednesday. This weekend should be fun. Will be flushing the brake fluid as well as installing some Dixcel blank rotors, Hawk HP+ pads, brand new e-brake cables, and I should have some fresh Rivals delivered on Saturday. I was expecting to be showing up to this two day gymkhana event with shit, and it looks like I'll be well prepared. Gymkhana on a 1/4 mile long run way should be a great way to learn the characteristics of this car.
Reply
Bookmarks
bought , built , dc5 , dc5r , integra , k24 , n or a , type
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
