My cheap clear coat repair - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Reply
Thread Tools
Old 07-28-2017, 01:35 PM   #1
Atx05rsxtypes
New Member
Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx Atx05rsxtypes is a jewel in the rough of c-rsx
This method would be another applicable solution to our cars for someone that doesn't want to spend too much money on. This method cost me $3 for sand paper and $13 for the product from amazon.
Clear coat was shot and peeling on multiple panels from exposure. I hit the paint with 1500 grit wet sand making sure I blended in the exposed paint with the good clear coat. After the sanding I used this rustoleum wipenew product that I have used in the past with good results. See the before and after pics.
Atx05rsxtypes is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-28-2017, 01:36 PM   #2
Atx05rsxtypes
New Member
Clear coat product I used.
Old 07-28-2017, 01:38 PM   #3
Salaswas
Senior Member
Salaswas's Avatar
Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx Salaswas is a jewel in the rough of c-rsx
intersted in seeing your results but pics are working???
Broke college kid #132
Salaswas is offline   Reply With Quote
Old 07-28-2017, 01:41 PM   #4
Atx05rsxtypes
New Member
It's not allowing me to post photos from my phone saying that I'm limited feom uploading...
Old 07-28-2017, 01:44 PM   #5
InZain08
Senior Member
InZain08's Avatar
InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx InZain08 is a jewel in the rough of c-rsx
If you ever get your pictures uploaded I would be interested in doing this to my e46. The roof is oxidizing pretty badly.
InZain08 is offline   Reply With Quote
Old 07-28-2017, 01:48 PM   #6
Atx05rsxtypes
New Member
This is the product I used.
Click image for larger version
Old 07-28-2017, 01:51 PM   #7
Atx05rsxtypes
New Member
These were taken a year ago. Notice the peeling clear coat where it completely exposed the paint. I ended up using a 1500 grit sand paper and some soap and water. Took about 1-2 hours to hit all the spots that I needed to cover.
ID:	535353   Click image for larger version
ID:	535361   Click image for larger version
Old 07-28-2017, 01:53 PM   #8
Atx05rsxtypes
New Member
These were taken yesterday after I allowed the product to dry. It dries into an acrylic like state. Kind of like clear nail polish. All the pictures I uploaded have not been edited or filtered. All were taken with natural lighting.
ID:	535377   Click image for larger version
ID:	535385   Click image for larger version
ID:	535393   Click image for larger version
ID:	535401   Click image for larger version
Old 07-28-2017, 01:54 PM   #9
Atx05rsxtypes
New Member
It's no where near showcase perfect but does the trick for someone wanting to spend less than $20.
Old 07-28-2017, 01:55 PM   #10
InZain08
Senior Member
InZain08's Avatar
Wow! Not bad. So walk us through your process once more with a bit more detail.
Old 07-28-2017, 01:59 PM   #11
Atx05rsxtypes
New Member
Correction on post #7. Pics were taken a week ago.
Old 07-28-2017, 02:01 PM   #12
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
wow that looks awesome
Type-Spaz is offline   Reply With Quote
Old 07-28-2017, 02:11 PM   #13
Atx05rsxtypes
New Member
I first thoroughly washed the car with a detergent such as dawn dish soap. Soaked another bucket with soap and water to use with 1500 grit wet/dry sand paper. Fold the sandpaper so it fitted in the palms of your hand and lightly sand the areas you are only going to cover with the product. You may need to sand a little more thorough on the areas of the peeling clear coat so that it will blend in with the rest of the panel. Be gentle because you will burn through the paint pretty quickly especially on the raises areas where the metal bends.
After sanding, wash the car again with a detergent and thoroughly dry it. Now once car is completely dry, you want to do this in a shaded area or in your garage. Best time to do this is in the late afternoon or evening because you want your panels cooled down. Now use the product and the supplied microfiber clothes. Product is about 2 ounces and is just enough to cover what you see in my pics. Soak the microfiber and be liberal covering the affected areas. You want to only make one pass because overlapping will cause streaking. YouTube wipenew and follow how to apply the product for best results. Once down, allow the product to dry for 24 hours. Don't get impatient and tough the panels during this time because you will create smudges. Like I said it isn't show quality or perfect but definitely better looking than before and great for a daily driver.
Old 07-28-2017, 02:14 PM   #14
Atx05rsxtypes
New Member
If you give it a try post some pics.
Old 07-28-2017, 02:15 PM   #15
Atx05rsxtypes
New Member
It's working now.
Old 07-28-2017, 04:06 PM   #16
InZain08
Senior Member
InZain08's Avatar
I'll do that. Just ordered a kit.
Old 07-31-2017, 07:26 PM   #17
Atx05rsxtypes
New Member
Got bored and decided to do the front bumper too since it had bad clear coat issues and scratches from years of abuse from being on the road. No before picture but you can see it all nice now.
Old 07-31-2017, 08:14 PM   #18
TRedel
Member
TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx TRedel is a jewel in the rough of c-rsx
Wow I may try that on my roof
TRedel is offline   Reply With Quote
Old 07-31-2017, 09:39 PM   #19
Atx05rsxtypes
New Member
After it has dried for a few days. I recommend applying some hand wax to give it a little more shine and protection.
Old 07-31-2017, 11:11 PM   #20
dc5luis
Master N00b Member
dc5luis's Avatar
dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx dc5luis is a jewel in the rough of c-rsx
Garage
Woah that came out amazing. Might have to look into this alternative.
dc5luis is offline   Reply With Quote
Old 08-01-2017, 09:07 PM   #21
InZain08
Senior Member
InZain08's Avatar
Still waiting on my kit to arrive. Your car is looking completely refreshed ATX. Good work and thanks for sharing
Old 08-01-2017, 09:37 PM   #22
Atx05rsxtypes
New Member
Thanks! If you notice the picture on post 17, you will see streaking and clouding on the headlights. That's what happens if you try to put on a second coat after the first coat dries. Try to do one pass before it starts drying and change out the microfiber pad if you notice the product starts hardening. You pretty much want to cover all the panels within a few minutes.
Old 08-03-2017, 03:37 PM   #23
Atx05rsxtypes
New Member
I had one person message me and mention that I needed to take pictures of the panels in sunlight for better representation of the work.
ID:	535737   Click image for larger version
ID:	535745   Click image for larger version
ID:	535753   Click image for larger version
Old 08-04-2017, 10:43 AM   #24
G3min1
Curious Gooner
G3min1's Avatar
G3min1 is on a distinguished road G3min1 is on a distinguished road G3min1 is on a distinguished road
Garage
Wow man...My hatch has the same problem as yours, and I just don't want to repaint it, so this is a great "temp" fix. I wonder how long it will last.
I take it you must really be patient when sanding and applying the wipe new? For the sanding did you just apply light pressure?
Originally Posted by krystar View Post
Turbo Pros: You get a BlowOff Valve PSHSHHHHHH
Cons: Your car can blow up
Supercharger Pros: You get that distinctive supercharger whine going down the street.
"Beating a Dead Horse Crew " Member #1
G3min1 is offline   Reply With Quote
Old 08-04-2017, 11:38 AM   #25
Atx05rsxtypes
New Member
Light pressure using your hand. It didn't take long. Just enough to feather the edges.
Reply
Bookmarks
cheap , clear , coat , repair
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
