The Ten Commandments of Noise Prevention - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Audio, Security, & Electronics RSX
Reply
Thread Tools
Old 06-03-2005, 09:51 AM   #1
Locotony
The Audio Guru
Locotony's Avatar
Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx Locotony might be well recognized one day on c-rsx
Saw this posted on ICIX and though it important enough to share as noise issues crop up here all of the time, Moderaters you may want to Stickey this.
Original article here:http://www.termpro.com/articles/noise.html
I. The best cure is prevention. I can't overemphasize this point. If you've ever spent an entire weekend tearing an installation apart in order to eliminate some noise, you know what I mean. Take the time to sketch the system out before you begin the install. This graphic representation of the installation will help you to avoid introducing ground loops and will serve as a road map for eliminating noise if it is present.
II. Don't introduce ground loops. Ground loops are created whenever an audio ground is established at more than one location. Theoretically, the only place the audio ground should be connected to the chassis ground is at the source unit. In my experience, I've found that in systems that have noise problems, a ground loop is the culprit nine times out of ten.
III. Never run signal wires alongside power cables. This is especially true in installations where high powered amplifiers are used. Large amplifiers are capable of drawing large currents. These currents vary with the musical demand of the program material as does the electromagnetic field surrounding the power cable. The more current that flows through the wire, the bigger this field becomes. If audio cables are located in close proximity to this fluctuating electromagnetic field, noise could be induced into the system.
IV. Always use 100% shielded audio cable. This will insure maximum protection against induced noises by power cables and other sources of electromagnetic interference. Good audio cables are not cheap. If you prefer to make your own cables, I would recommend using a wire with a foil shield surrounded by a drain wire.
V. Never use the ground wire in the vehicle's OEM radio harness. This wire usually makes a very poor ground due to it's length, small wire gauge, close proximity to other power wires, and unknown termination point. Instead, ground the source unit directly to the chassis or firewall.
VI. Make sure the amplifiers have a good audio ground reference. In order for the amps to function properly, the audio ground must be referenced to chassis ground at the source unit. If it is not, the amplifier could oscillate. To check for a good ground reference, take a volt-ohm meter (VOM) and measure the resistance between the chassis of the radio and the shield of the RCA line level outputs of the radio. This reading should indicate a direct short. If this is not the case, grounding the shield of the RCA line level outputs to the chassis of the radio will probably be necessary.
VII. Keep amplifier power ground wires as short as possible. The longer a wire, the more resistance it has. When a current flows through a resistance, a voltage drop is produced. Because of this, the ground reference at the amplifier's circuit board is no longer the same as that at the chassis of the vehicle. This ground potential differential can lead to noise and improper operation of the amp.
VIII. Don't connect all of your amplifier ground wires under one bolt. Contrary to belief, this is not required if the rest of the system is installed properly. If you do connect more than one power ground wire under a single bolt, you run the risk of amplifier ground modulation. This is caused by the current demands of, for example a woofer amp, modulating the power ground wire of a tweeter amp. This results in a squeaking noise that can be heard over the tweeters whenever bass notes hit.
IX. Make sure all levels are set correctly. Level setting is a critical part of the installation process. If done properly, maximum system signal to noise ratio can be obtained. Keep in mind that you want to drive the audio cables that feed the amps in the rear of the car as hard as possible. To do this, reduce the gain of the amplifiers to minimum. Turn up the volume on the source unit to 80% of maximum. Now adjust the input sensitivity of the amplifiers upward until the maximum intended loudness is obtained.
X. Noise filters can only reduce noise, not eliminate it. A noise filter is just that, a filter. And like any other filter (crossover network, etc.), it works by modification, not elimination. Some installers rely on filters heavily. In some instances a filter may prove necessary, but I believe that if the system is installed properly, a filter is usually not required.
About now most of you are probably making strange faces and saying "Now you tell me!" Well, all is not lost. If you have already installed your auto sound system and are unfortunate enough to have some noise, here are a few suggestions on where to look and what to do.
Alternator Whine
To me, alternator whine is the most annoying form of noise. For those of you who are lucky enough never to have been exposed to alternator whine, it sounds like a miniature siren that rises in pitch with the speed of the engine. Alternator whine is almost always caused by a ground loop. The following steps will aid you in locating and correcting a ground loop problem.
1. Verify that all levels are set properly.
2. With the system turned off, unplug the RCA inputs to the amplifier.
3. Start the vehicle and turn the system on. If the noise is gone go to step 8. If the noise is still present, it is coming from the amp or the speaker wiring. Continue.
4. Turn the system off and disconnect the speaker harness.
5. Start the engine and verify that no noise is present. In a few rare instances, I have actually heard speakers reproduce noise without being connected to an amplifier. This noise was being induced by power cables that were very close to the speaker wire. If you do have this type of noise, reroute the appropriate speaker lead and go to step 3.
6. With the speaker harness still disconnected, check to make sure there are no shorts between the speaker leads and the chassis of the vehicle. A shorted negative speaker lead will create a ground loop by establishing a second audio ground reference point. If you do have a short, trace the wire out and repair it then go to step 3.
7. With the RCA inputs and speaker harness still disconnected from the amplifier, use your VOM to measure from the shield of the RCA jacks on the amp to the chassis of the vehicle. This reading should not be a direct short (100 ohms or more is acceptable.) If this reading does indicate a direct short, you might have a defective amp and should contact the manufacturer for verification. (Note that there are a few "inexpensive" amps or boosters on the market that have their audio ground and electrical ground commoned internally. For units of this type, the information in this article will be of very little value.)
8. If you've made it here, you know that the amplifier and speaker wiring are okay.
9. Connect the accessories in front of the amp (crossovers, equalizers, etc.) one at a time and check for alternator whine. When each device is tested, there should be nothing plugged into the input of that device. In this way, we will work toward the source unit piece by piece. Be sure to turn the system power off before connecting or disconnecting any cables or accessories.
10. Repeat step 9 until all accessories have been tested.
11. If a particular accessory is causing noise, try disconnecting it's power ground wire. Go to step 9.
12. Now it's time to connect the source unit. Do that now and test for noise.
13. If noise is present, try unplugging the antenna. If the noise goes away, you will need to use an antenna isolator. This little gismo opens the shield wire of the coax to eliminate the ground loop caused by the ground at the antenna.
14. If you still have noise, try connecting the source unit's ground wire in another location,. preferably as close to the source unit as possible.
15. Does the noise vary in amplitude when you adjust the volume control? If it does, the problem is probably power line related and not a ground loop. If this is the case, run the source unit's B+ (yellow) wire directly to the positive terminal of the battery. If this doesn't do the trick, you will probably have to use a power line filter on the source unit's B+ (Yel) and Ignition (Red) wires.
Ignition Noise
Ignition noise is another type of noise that is quite annoying. It usually sounds like a popping or buzzing sound whenever the engine is running. The best cure is to remove the motor but since we can't do that, we will have to rely on some other form of remedy. Follow the steps below to eliminate or reduce ignition noise.
1. Make sure you are using resistor type spark plugs and resistor type plug wires.
2. Determine where the noise is coming from. If the noise is a popping sound that occurs 2 or 3 times a second, you probably have a loose or bad plug wire. First, make sure that all plug wires are seated properly. If this doesn't do the trick, you may have a bad plug wire. Usually this occurs due to a pinhole in the insulation of the wire. Whenever the plug wire is energized, an arc jumps through the pinhole to the chassis of the vehicle. Replace with silicone resistor plug wires.
3. If the noise is a buzzing sound, the problem is usually associated with the points, distributor, or coil. Try replacing the condenser on both the coil and points. Make sure all plug wires are seated properly in the distributor cap. Additionally, you might try adding a 2200 uF cap from the positive terminal on the coil to chassis ground.
4. Don't use the fuse block in the vehicle to derive power for the source unit. Run the Constant Hot B+ (memory) wire directly to the battery's positive terminal.
5. If you still have noise, it could be occurring because of induction. Try pulling the source unit out of the dash and check for noise. If the noise is eliminated, try rerouting any wiring harnesses that are close to the deck. If this is not possible, try using self adhesive metal shielding. This might just do the trick.
Turn On/Off Thump
Turn on thump can vary from a slight pop to a mind shattering, teeth rattling BOOM! This thump is caused by the audio circuitry stabilizing when power is applied. Most amplifiers and source units have muting circuitry that lasts a couple of seconds to allow these fluctuations to subside before passing a signal. However, if the amplifier un-mutes before the source unit or any other accessory, you better watch out. Here are some things to try if you have turn on thump.
1. Verify that the amp has a good audio ground reference. (See rule 6 of the Ten Commandments of noise free installation.)
2. Don't install the system so the amplifiers can be switched on when the source unit is turned off.
3. If you still have thump, add a turn on delay module in line with the remote turn on wire to the amp.
4. This concludes the section on turn on thump.
System Hiss
Hiss is usually most noticeable over the midrange and tweeters. The reasons for this are simple. The human ear is more sensitive to the frequencies reproduced by these drivers. Mids and tweets are usually far more efficient than their low frequency counterparts. And, these drivers are usually mounted closer to the listener. If you have hiss, you probably have your levels set improperly. See rule 9 of the Ten Commandments of noise free installation.
While I know that I haven't covered all the forms of noise or even all of the methods of dealing with it, I hope that I've made a good start. By adhering to the Ten Commandments and investing a little persistence, you will be rewarded with a noise free installation.
Car Audio, Security, & Electronics Moderator
2014 CBP Civic Si Coupe
Rockford Fosgate 3sixty.3
Illusion Audio Carbon C6 Comps
Precision Power Phantom 900.4 and 1000.1
2 - 12 inch Acoustic Elegance IB12AU Subs
Locotony is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-03-2005, 10:03 AM   #2
xvi3tsoljahx
Senior Member
xvi3tsoljahx is an unknown quantity on c-rsx
good read.
xvi3tsoljahx is offline   Reply With Quote
Old 06-03-2005, 11:30 AM   #3
ewoodrsx1
aka Batman on weekends
ewoodrsx1 is an unknown quantity on c-rsx
what if there is a popping sound on my tweeters when the volume is at 01 or higher but perfect silence at 00 (no volume at all). Is there a difference in the potential problem?
04NBPBase
*CRSX*Injen*Mugen/Mugen Replica*GrilleTech*JJ's*Infinity/Kappa*Eclipse*JVC*Valentine*Autovation*DecalGirl*A SPEC*ITR*Comptech*LaminX*HKS*DynamatXtreme*Megan*C usco Replica*DC Sports*Fujitsubo*EnergySuspension
*Hondata*Wilwood*Hawk*Motul*Ingalls*Rotora*Stoptec h*OZ Racing*Yokohama*RAYS*Dunlop*Directed*Neuspeed*V-leds*Retro-Solutions*Buddy Club
ewoodrsx1 is offline   Reply With Quote
Old 06-03-2005, 01:47 PM   #4
Locotony
The Audio Guru
Locotony's Avatar
the silence at 00 would be that the hu is not sending any signal so the amp is not seeing anything to amplify, at 01 it gets a signal and starts working.
Old 06-03-2005, 05:44 PM   #5
Hobbes26
Member
Hobbes26 is an unknown quantity on c-rsx
Who wrote it?
edit: nevermind... I see the link at the top now.
I'm not so sure I agree with all of those points he makes.
Hobbes26 is offline   Reply With Quote
Old 06-04-2005, 05:51 AM   #6
Excelerater
ooop's upside your head
Excelerater is an unknown quantity on c-rsx
well said
RSX
Excelon 789 HU
Aura MR62's
Ported Diamond TDX12D2
eD Nine.1
D5300.2
KNU 4ga
Excelerater is offline   Reply With Quote
Old 06-05-2005, 10:16 AM   #7
Locotony
The Audio Guru
Locotony's Avatar
Bump for necessary info
Old 06-15-2005, 06:28 AM   #8
Locotony
The Audio Guru
Locotony's Avatar
Bump for good Info
Old 06-17-2005, 09:12 PM   #9
thud333
Bass head
thud333 is an unknown quantity on c-rsx
this really should be a sticky.
thud333 is offline   Reply With Quote
Old 06-17-2005, 10:36 PM   #10
VTEC-RSXS
Bimmer1
VTEC-RSXS's Avatar
VTEC-RSXS is an unknown quantity on c-rsx
you are the man.
What?
VTEC-RSXS is offline   Reply With Quote
Old 06-18-2005, 04:24 PM   #11
Anti Conforming
Smile For Me Daddy
Anti Conforming's Avatar
Anti Conforming is an unknown quantity on c-rsx
I have mad turn on thump, but i dont exactly understand what you are trying to explain, could you put it simpler at all?
Anti Conforming is offline   Reply With Quote
Old 06-18-2005, 08:56 PM   #12
MueveloNYC
700p LTR TWS .308
MueveloNYC's Avatar
MueveloNYC has a clean start MueveloNYC has a clean start MueveloNYC has a clean start MueveloNYC has a clean start
adding this to faq.
2009 Infiniti G37x 330HP - Sold: 2002 SSM RSX
Photo: Canon 7D, 70-200 f/2.8L IS, 24-105 f/4L IS, 50 f/1.4, 100 f/2.8, 10-22, 580EXII, ABR800
Firearms: HK USPc w/ CCW (CT/FL), Remington 700p .308 LTR TWS, Benelli M1 Super 90, Browning Buckmark Hunter w/ 10" TacSol barrel
MueveloNYC is offline   Reply With Quote
Old 06-19-2005, 02:05 AM   #13
FaintReality
Master Member
FaintReality's Avatar
FaintReality is an unknown quantity on c-rsx
Good info but I do not agree with all the above
Dave
Audio & Security FORUM MODERATOR
FaintReality is offline   Reply With Quote
Old 06-19-2005, 02:47 AM   #14
BRAISKI
What are you made of...
BRAISKI's Avatar
BRAISKI has disabled reputation
Damn thats too much reading for me
Any cliff notes?
http://forums.clubrsx.com/signaturepics/sigpic17787_1.gif
"Destiny is not a matter of chance; it is a matter of choice. It is not something to be waited for; but, rather something to be achieved." William Jennings Bryan (1860-1925)
Effective questioning brings insight, which fuels curiosity, which cultivates wisdom
BRAISKI is offline   Reply With Quote
Old 06-19-2005, 09:30 AM   #15
Locotony
The Audio Guru
Locotony's Avatar
Originally Posted by MueveloNYC
adding this to faq.
Thanks, +rep
Old 06-19-2005, 03:59 PM   #16
| Greg2385 |
Scion TC
| Greg2385 |'s Avatar
| Greg2385 | is an unknown quantity on c-rsx
Great Write-up.
| Greg2385 | is offline   Reply With Quote
Old 06-20-2005, 11:47 PM   #17
papichulo21
papichulo21 is an unknown quantity on c-rsx
Did you set your gain properly...did you use a multimeter to match your decks output voltage to that of your amplifier? This is a commonly overlooked problem and could resolve your issue quite easily.
Also, if it persists what might be happening is that everything is turning on at once and what you need to do is delay the amp turnon to do this you can purchase http://www.cardomain.com/sku/STISPSON Stinger On Pop Eliminator
but i highly suggest you first check your amplifier settings before anything else.
papichulo21 is offline   Reply With Quote
Old 06-21-2005, 03:44 PM   #18
Hobbes26
Member
Dave
That's what I said.
Old 10-12-2005, 11:29 AM   #19
DallasRSX
I am a non smoker
DallasRSX's Avatar
DallasRSX is an unknown quantity on c-rsx
good shit good shit!
DallasRSX is offline   Reply With Quote
Old 12-24-2007, 08:07 PM   #20
jspatei
Senior Member
jspatei is an unknown quantity on c-rsx
Much respect to the guys who've contributed to the noise reduction thread. I have one issue that doesn't seem to have a clear response, and a few members have had the issue in the past: When I tap the brakes I get a pop in the speakers. Any suggestions as to the likely cause? Searched and couldn't find an answer.
jspatei is offline   Reply With Quote
Old 12-25-2007, 06:08 AM   #21
Locotony
The Audio Guru
Locotony's Avatar
Usually something like that has to do with a ground being loose or radiated noise from speaker/rca lines too close to the ECU.
Old 03-18-2008, 08:23 AM   #22
bacchus418
Senior Member
bacchus418's Avatar
bacchus418 User will be banned for a week, please report them to an Admin
The grounding issue seems contradictory to me. It says all audio grounds should be at one location, at the source unit. It also says that ground wires for the amplifiers should be as short as possible. Then again it says that you shouldn't share a ground with more than one amplifier. That doesn't make sense. You can't do all three of these things together. So what's the right way to do it?
2003 RSX-S PWP
SHOW: Aspec kit, Chargespeed grille, '05 gunmetal wheels, DIY blackouts, nine.4, eDi 6500s, Big 3, Alpine 9884, Audiofrog, Fosgate, custom 10" sub box, Titanium trim kit, Bride shift boot, Wet Okole, 5% tint GO: K-Pro!, IMG, Injen CAI, Megan shorty header, custom 2.5" catback, KW V2 coilovers, SPC camber kits, Hotchkis endlinks, Progress sway bars, Stoptech Stage 2, Ingalls ETD, Hardrace bushings and mounts, Comp Clutch Stg 5, Quaife, JRSC 3" pulley, Merc aftercooler, DW 65C & 800CC INJs
bacchus418 is offline   Reply With Quote
Old 03-19-2008, 12:20 AM   #23
strikeback03
Senior Member
strikeback03 is an unknown quantity on c-rsx
Unless you consider the chassis to be a perfect ground block, if you have the HU at the front and amp(s) at the back one of those will need a long ground cable.
strikeback03 is offline   Reply With Quote
Old 03-19-2008, 06:18 AM   #24
Locotony
The Audio Guru
Locotony's Avatar
the HU ground to the rear where the amps are is a last ditch noise prevention thing to try. most people don't have issues with a single grounding point for amps either, once again last ditch efforts to get rid of noise. about 80% of the time noise issues are either RCA issues or a poor grounding on the amps.
Old 04-03-2008, 09:57 PM   #25
bacchus418
Senior Member
bacchus418's Avatar
That makes more sense. I eventually discovered my alternator whine was due to my LOCs. A new Alpine HU took care of that. Thank god, it was making me f**king crazy
2003 RSX-S PWP
Reply
Bookmarks
commandments , noise , prevention , ten
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
