How to Conceal Your Head Unit - Club RSX Message Board
Go Back   Club RSX Message Board > STYLE RSX > Car Audio, Security, & Electronics RSX
Reply
Thread Tools
Old 06-19-2005, 12:49 PM   #1
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
9/11 RSX-s has a clean start 9/11 RSX-s has a clean start 9/11 RSX-s has a clean start
A couple of years ago when I replaced the stock speakers and amp, I kept the stock head unit, in part, because I didn't want to invite every flippin' crackhead in the country to break into my car. Say what you want about the Bose HU, but it has one great feature: It won't fit in ANY other car (and it has a security code) so only a complete moron would steal one (okay, so that is not 100% protection).
Anyway, I got the notion that maybe the faceplate of the stock HU could be used as a false faceplate over the top of an aftermarket HU. As it turns out, I was right. This 3-part post explains what I did. Oh, and it can all be undone and set back to stock.
One screw on each side of the HU holds the faceplate on.
(See the existing DIY's, and such, for info on removing the HU, that's what I did.)
The back of the faceplate is a circuit board. The little metal clips on the ends of the plastic studs are why the HU is sort of difficult to remove from the dash. Pull the little bastards off and throw them away (even if you are retaining the stock HU, you don't need them). The plastic studs have a shoulder, then a tip that extends further to which the metal clips are attached. Trim off most of that extension (this allows clearance for what ever trim plate you use around the concealed HU).
Click image for larger version
ID:	178144   Click image for larger version
T-shirts that make you think ... and laugh
https://www.eyeronic-ts.com
Clarion DXZ755MC (concealed install)
ASPEC | Neuspeed | CenterLine Racing RPM | BFG KDW-2
IN> Injen CAI > Hybrid Racing 70mm > RRC > RDX 410cc > IPS K2 > DCRH & Cat > 2.5" Stainless >OUT
9/11 RSX-s is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-19-2005, 12:53 PM   #2
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
PART-2 Mounting Bracket
The stock HU is held in the dash by the annoying metal clips on the faceplate and by a metal bracket that surrounds the HU like a cage. This bracket has two nuts toward the rear, but since we must mount the concealed HU deeper into the dash than stock, the nuts on the bracket will no longer line up with the bolt holes in the dash structure. In order to mount the bracket and HU deeper in the dash, we must trim some metal off the left, rear, top corner of the bracket.
We must also trim the left, rear, bottom of the bracket. Note, you could cut off several inches and gain some maneuvering room that would be very nice while you are trying to fit trim around the concealed HU, but if you cut off the area that contains the two nuts, you would not be able to use the bracket for a stock depth mounting in the future.
Now add slots to the two holes in the middle of the bracket. This is where our new mounting bolts will go. I would make them a bit longer than I did. You'll need 2 bolts 3/4" long, 2 nuts, 4 washers (and I would use a lock washer of some sort, too).
These two holes in the structure of the dash will align with the slots you cut in the mounting bracket.
Trim back the plastic edge of the dash opening. This will make it easier to fit trim around the concealed HU. But you need to retain some material for the shoulders of the plastic studs on the faceplate to rest on. This is what keeps the faceplate at the correct height.
Note the pretty, pretty yellow foam around the edges of the opening. The "chunks" that are sort of out in the open are already sort of cut out, you just need to persuade them to let go. Once I had the extra chunks off, I went around the foam edge with a black marker. No more yellow.
ID:	178146   Click image for larger version
ID:	178147   Click image for larger version
Old 06-19-2005, 12:59 PM   #3
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
PART 3 Installed
My HU came with a mounting kit that included a pocket for under the HU. I cut a hole in the back side of the pocket and ran the Aux line from the HU and the USB from my K-Pro into the pocket.
The green circle marks where I cut the trimplate in half. Once the HU is in the dash, there is not enough room to get the full trimplate in, so I did it in halves. If you cut off more of the back of the bracket, you might be able to maneuver the trimplate into place in one piece. In any case, you'll need to trim some material off the bottom of the trimplate where it hits up against some plastic ridges in the lower portion of the dash opening. This is hard to do once you have the HU in place, so I recommend doing a test fitting before you commit to hooking up wires and such.
That is the real Hazard button. On the stock faceplate, I mounted one with the backside cutoff so it would clear the inner trimplate (check a junk yard for this part).
I have not yet colored the foam or put rubber trim in the gap.
Blurry, but it fits over the concealed aftermarket HU.
Finished daytime photo. Note, the wires in the pocket are for my K-Pro and Aux input into the HU. I thought about using some black cloth tape around the gap instead of the rubber weather strip, but couldn't find the stuff any more. Perhaps you'll come up with a better way to finish the gap.
Night photo. The HU is a Clarion DXZ755MC. You can set the RGB color of the display and the buttons. Better red than . . .
ID:	178149   Click image for larger version
ID:	178150   Click image for larger version
ID:	178151   Click image for larger version
Old 06-19-2005, 08:00 PM   #4
h4rapture
Audio Junkie
h4rapture's Avatar
h4rapture is an unknown quantity on c-rsx
dude that is freakin awesome! seriously i think its brilliant, definate alternative to removable faceplates!
Car: 04 Eternal Blue Pearl Auto w/ Leather
h4rapture is offline   Reply With Quote
Old 06-19-2005, 08:38 PM   #5
blaznRSX
405 (OKC) to the 703 (VA)
blaznRSX's Avatar
blaznRSX is an unknown quantity on c-rsx
that's sweet! too bad i can't try that DIY since I swapped my stock for a pioneer
blaznRSX is offline   Reply With Quote
Old 06-21-2005, 10:20 AM   #6
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
Thanks.
Yeah, and since almost every aftermarket HU has a removable faceplate, people break in anyway and then look in the glovebox for the faceplate since most peeps don't actually take the thing with them.
Old 06-21-2005, 10:26 AM   #7
BarracksSi
Master Member
BarracksSi's Avatar
BarracksSi is an unknown quantity on c-rsx
When the entire radio was removable, this was a lot easier --
My first aftermarket deck was a pullout model. I pried the faceplate off of the stock HU and Superglued the buttons & knobs in place. When I wasn't comfortable with wherever I parked, I would pull out the aftermarket head, put it under the seat, and cover the hole with the stock faceplate. Nobody could tell the difference by looking into the car.
BarracksSi is offline   Reply With Quote
Old 06-21-2005, 11:33 AM   #8
itzjere
Alpine White E46 M3
itzjere's Avatar
itzjere is an unknown quantity on c-rsx
Man, that is amazing!
2003 Alpine White BMW M3
2004 Crystal White Pearl RSX Type-S with Ebony Interior - Sold
Member Show-Off | S2000 Cluster Retrofit DIY | www.JeremyCheung.net | flickr
itzjere is offline   Reply With Quote
Old 06-21-2005, 11:35 AM   #9
Brusky
B-O-MmMmm
Brusky's Avatar
Brusky is an unknown quantity on c-rsx
Talk about stealthy. Props for creativity and originality.
| Canon Rebel XT | 18-55mm Kit Lens | Canon 28-135 IS USM |
| Brusky's Photography Gallery |
| Brusky: Return of the BoMmMmm Machine |
Brusky is offline   Reply With Quote
Old 06-22-2005, 09:32 AM   #10
SpeeDemoN
SpeeDemoN's Avatar
SpeeDemoN has been a little shit in the past
That is awesome!!! hahaaahaahah
SpeeDemoN is offline   Reply With Quote
Old 06-30-2005, 12:58 PM   #11
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
Minor update. My HU came with a remote. Turns out that I can leave the stock faceplate in place, prop open the cassette slot, and run the Clarion HU with the remote. Stealth mode
Old 07-16-2005, 08:58 AM   #12
jay3737
GS...yes plz
jay3737's Avatar
jay3737 is an unknown quantity on c-rsx
sweet idea... + rep for you!
'12 Regal GS | '93 MR2
jay3737 is offline   Reply With Quote
Old 07-16-2005, 09:02 AM   #13
Insomniak
Senior Member
Insomniak's Avatar
Insomniak is an unknown quantity on c-rsx
Very unique idea... hahaha
Insomniak is offline   Reply With Quote
Old 08-05-2005, 02:35 AM   #14
The Spectacle
is addicted to success
The Spectacle's Avatar
The Spectacle is an unknown quantity on c-rsx
nice
The Spectacle is offline   Reply With Quote
Old 08-05-2005, 12:24 PM   #15
dbgtlord
HyPHY
dbgtlord's Avatar
dbgtlord is an unknown quantity on c-rsx
haha! wow thats awesome! i still remember those decks that you had to completely take out. old school shiet.
dbgtlord is offline   Reply With Quote
Old 08-05-2005, 08:56 PM   #16
inmys2k
Hellooo
inmys2k's Avatar
inmys2k has a clean start inmys2k has a clean start inmys2k has a clean start
wow, good stuff there, i like stealth =)
inmys2k is offline   Reply With Quote
Old 08-07-2005, 01:38 AM   #17
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
plus rep for u man but get the tape cover out and then u can use ur remote and never remove the front face or drill a hole where the IR sensor is muahahah even better
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Old 08-07-2005, 01:57 AM   #18
9/11 RSX-s
Master Member
9/11 RSX-s's Avatar
Actually, I just sort of stick the end of the remote in the tape slot and fire away.
Hey, thanks everyone for the comments.
Old 08-07-2005, 02:09 AM   #19
bluej511
Name's Vic
bluej511's Avatar
good enough fuck it as long as it gets the job done u should get a shit load of reps from this thread its def amazing work write that in ur sig ur the first one buddy congrats
Old 08-07-2005, 03:33 AM   #20
GotDc5
FEED ME!!!
GotDc5's Avatar
GotDc5 is an unknown quantity on c-rsx
damn thats some cool shit right there
Flickr
GotDc5 is offline   Reply With Quote
Old 08-08-2005, 02:17 PM   #21
MueveloNYC
700p LTR TWS .308
MueveloNYC's Avatar
MueveloNYC has a clean start MueveloNYC has a clean start MueveloNYC has a clean start MueveloNYC has a clean start
its a little extreme, but the thing looks insanely ugly without the cover. Kudos for the novel idea... Now if you can get the antitheft light to blink, that would be hot.
2009 Infiniti G37x 330HP - Sold: 2002 SSM RSX
Photo: Canon 7D, 70-200 f/2.8L IS, 24-105 f/4L IS, 50 f/1.4, 100 f/2.8, 10-22, 580EXII, ABR800
Firearms: HK USPc w/ CCW (CT/FL), Remington 700p .308 LTR TWS, Benelli M1 Super 90, Browning Buckmark Hunter w/ 10" TacSol barrel
MueveloNYC is offline   Reply With Quote
Old 08-08-2005, 06:26 PM   #22
raiser
Master Member
raiser's Avatar
raiser is an unknown quantity on c-rsx
agreed
raiser is offline   Reply With Quote
Old 08-09-2005, 04:18 PM   #23
danieRRrr
135i Coupe Owner!
danieRRrr's Avatar
danieRRrr is an unknown quantity on c-rsx
Except you wont be able to switch cd's without taking off the stock headunit plate
2008 BMW 135i Coupe
Jet Black
Sports Pkg
Lemon Boston Leather Interior
High Black Gloss Trim
Comfort Access System
danieRRrr is offline   Reply With Quote
Old 09-16-2005, 10:25 AM   #24
4thGenTeg
I support Death Panels
4thGenTeg's Avatar
4thGenTeg has been a little shit in the past
Brilliant. I'd been thinking for some time that the best security would be finding a way to do this. I always hated pulling the faceplate off my fancy stereo, so I haven't bothered putting it in this car. Good to see someone had the initiative and ingenuity to figure it out. Seems like there should be an aftermarket outfit specializing in finding ways to make a nice h/u look stock, or like a cheap h/u. It's the ultimate combination of security and convenience.
4thGenTeg is offline   Reply With Quote
Old 09-19-2005, 02:13 AM   #25
rbarbera75
Master Member
rbarbera75 is on a distinguished road rbarbera75 is on a distinguished road
That is really a cool idea and it looks great.
rbarbera75 is offline   Reply With Quote
Reply
Bookmarks
conceal , head , unit
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
