DIY Coilover Install - Club RSX Message Board
Go Back   Club RSX Message Board > SUSPENSION > Suspension, Chassis & Brakes
Reply
Thread Tools
Old 02-28-2006, 08:40 PM   #1
bluej511
Name's Vic
bluej511's Avatar
bluej511 is a hardcore rep whore
bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore bluej511 is a hardcore rep whore
Alright well i had to start a new thread so people dont get confused.
Follow link to pre-coilover installation.
http://forums.clubrsx.com/showthread.php?t=361955
1 Putting my coilovers to sleep
2 Heres before
3 And heres after install
Edit Edit Edit
Here are the torque specs for you guys, right out of the helms manual
Front
Brake line is 16 ft lbs
ABS line is 7.2 ft lbs
Both lower strut bolts are 76 ft lbs
Top 3 bolts are 33ft lbs
Rear
Top upper bolts are 43 ft lbs
Rear bottom bolt is 45ft lbs.
If your going to loosen the tie rod the bolt is 15/16ths and 14mm to hold the inner tie rod to tighten the tie rod end nut.
Armenian crsx crew member #6
02' RSX-S 179k mi, 14.5 @97. Sold after 12years.
13' Trek Madone 5.2. 2012 Swift Sport
bluej511 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-28-2006, 08:43 PM   #2
bluej511
Name's Vic
bluej511's Avatar
FRONT INSTALLATION
1 Jack up the car, if you dont know how to do that or put jack stand under a car please stop now lol
2 Tools needed are 19mm for tie rod strut lower bolts and rim. 7/8ths wrench to hold nuts for lower strut bolt.10mm for ABS and 12mm for brake line, 14mm for strut bolts. Torque wrench and air gun.
3 Wheels off and time to check rotors and pads as well.
Remove tie rod by hitting the strut arm with a hammer until the tie rod is loose, or use a tie rod puller. Unbolt abs and brake line, and take both bottom strut bolts out. Leave the knuckle and brakes at the opposite side of which ur gonna pull the strut out. Left side came out towards the front of the car and the right side was opposite....Unbolt 2 of the 3 strut bolts and leave em on the cowl close to reach if 1 person installation....BE EXTREMLY CAREFULL BEFORE REMOVING THE THIRD BOLT MAKE SURE U OR SOMEONE ELSE IS HOLDING THE STRUT SO U DONT RUPTURE THE CV JOINTS.
Tip...Unscrew the tie rod nut for adjustment so when u out it back on u can sorta eye ball it bfeore the alignment and ur not driving crooked.
4 Heres old and new, which looks better?
5 Do exactly the opposite putting it back in, but use either a jack under the control arm or ur thighs and push up on the knuckle and brakes to line up the holes. This will be much higher then stock
Old 02-28-2006, 08:43 PM   #3
bluej511
Name's Vic
bluej511's Avatar
6 Picture of the front dropped after install
REAR INSTALLATION...Tools Needed are 17mm socket or wrench for bottom bolt and breaker bar, and 14mm wrench or socket with extension and swivel.
7 Only pic i took of the rear because its just so dam easy...One 17mm bolt on the bottom and 2 14mm nuts up top.....The bottom bolt wont wanna come out but u can use a pry bar and try to pull the bolt out or push it thru the other side of the bolt. Another way is to use a jack and a small deep socket that will fit under the strut so u can lift it up and remove the bolt...I tried all these and it didnt work for me since the bolts are old so i pried against it with a pry bar and shot it with the gun lol.
8 I decided to cut it, makes adjusting it SO SO much easier....Kinda hard to see the back nut, thats because it is lol...For installation do everything backwards, and once the wheels are tight and torqued, tighten the 14mm nut under the adjusting screw
I realized i didnt write how to put it back in so here it is. Put the lower bolt in first and tighten it. Make sure the top hat is ligned up with the 2 holes for studs. Put the jack under the suspension and jack it up until the top hat is thru the holes and then put both nuts on and tighten it.
Old 02-28-2006, 08:48 PM   #4
bluej511
Name's Vic
bluej511's Avatar
Random Pics after installation
9
10
11
Old 02-28-2006, 08:49 PM   #5
TI-10
Member
TI-10 is an unknown quantity on c-rsx
nice
TI-10 is offline   Reply With Quote
Old 02-28-2006, 08:54 PM   #6
Djstorm100
Boostifed
Djstorm100's Avatar
Djstorm100 is an unknown quantity on c-rsx
you dirty whore..lol
nice install
Motorcycle Crew#11 2008 Harley Davidson NightTrain
1991 Venom Red Mustang 306 76mm Turbo 550hp low boost.
Djstorm100 is offline   Reply With Quote
Old 02-28-2006, 08:58 PM   #7
i VieTEC
Master Member
i VieTEC's Avatar
i VieTEC is an unknown quantity on c-rsx
12 Wash the car!!!!
jk very nice write up
i VieTEC is offline   Reply With Quote
Old 02-28-2006, 08:58 PM   #8
bluej511
Name's Vic
bluej511's Avatar
REVIEW REVIEW REVIEW..
All points are from a scale 1-10 10 being the best.
Installation=7
Installation went relatively well except for the torching of the front right lower strut bolt which was seized in there. Made sure all my perches were tight, made sure pre-load setting hadnt changed. Now after everything is done go thru the hood and adjust toe by rotating the inner tie rod either towards the back or front to change toe.Try and get it as straight as possible for both wheels while making sure ur steering wheel stays straight...This is all for being able to drive to an alignment place afterwards.
Built Quality=9
The built quality on these are amazing def much better then oem built and much better then tein from what ive seen. Only reason for the 9 is no abs or brake line brackets.
Steering Feel=10
Steering feel has greatly improved, steering feels more solid. Making turns is easier and switching lanes feel safer.
Ride Comfort=10
Unbelievable.. i have mine set to 7 front and 10 rear. I gotta say it rides much better then what i had before, car feels more solid.... I will be playing around with the settings and see how it rides and if any of the perches come loose. If they havent tonight then they never will lol.
Handling=12
Sorry guys i had to give it a good rating because they truly took my breath away. And i noticed it in the first turn i took on the back roads. Why didnt my body move? Car feels so incredibly neutral, i will post again once i set my alignment.
If anyone has any questions about installation or would like me to add anything to my review then please feel free to ask.
P.S. I did find a way to adjust the rear but i didnt try it lol after almost 3hrs i just wanted to see how it handled.
Old 02-28-2006, 08:59 PM   #9
Point_particle
Complete Part Out
Point_particle's Avatar
Point_particle is an unknown quantity on c-rsx
good write up
lol @ you putting your coilover to sleep
Point_particle is offline   Reply With Quote
Old 02-28-2006, 08:59 PM   #10
bluej511
Name's Vic
bluej511's Avatar
haha FUNNY car will be washed and vaccumed on fri and then u guys will drool.
Old 02-28-2006, 09:24 PM   #11
bluej511
Name's Vic
bluej511's Avatar
Oh and i also sell these for anyone interested.
Old 02-28-2006, 09:46 PM   #12
Spent198
Spent198 is an unknown quantity on c-rsx
As always, a very nice install by Vik himself. Can't wait to see you Saturday, its been quite a while.
-Carl
Spent198 is offline   Reply With Quote
Old 02-28-2006, 10:05 PM   #13
bluej511
Name's Vic
bluej511's Avatar
Will this be stickied oh great moderator?
Old 02-28-2006, 10:35 PM   #14
Ryan
Bowchickabowwow !!!
Ryan's Avatar
Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx Ryan is a jewel in the rough of c-rsx
badass. nice guide and review.. i gotta get them now
Ryan is offline   Reply With Quote
Old 02-28-2006, 11:04 PM   #15
SpoonR
SpoonR is an unknown quantity on c-rsx
Did it drop like you wanted? Man, your state must have dirty ass road. Man, I can't believe how dirty your fender wall is. Beside that, I love it.
SpoonR is offline   Reply With Quote
Old 02-28-2006, 11:05 PM   #16
sikdalla
sikdalla is an unknown quantity on c-rsx
nice review and nice drop, now like everyone else said, she needs a wash bad !!!
sikdalla is offline   Reply With Quote
Old 02-28-2006, 11:26 PM   #17
aftershock141
///M
aftershock141's Avatar
aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top
aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top aftershock141 is not even half way to the top
Nice write-up. Glad you're enjoying them.
Big Hitter
R35 GTR
aftershock141 is offline   Reply With Quote
Old 02-28-2006, 11:35 PM   #18
vtec407
2010 Acura TSX
vtec407's Avatar
vtec407 is an unknown quantity on c-rsx
Awesome DIY. Now I can buy a set of coilovers and do it myself
vtec407 is offline   Reply With Quote
Old 02-28-2006, 11:40 PM   #19
05nbp
Senior Member
05nbp's Avatar
05nbp is an unknown quantity on c-rsx
nice write up, nice pics, i just wish it was for the megans! only reason is cuz mine are comin in thursday! i cant freakin wait. im doin the instal myself, im just confused why you took apart the whole damn coilover?!?!? lol, i was plannin to just leave the preload the way it is for the megans and adjust the shock body to the height i desire.( probably the lowest cuz the new ones come with an extra perch and make it sit a lil higher).
anyways, other than that ... yea go wash that beast and after that you can take some "random pics after install" ... lol jk .... its still an rsx which is really what matters!
"If you drive to mcdonalds ill buy... but you have to hit vtec at least 7 times or it doesnt count"
-nextdoor neighbor
2005 NBP RSX Type - S
05nbp is offline   Reply With Quote
Old 03-01-2006, 12:23 AM   #20
Ryan
Bowchickabowwow !!!
Ryan's Avatar
its mainly because for the rear coilover, the height adjustment is inside the springs and boot
Old 03-01-2006, 01:27 AM   #21
DOHCtor
I love my rally car
DOHCtor's Avatar
DOHCtor is an unknown quantity on c-rsx
damn vicken that's a super dirty car lol
nice writeup bro
Vid of me at streets of willow http://youtube.com/watch?v=rWNnDO7EHMw
Join the anti-drag racing crew
20MPG Crew
DOHCtor is offline   Reply With Quote
Old 03-01-2006, 04:06 AM   #22
04Pear12sX
O.o DC5S
04Pear12sX's Avatar
04Pear12sX is an unknown quantity on c-rsx
nice writeup bro
Agreeded The car needs a wash
04Pear12sX is offline   Reply With Quote
Old 03-01-2006, 04:22 AM   #23
NA DC5 S
NA DC5 S is an unknown quantity on c-rsx
Originally Posted by seth812
good write up
NA DC5 S is offline   Reply With Quote
Old 03-01-2006, 06:09 AM   #24
bluej511
Name's Vic
bluej511's Avatar
haha thanks guys hopefully we can get this stickied. I spend 4-5 hrs detailing the car last time and it snowed a couple days later and they salted the roads way to much so the roads dont ice up. Oh well im gonna wash it fri since its gonna snow tomorrow. i gotta find a way to clean my undercarriage to my exhaust was covered in that shit.
Old 03-01-2006, 06:10 AM   #25
bluej511
Name's Vic
bluej511's Avatar
Spoon yes it did drop exactly how i wanted it which was to keep my original drop.My lower control arms are pretty much parallel with the ground so 2in is the max drop without messing up ur LCA angles.
If these can stand up to the MA winters then u guys should be alright.
Reply
Bookmarks
coilover , diy , install
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
