DIY Taillight Gasket Replacement (Water in Trunk Fix) - Club RSX Message Board
Reply
Thread Tools
Old 02-23-2008, 06:04 PM   #1
dom7293
Member
dom7293's Avatar
dom7293 is an unknown quantity on c-rsx
Smile DIY Taillight Gasket Replacement (Water in Trunk Fix)
This is for the 02-04 RSXs that drive around with a pool of water in their trunk.
Here’s the pool
We need to find out where the leak is.
Remove your carpet, foam board, spare tire, taillight access lid, (and plastic cover if you wish).
To take off the taillight access lids, just pull… very hard
I took off the plastic cover. You don’t have to but it’s quick and it makes the job a little bit easier.
There are only 4 snaps. Just pull and they’re out.
After removing the carpet, foam board, spare tire, and taillight access lid; run water down from the top of the hatch and let it flow through the taillight. Do this until you notice where the water is leaking through.
Here’s the problem
For most people, the problem is usually that their taillight gaskets are bad.
I ordered my new taillight gaskets from acuraoemparts
Part Number: 33502-S6M-A11
Their minimum quantity is 2 so you would pay $16.16 + shipping
These are the gaskets
First thing you need to do is remove your rear bumper
s2k_3.11 has a great DIY for removing your rear bumper here http://forums.clubrsx.com/showthread.php?t=542715
Now that the rear bumper is off, you can move inside the car
Turn the bulb sockets 45 counterclockwise to remove the bulb sockets. Pull the small plug at the end out.
Remove the mounting nuts. There are four 8mm nuts on the inside, 2 screws on the outside (you already took one out when you took off the rear bumper).
I also removed one of the mounting bracket nuts (10mm) to gain full access to the taillight.
dom7293 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-23-2008, 06:11 PM   #2
dom7293
Member
dom7293's Avatar
Remove the taillight
Now you can access the old gaskets
Peel the old gasket off. It’s very sticky in some areas. Be careful not to break any of the plastic rods. Put the new gasket on.
Replace the taillight and secure it. I did my other taillight also even though it didn’t leak. Secure everything back in the order you took it off. After everything is back on, run water through the taillights again to see if it continues to leak. If it does, I don’t know what to tell you :/
BUT it worked for me so it should work for you
Old 02-23-2008, 06:21 PM   #3
mode360
JDM>USDM
mode360's Avatar
mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own
mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own mode360 must be an admin because here is no way they could have reached this amount on their own
Nice write-up
Hopefully I don't have to do this with my JDM tails
G.O.A.T. Status Crew
[SIGPIC][/SIGPIC]
Click my sig to see my minus vtak
mode360 is offline   Reply With Quote
Old 02-23-2008, 06:22 PM   #4
l e o h j
got swirls?
l e o h j's Avatar
l e o h j is an unknown quantity on c-rsx
nice writeup.
and yes you should blackout your headlights
need a detail?[L.A / O.C / I.E /SFV COUNTY] pm me for a price
DIY: BUDDYCLUB SHORT-SHIFTER INSTALL
l e o h j is offline   Reply With Quote
Old 03-26-2008, 12:34 PM   #5
skoo74
sk( . )( . )74
skoo74's Avatar
skoo74 has been a little shit in the past
damnnn.. so that's what it was!? good job!
NUDE pix of Silvia! CLICK!!!
skoo74 is offline   Reply With Quote
Old 03-26-2008, 12:52 PM   #6
ThomBoy
i has vtak!
ThomBoy's Avatar
ThomBoy is an unknown quantity on c-rsx
awesome. much needed DIY
04 ABP DC5
ThomBoy is offline   Reply With Quote
Old 03-30-2008, 08:45 PM   #7
dom7293
Member
dom7293's Avatar
Thanks! I found quite a number of threads about water leakage so I decided to do it myself and help some people out
Old 03-30-2008, 09:26 PM   #8
gthugdelux
Sure don't...
gthugdelux's Avatar
gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though gthugdelux is cool, not as cool as some though
killer DIY
awesome!!!!!!!!!!
gthugdelux is offline   Reply With Quote
Old 04-02-2008, 07:53 PM   #9
Frunkis
Casual Scum
Frunkis's Avatar
Frunkis is an unknown quantity on c-rsx
I just noticed a pool in my trunk a few hours ago. NICE!!
Frunkis is offline   Reply With Quote
Old 04-23-2008, 11:07 PM   #10
J. Dub
Search newbster SEARCH!
J. Dub is on a distinguished road J. Dub is on a distinguished road
Subscribed! Even though I got mine fixed under warranty I'm sure it will happen again later down the road. Thanks for the DIY! Pretend +rep
J. Dub is offline   Reply With Quote
Old 04-24-2008, 01:46 AM   #11
jt_13
Member
jt_13 is an unknown quantity on c-rsx
I love how your spare tire well doesn't seem to have alot of rust even with the amount of water in there...
jt_13 is offline   Reply With Quote
Old 04-24-2008, 05:09 PM   #12
dom7293
Member
dom7293's Avatar
Thanks for the pretend +rep! lol
I know i was surprised as well. I dont know how long the water had been there until i finally heard it swishing around
2003 Eternal Blue Pearl Base Manual
Show-Off Thread
My DIY: Taillight Gasket Replacement (Water in Trunk Fix)
Upcoming Mods: Tanabe Sustec Pro S-OC Coilovers, Window Tint, Hondata Reflash
Old 04-30-2008, 06:42 PM   #13
Nugwin
New Member
Nugwin is an unknown quantity on c-rsx
hellloo...dom...
Nugwin is offline   Reply With Quote
Old 04-30-2008, 08:54 PM   #14
himrin1216
In the works... ^.^; ;
himrin1216's Avatar
himrin1216 is on a distinguished road himrin1216 is on a distinguished road
wow .. nice diy lol ..
2003 ABP type S
[SIGPIC][/SIGPIC]
himrin1216 is offline   Reply With Quote
Old 05-01-2008, 07:42 PM   #15
dom7293
Member
dom7293's Avatar
Originally Posted by Nugwin View Post
hellloo...dom...
uhh... hello... nugwin... ???
Show-Off Thread
Old 05-01-2008, 08:11 PM   #16
Nugwin
New Member
this is dominic n. right...?
Old 05-02-2008, 09:29 PM   #17
dom7293
Member
dom7293's Avatar
yea thats me who are you?
Show-Off Thread
Old 05-04-2008, 11:53 PM   #18
Tony_RSX85
2006 Type Slow
Tony_RSX85's Avatar
Tony_RSX85 is an unknown quantity on c-rsx
Thanks a million dude i have that problem
Tony_RSX85 is offline   Reply With Quote
Old 07-10-2008, 01:22 PM   #19
Special_K_
Member
Special_K_'s Avatar
Special_K_ is an unknown quantity on c-rsx
life saver....my car smelled like a locker room from all of the water
Special_K_ is offline   Reply With Quote
Old 07-10-2008, 01:41 PM   #20
a2_dc5
Brevit : the soul of wit
a2_dc5's Avatar
a2_dc5 is a rep WHORE
a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE a2_dc5 is a rep WHORE
nice write up
Armenian crsx crew member #2
a2_dc5 is offline   Reply With Quote
Old 07-10-2008, 02:00 PM   #21
drumnatural
I can drive up your rsx
drumnatural's Avatar
drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though drumnatural is cool, not as cool as some though
Good Job TS
You treat your car like your girlfriend...Tender loving care along with giving her some WOT
[SIGPIC][/SIGPIC]
drumnatural is offline   Reply With Quote
Old 07-12-2008, 09:57 AM   #22
rusty832
Philadelphia Eagles >*
rusty832's Avatar
rusty832 is an unknown quantity on c-rsx
just had to do this...thanks for the write up
///M
Subwoofers for sale: http://forums.clubrsx.com/showthread.php?t=557073
Golf Clubs for sale: http://forums.clubrsx.com/showthread.php?t=558601
rusty832 is offline   Reply With Quote
Old 11-01-2008, 04:48 PM   #23
JaCkaL829
Car Care Extraordinaire
JaCkaL829's Avatar
JaCkaL829 is an unknown quantity on c-rsx
Great writeup, I just did this to my car today as well
John
2002 NBP RSX 5 spd
http://www.flickr.com/photos/jackal829/
JaCkaL829 is offline   Reply With Quote
Old 11-04-2008, 11:53 AM   #24
acuraanimal
AcurAanimal
acuraanimal's Avatar
acuraanimal is an unknown quantity on c-rsx
yea i had the same problem, i didnt feel like ordering a new gasket.. so i just took out the tail lights and on the old gasket you can see where it presses against the car. and i just put some cock(idk how to spell it) around the taillight gasket and no leaks since
cost like 3 dollars =)
Show Off thread FirePepper Red W/ show-finish
http://forums.clubrsx.com/showthread.php?t=612692
acuraanimal is offline   Reply With Quote
Old 11-04-2008, 09:19 PM   #25
GARCIA_DC5
Member
GARCIA_DC5's Avatar
GARCIA_DC5 is an unknown quantity on c-rsx
Thanks bro i`ve been trying to find the problem for about two months.Now I know what it is
GARCIA_DC5 is offline   Reply With Quote
Reply
Bookmarks
diy , fix , gasket , replacement , taillight , trunk , water
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
