DIY: 02-04 Ebay Foglights. NO SWITCH HARNESS NEEDED! - Club RSX Message Board
Reply
Thread Tools
Old 07-17-2008, 02:04 AM   #1
Peedumms
Sinister Crew
Peedumms's Avatar
Peedumms has been a little shit in the past
After looking at all of the problems members were having with wiring the Ebay fog light kits, I decided to do a full write up on how to install your fogs without that stupid switch harness that doesn't seem to have the proper connections on it. This install will make it so your fogs turn on and off with your parking lights.
Disclaimer: This is meant as a guide to help you. I am not responsible for any damage done to your car by you or anyones else that works on it using this guide.
Tools/Parts needed:
- Ebay Fog light Kit
- Relay (Can be purchased at any Car Audio store)
- Wire Crimpers
- 1 ft. each of Red, Yellow, Black, and Green wire.
- T-Taps
- 5 Female Spade connectors
- 1 Male Spade connector
- Drill with 1/4 in. Drill bit
- Airsaw or Dremel (Any cutting tool you feel comfortable make precise cuts into your bumper with)
- Painter's tape (Blue or Green variant)
- Zip Ties
- Phillips head Screwdriver
First step is to remove your bumper
Next. Lay out the ebay harness that connects to the fog light bulbs as shown in the picture. The brown plug should be on the driver's side while the ring connector should be on the passenger's side.
Run the plugs of the harness down below your headlights. I ran the harness across the radiator support. There is another harness under it you can Zip Tie the Fog Light harness to.
Driver Side
Passenger Side
Now that the harness is ran. Connect the ground ring connector to the10mm ground bolt with the dirty X under it.
Now comes the relay
Wire your relay up just like this one. The numbers of each pin should be stamped in the plastic of the relay. We used 4 female spade connectors for the connections.
Your relay pack should now look like this.
Now it's time to hook up the relay.
Connect the Yellow wire to the positive terminal on your battery. NOTE* It's a good idea to put a fuse inline between the battery and the relay. We didn't have one at time of install but have put one on since.
Peedumms is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-17-2008, 02:28 AM   #2
Peedumms
Sinister Crew
Peedumms's Avatar
Now. Connect the black wire to the Negative Terminal of the battery.
T-Tap or T Splice the Red/Yellow wire going to your corner light. Connect the red wire from the relay to the corner light wire. NOTE* The other wire in photo is the power wire from JDM sidemarkers. Don't worry about that wire.
Now use a female spade connector to connect the green wire to the fog light harness' brown plug.
Wiring up the relay is now finished. You can zip tie all the wires to make everything look clean.
Next up is the scary part. Cutting your bumper.
You can use templates. I couldn't get them to print out to the right size so we just eyed it. Definatly don't try that if you're inexperienced with cutting. There are templates on this site you just have to find them.
First. Tape off the area that is going to be cut.
We used a Matco Airsaw to do the cutting. You'll need an air compressor to use this tool though. Be sure to cut in bursts or else the plastic on the bumper will melt. That goes for dremels too.
Like I said we eyed it. We cut out the black part first and then just modified the opening as need for clearance.
The fog kit we used had plastic support brackets on the inside of the bend. So notches had to be cut to accomodate
First. Drill holes you can use to start your cut from
Then use your cutting tool to make the notches.
Make sure you test fit before moving on. The fog light should fit flush or almost flush.
Old 07-17-2008, 02:37 AM   #3
Peedumms
Sinister Crew
Peedumms's Avatar
Put on the fog light and mark the holes for the screws with a sharpie. And drill out the holes.
Slide the clips that come with the kit into place. NOTE* The slots that the clips slide into will have to be modified for the clips to fit.
YOUR'RE ALMOST DONE!!!
Now it's time to put the front bumper back on and secure it with the clips and screws. Pull the fog light plugs through the new fog light holes.
Now install the fogs and secure them with the supplied screws. And you're done!! Turn those bad boys on!
Big thanks to Justin and Chan of Project Empire for the help with the install and an additional props to Justin for helping with the photoshop. Also thanks to CRSX and Project Empire member Peter (Partiboi) for letting us use his car for the DIY.
Old 07-17-2008, 07:21 AM   #4
luckyred
Master Member
luckyred's Avatar
luckyred is an unknown quantity on c-rsx
Great write up! If only this was written when I installed mine 3 weeks ago.
luckyred is offline   Reply With Quote
Old 07-17-2008, 07:27 AM   #5
luckyred
Master Member
luckyred's Avatar
What steps would you need to take if you wanted to use a switch to turn on the fog lights instead of using the parking light switch?
Old 07-17-2008, 09:08 AM   #6
trancednovea
Let there be light
trancednovea's Avatar
trancednovea is an unknown quantity on c-rsx
Wow. Bookmarked
show - || Vis Carbon Fiber hood || carbon fiber-blue pedals || blue stitched steering wheel || weighted shift knob || Revo SS || blackout headlights || redout tail lights || Eclipse 1000w amp + 1x10" JL-Audio W3 sealed sub w/ .5 farad cap || Pioneer HU || ITR lip kit (black) || ITR wing | ABP Crew Member #30
go - || Injen CAI || PRC (type r) IM || Hondata IMG || BCRH || Hondata Reflash || ESMM || RSR GT2 Catback || Continental ExtremeContact DWS || Hawk HPS |
trancednovea is offline   Reply With Quote
Old 07-17-2008, 10:45 AM   #7
RSX-Served
Member
RSX-Served's Avatar
RSX-Served is an unknown quantity on c-rsx
Wow. One of the best DIY guides I have ever seen. Should be a sticky.
2012 BWP TSX Special Edition
RSX-Served is offline   Reply With Quote
Old 07-17-2008, 10:51 AM   #8
02Blktypes
Broke...
02Blktypes is an unknown quantity on c-rsx
sticky this!
02Blktypes is offline   Reply With Quote
Old 07-17-2008, 10:56 AM   #9
Charisma
Absolute Pro-Formance
Charisma is a name not to mess with
Nice write up! I'm stealing my dad's fogs of fhis RSX though. baaha.
1993 Civic CX H2B "True Street" Car- Sleeved, Stroked, Bullseye S366XL Induced.
1993 Civic CX B18C1 "True Street"- Sleeved, T67 Incuded 588whp low boost daily
1994 Integra- The "HOT ROD" As seen in Import Tuner
Charisma is offline   Reply With Quote
Old 07-17-2008, 03:51 PM   #10
Peedumms
Sinister Crew
Peedumms's Avatar
Instead of running the red wire to the parking light. Run it to your ACC wire or your IGNTION wire under your dash. But put a switch between the Relay and the ACC or IGN wire. Make sure you fuse any power wires.
Old 07-17-2008, 04:59 PM   #11
yukihiro
ciao-su!
yukihiro's Avatar
yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx yukihiro might be well recognized one day on c-rsx
this is an awesome write up. great job
04 type-s pwp no more..
14 wrx hatch
yukihiro is offline   Reply With Quote
Old 07-18-2008, 02:02 AM   #12
Peedumms
Sinister Crew
Peedumms's Avatar
Thanks fellas. Not too bad for my first DIY huh?
Old 07-18-2008, 02:15 AM   #13
obey562
Senior Member
obey562's Avatar
obey562 is an unknown quantity on c-rsx
nice write up man. exactly the same way i have mine wired up
Canon 40D w/ BG-E2N grip
| 17-55 f/2.8 | 50mm 1.8 | 85mm 1.8 | sigma 10-20 | 430EX | (2) Vivitar 285HV | AB800 | Cyber Sync's
obey562 is offline   Reply With Quote
Old 07-18-2008, 02:21 AM   #14
Peedumms
Sinister Crew
Peedumms's Avatar
Great minds think alike.
Old 07-18-2008, 02:32 AM   #15
1shot1kill
mmm..
1shot1kill's Avatar
1shot1kill is on a distinguished road 1shot1kill is on a distinguished road
good job.
1shot1kill is offline   Reply With Quote
Old 07-18-2008, 02:41 AM   #16
partieboi
Taingo
partieboi's Avatar
partieboi is an unknown quantity on c-rsx
bump, bump it up. for a great writeup on my car .
04 PWP RSX-S
The mod bug is back!
partieboi is offline   Reply With Quote
Old 07-18-2008, 06:55 PM   #17
aznclarity
無限
aznclarity's Avatar
aznclarity is an unknown quantity on c-rsx
so if i have jdm side markers spliced into the parking light a long with the fogs i dont need to change anything right? it wont be overpowering or anything like that?
'02 ABP-S
AznClarity's Official Picture Trail!! http://forums.clubrsx.com/showthread.php?t=557324
aznclarity is offline   Reply With Quote
Old 07-18-2008, 11:53 PM   #18
Peedumms
Sinister Crew
Peedumms's Avatar
No, you'll be ok. The relay is pulling most of the power from the battery. The wire from the corner light is just a signal input for the relay telling it to switch on and power the fogs. I have the exact same set up on my 04 DC5 and I've had no problems. If it really worries you though just put a fuse between the relay and the parking light wire. Then in the small chance that something does go wrong, the fuse will pop and the wires and bulbs will be saved.
Old 07-23-2008, 02:23 PM   #19
RsxJatt
bLaZinRsX
RsxJatt is an unknown quantity on c-rsx
great write up timfor my fogs
RsxJatt is offline   Reply With Quote
Old 07-23-2008, 04:21 PM   #20
riceman
WWJDMD?
riceman's Avatar
riceman has been a little shit in the past
Awesome job. I had fog lights done this way on my DA, but decided to add a switch for those "keep it on a down low" situations. Fog lights attract too much attention sometimes.
92 Frost White Integra LS-Vtec - 2.1 NA - sold
06 PWP Type-S - little show limited go
08 UG R32 - sold
Rice fo Life y0!
riceman is offline   Reply With Quote
Old 07-23-2008, 05:20 PM   #21
samuraikc
New Member
samuraikc is an unknown quantity on c-rsx
Great write up, much easier than the install manual suggests, haha.
I've had mine wired up for about a month, but every now and then they turn off due to a faulty connection with the wire tap and the parking light. does this ever happen to you?
samuraikc is offline   Reply With Quote
Old 07-23-2008, 07:06 PM   #22
khang637
Senior Member
khang637 has been a little shit in the past
Awesome write up!!! Just what I've been looking for!
MAX POWER!
khang637 is offline   Reply With Quote
Old 07-23-2008, 07:15 PM   #23
KazeSpec
Engineering
KazeSpec's Avatar
KazeSpec is loved by everyone on c-rsx
KazeSpec is loved by everyone on c-rsx KazeSpec is loved by everyone on c-rsx KazeSpec is loved by everyone on c-rsx KazeSpec is loved by everyone on c-rsx KazeSpec is loved by everyone on c-rsx KazeSpec is loved by everyone on c-rsx
Peedums, with your permission I'd like to link this to my DIY fog thread. Great idea to fix all the problems we've been having nowadays with the ebay kits.
KazeSpec Engineering, Pro-Car Innovations, European Auto Source, TrackTactics
Race car is gone, now tracking the bike
All Motor Crew#8, Motorcycle Crew #37
KazeSpec is offline   Reply With Quote
Old 07-23-2008, 10:52 PM   #24
Peedumms
Sinister Crew
Peedumms's Avatar
Thanks, yeah you can link it. No prob.
Old 07-23-2008, 10:55 PM   #25
Peedumms
Sinister Crew
Peedumms's Avatar
No I haven't had this problem. You can always t-splice the wire and solder the wire for a better connection.
Reply
Bookmarks
0204 , diy , ebay , foglights , harness , needed , switch
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
