P1078 - Intake Manifold Runner Control (IMRC) System Malfunction (High rpm) - Club RSX Message Board
Go Back   Club RSX Message Board > GENERAL RSX > Problems & Solutions RSX
Reply
Thread Tools
Old 11-27-2008, 08:49 AM   #1
TommyGunRSX
Member
TommyGunRSX is an unknown quantity on c-rsx
There was a thread on this before but no definite answer. The car runs rough at both high and low rpm
Has anyone had this problem before and found a fix?
Is it a complete replacement of the intake manifold or a fix of the part.
If so, how much did it cost?
The car is running rough as hell and I'm afraid this issue is going to cause some other issues.
Any help would be appreciated
TommyGunRSX is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-27-2008, 09:26 AM   #2
Sephitrask
Rotary Trooper
Sephitrask's Avatar
Sephitrask is an unknown quantity on c-rsx
here you go man. this is more than likely the same thing that you have.
http://forums.clubrsx.com/showthread...Runner+Control
Sephitrask is offline   Reply With Quote
Old 11-27-2008, 09:42 AM   #3
TommyGunRSX
Member
This problem is the sensor however, my issue deals with the actual runner I believe. Thanks though
Any more suggestions?
Old 11-27-2008, 04:45 PM   #4
rensoyka
Breast inspector by appt.
rensoyka's Avatar
rensoyka is an unknown quantity on c-rsx
unless there a problem with the vacuum hose or the wiring, the manual advises to replace the solenoid valve.
'06 black type-s.
rensoyka is offline   Reply With Quote
Old 03-01-2010, 12:32 PM   #5
Nate2003
pain = gain
Nate2003's Avatar
Nate2003 is on a distinguished road Nate2003 is on a distinguished road
I had a tech look at my car over the weekend with the same error code and was saying I needed to replace the solenoid. I called up Acura while ago and explained to them the best I could about what I needed IMRC solenoid and they acted like they were clueless.
Any ideas on where I can get this part?
2003 RSX DSM/A-Spec Lip Kit/DrifZ 517GM 18s/JDM Style Headlights/Red Outs/35% tint/Debadge/Pioneer AVIC-D3
<CRSX Zombie Eradication Team Member #13><TN Crew Member #2>
Nate2003 is offline   Reply With Quote
Old 03-01-2010, 12:43 PM   #6
Nate2003
pain = gain
Nate2003's Avatar
Does this sound right?
36163-PND-A01 VALVE ASSY., BYPASS CONTROL SOLENOID 2003 RSX
Old 03-01-2010, 12:56 PM   #7
TommyGunRSX
Member
yes, most mechanics will give you the WTF look when you mention that code.
I replaced that part. It came as an assembly with the sensor attached to the runner value and chamber. I fixed it last year and it seemed to fix the problem.
When replacing it, you have to remove the entire intake manifold so watch out for the coolant bypass hose (plug it before hand).
Old 03-01-2010, 01:07 PM   #8
Nate2003
pain = gain
Nate2003's Avatar
So you were verifying that is the correct part I'm after?
Remove the entire intake manifold? Is that all that hard? Tech was saying it would be rather simple just one bolt and a couple of hoses.. but just what he mentioned.
<--- not a mechanic
Old 03-01-2010, 02:30 PM   #9
TommyGunRSX
Member
014 17120-PPA-A01 VALVE ASSY., ROTARY
That was the solution to my problem. If you look at the diagram, it has the chamber attached to the long part (runner valve).
The runner valve with the chamber must slide out (towards passenger side) out of the intake manifold. Therefore, you must remove the entire manifold assembly. It is all one piece (chamber and runners).
Old 03-26-2010, 10:19 AM   #10
Jturner2010
New Member
Jturner2010's Avatar
Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx Jturner2010 is a jewel in the rough of c-rsx
how much did it cost to fix your car and running rough how so cause i have the same code and its jerking and surging on me all the time really bad. did u have to replace the whole intake maniold or could u buy seperate parts for it...
<----------- also not a mechanic but very hands on
Jturner2010 is offline   Reply With Quote
Old 03-26-2010, 12:53 PM   #11
TommyGunRSX
Member
Parts cost me around 150-160. Labour is about 1.5 hours, even faster if you're familiar with removing IM. You don't have to replace the entire intake manifold assembly but the entire unit has to be removed.
All you have to replace is the runner valve which spans the entire width of the manifold once installed.
I can ran sluggish like I had lost all power or had a major vacuum leak.
I'm just B.C. too so hope this answers some questions
Old 03-27-2010, 12:28 AM   #12
paulkramer
Member
paulkramer's Avatar
paulkramer is an unknown quantity on c-rsx
You can buy the solenoid separately - you don't have to buy/replace the entire runner.
Why do you guys think replacing the solenoid alone won't fix his problem?
paulkramer is offline   Reply With Quote
Old 10-24-2010, 10:53 PM   #13
cryptic
Former 240sx GURU
cryptic's Avatar
cryptic is an unknown quantity on c-rsx
thread revival...
haveing same issue.. what resolved it? need to know...
do i need to replace entire unit or just little box...
my rsx is runnin like shit...
Back to stock
2012 Mustang shelby On route
cryptic is offline   Reply With Quote
Old 10-25-2010, 10:23 PM   #14
Jturner2010
New Member
Originally Posted by cryptic View Post
thread revival...
hey do you have a cold air intake
Old 11-09-2010, 05:39 PM   #15
cryptic
Former 240sx GURU
cryptic's Avatar
no CAI...
all stock.. this isnt intake related its all manifold issues... stupid high low switching bullshit...
Back to stock
Old 11-23-2011, 02:46 PM   #16
ruiMTB
Member
ruiMTB's Avatar
ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx ruiMTB is a jewel in the rough of c-rsx
bringing this back...
having a similar issue
cel comes on and off and came back on today so i had it scanned and got this code with two others that are for another issue. i wanted to look into fixing this issue but not sure what to get.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
would i need the whole assembly or just the solenoid?
in that link, #14 or is the solenoid #16?
thanks in advance!
ruiMTB is offline   Reply With Quote
Old 11-25-2011, 07:20 PM   #17
Cb7-R
Sacked!!
Cb7-R's Avatar
Cb7-R is an unknown quantity on c-rsx
thanks in advance!
Try Seafoam through the brake booster line.
ASE Master/L1 Technician
Cb7-R is offline   Reply With Quote
Old 08-25-2012, 01:47 PM   #18
jshoe
New Member
jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx jshoe is a jewel in the rough of c-rsx
i have same prob with 2002 honda crv p1078 intake manifold tuning valve stuck
thinking 19 37890-PND-A01 SENSOR ASSY., ANGLE would fix issue
any thoughts?
jshoe is offline   Reply With Quote
Old 01-24-2014, 05:32 PM   #19
jonathanrivera545
New Member
jonathanrivera545's Avatar
jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx jonathanrivera545 is a jewel in the rough of c-rsx
I need help guys I have the same issue can anyone help me out?
jonathanrivera545 is offline   Reply With Quote
Old 01-25-2014, 04:57 PM   #20
jonathanrivera545
New Member
Any updates pls
Sent from AutoGuide.com Free App
Old 01-25-2014, 05:07 PM   #21
jonathanrivera545
New Member
Bump help me out pls
Old 02-26-2014, 05:16 PM   #22
ruiMTB
Member
ruiMTB's Avatar
You're just throwing the code? Did you do anything to troubleshoot?
Old 02-25-2015, 07:17 AM   #23
AntwonSoup
New Member
AntwonSoup's Avatar
AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx AntwonSoup is a jewel in the rough of c-rsx
IMRC Solenoid worked for p1078
I understand that this is an old thread, but I've been studying these message boards for months to fix this problem. I just got the IMRC Solenoid and replaced it yesterday, which effectively killed the p1078 trouble code. I hope this helps others who are having this problem.
AntwonSoup is offline   Reply With Quote
Old 02-25-2015, 07:45 AM   #24
ruiMTB
Member
ruiMTB's Avatar
Is that part in this diagram?
Old 02-25-2015, 09:09 AM   #25
AntwonSoup
New Member
AntwonSoup's Avatar
No, when you're on the parts listing page, it will be under
'INSTALL PIPE - TUBING'
IMRC Solenoid is part # 020; 36163-PND-A01
Reply
Bookmarks
control , high , imrc , intake , malfunction , manifold , p1078 , rpm , runner , system
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
