D.I.Y Electronic Power Steering - Club RSX Message Board
Reply
Thread Tools
Old 09-20-2010, 02:23 PM   #1
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Type-Spaz has disabled reputation
So I finally finished converting my car to electronic Power Steering the other day and I made a small DIY for you. Let me just say this is an easy swap and most people are worried about it but after doing it I realized just how easy it is.
This is also an updated version with new Info than erik lozas DIY and this version works for 05 PEOPLE with NO dakota digital box!!!!
First here are all of our parts!
Rack and Pinion
Tie Rod Ends
Brain Box
Wiring Harness
EP3 Brackets
First thing first we need to rip out the Hydraulic Power Steering lines and pump. I already did that as I'm running no P/S
So first lets unbolt the wheels and un bolt the tie rod ends
next for more clearance I took out this lower bar
then unbolted the PS rack from the RSX brackets
Then go inside the car and unbolt the 10mm bolts holding on the ujoint on the steering shaft
Now unbolt the brackets from the frame and rip out the rack and pinion
Now lets compare the RSX and EP3 racks
HERE IS THE NEW INFORMATION~!!!
The inner tie rod ends are the same!! There is no need to swap the entire tie rod assembly like everyone else!!!! Only the outer tie rod ends are different and need swapping! So take a wrench and swap them out!
Here you can see the difference in the rsx and ep3 tie rod ends. The RSX is much thicker going into the strut assembly.
Now lets slap in the new EP3 rack and pinion and bolt it up to the new EP3 Brackets you also needed.
So now you rack is in and it's time to do the wiring... There is not much to it!
** Ivy is official SOLD **
Good buy RSX World.....
Type-Spaz is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-20-2010, 02:24 PM   #2
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
So first thing I did was go inside the car and run the new wiring harness threw the location of the stock wiring harness. Under the carpet footboard for the gas pedal. Then pulled the wire out into the engine bay and up to the eps rack
Now I mounted my box and plugged it in
But we need power! For this I made a custom plug into the factory plug and ran a power wire out the fender to my fuse box. You can either go to the fuse box like I did or go to the battery like Loza did. I went to the fuse box because I relocated both box and battery and my box was closer!
and here is where I went into the fuse box. I decided to add a inline fuse. I used the power source on the left which is coming straight from the batter. So if you wanted you go also go straight to the battery instead of the fuse box. But for me my fuse box is closer than my battery.
I then cut a small opening for the cable on the lid
Old 09-20-2010, 02:29 PM   #3
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
Now onto the ECU wiring! You only need to add three wires to the new EPS. Engine RPM, Vehicle Speed, and constant power!
I tapped into the hondata jumper harness using three different colored wires to identify each one!
here I tap into the lines
Blue White goes to pin A18 VSS sensor (vehicle speed sensor located in tranny)
Solid Blue goes to E26 NEP (Engine RPM or Engine Speed Sensor)
Yel goes to pin E9 IGN power (this is IGN to let the BCU know when engine is running)
02-06 ECU diagrams are the same. refer to Hondata for ECU pin out.
http://www.hondata.com/help/kmanager/
Reference > ECU connectors
Connector A (2p)
THICK blue/white is +power for EPS system 60A fused
THICK BLACK is - PG Power ground to chassis
Old 09-20-2010, 03:02 PM   #4
Drewpreme
( ‾ʖ̫‾)
Drewpreme's Avatar
Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top Drewpreme is not even half way to the top
Drewpreme is offline   Reply With Quote
Old 10-10-2010, 10:40 PM   #5
Dickbowlmidz
Still here
Dickbowlmidz's Avatar
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more Dickbowlmidz is a super person....that needs to get out more
how long did the whole install take for you?
InFamous / ThePremSociety / Hellafunctional
Dickbowlmidz is offline   Reply With Quote
Old 10-10-2010, 10:58 PM   #6
SHOGUNN
Master Member
SHOGUNN's Avatar
SHOGUNN has been a little shit in the past
damn dude...nice work!!...sweet DIY!!...where did you pick up the EPS? and whats the best place to look??
Mag Tuned
SHOGUNN is offline   Reply With Quote
Old 10-11-2010, 07:54 AM   #7
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
being that I have one bum arm and was doing it by myself I took a break here and there. But it took maybe 2-3 hours tops. Not long at all.
I picked up everything from a local salvage yard. I would start buy finding a nice yard and calling them up
Old 10-11-2010, 08:29 AM   #8
Dickbowlmidz
Still here
thanks
Old 10-11-2010, 09:07 AM   #9
zurmagus
Master Member
zurmagus's Avatar
zurmagus is an unknown quantity on c-rsx
Great writeup. It looks much easier than I thought it would be. I need the brackets and sub harness so I can get mine installed.
I have an 05 as well - can you elaborate on how it works without the dakota digital?
zurmagus is offline   Reply With Quote
Old 10-11-2010, 09:48 AM   #10
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
just heading into work I'll elaborate on my lunch break.
Old 10-11-2010, 12:25 PM   #11
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
So to answer your question Zurmagus
There are three wires from the EPS harness you need to tap into the RSX ECU. The colors will match for two of them. But obviously from my photos I taped into the jumper harness not the actual harness. The two wires in the harness are VSS and engine RPM. Blue wire and blue with white wire. The hitrd wire from the EPS is just constant power I went into the fuse box for that.
Pros and Cons:
Pros - my steering is fast as hell and extremely sensitive! You can make the sharpest turns and fastest on ramps with just a finger its so awesome...
Cons - Power Steering doesn't kick in right away it needs to readjust for the different VSS. So once I hit like 5-10mph it starts working. So if you need to turn sharp right away when turning on your car no P/S. (AT LEAST FOR ME) But EPS rack with no PS is a shit ton easier to turn the Hydraulic rack with no PS. Also another con is EPS is speed sensitive. With the different EPS the PS is only on or off for the 05 guys. But I have no complaints and love it!
Old 01-08-2011, 12:52 PM   #12
1JZ Type-S
1JZ Type-S is an unknown quantity on c-rsx
Great writeup, bro. What gauge wire did you use to connect the brain box w/ the ECU & fuse box? Also, did you do this with your motor out, or in?
1JZ Type-S is offline   Reply With Quote
Old 01-08-2011, 01:11 PM   #13
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
My motor was in. And I used a 12 gauge cable if I recall correctly...
Old 01-08-2011, 01:27 PM   #14
1JZ Type-S
Ok. For the fuse box.....What fuse did you use? 10,12,15, etc??
Also....Did you have to change your belt, when you took out your ps pump? Or did you retain the oem belt?
Old 01-08-2011, 01:37 PM   #15
itsBryan
Nomnominin'
itsBryan's Avatar
itsBryan has a clean start itsBryan has a clean start itsBryan has a clean start itsBryan has a clean start
GO LAKERS!!!
Originally Posted by imbest123 View Post
piece of shit rsx fucking gay ass raping penis tucking car full of fwd failfucking fuck shit rsx sucks my dick...fwd
Originally Posted by MatchbookSS View Post
FWD is for faggots.
E46 ///M3
itsBryan is offline   Reply With Quote
Old 01-08-2011, 01:40 PM   #16
1JZ Type-S
Old 01-11-2011, 09:45 PM   #17
OgLOc
PSN: TomasTheTank
OgLOc's Avatar
OgLOc is an unknown quantity on c-rsx
I would like to know also
OgLOc is offline   Reply With Quote
Old 01-11-2011, 09:47 PM   #18
OgLOc
PSN: TomasTheTank
OgLOc's Avatar
Great writeup by the way
Old 01-11-2011, 10:39 PM   #19
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
You would obviously have to change belts since you no longer have power steering to go around. The belt would be WAY to big to reuse.
As for as your fuse question not sure what you mean by 10,12 15? And I actually changed my setup a little bit I will take a photo of it for you and change it on the DIY
Old 01-11-2011, 10:48 PM   #20
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
new fuse pictures added
Old 01-11-2011, 10:49 PM   #21
Dickbowlmidz
Still here
still havent found a totalled ep3 in my area yet
Old 01-11-2011, 10:51 PM   #22
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
go sabotage one...
Old 01-11-2011, 10:56 PM   #23
Dickbowlmidz
Still here
Old 01-11-2011, 11:16 PM   #24
josolanes
Master Member
josolanes's Avatar
josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx josolanes might be well recognized one day on c-rsx
Did you use the K-Tuned adjustable idler pulley for belt routing? Here: http://www.k-tuned.com/store/index.php?cPath=17
And pics of your belt routing without the PS?
SOLD - 2002 ABP RSX-S | RIP - 2003 DSM Base RSX
josolanes is offline   Reply With Quote
Old 01-11-2011, 11:27 PM   #25
Type-Spaz
Hybrid-Racing.com
Type-Spaz's Avatar
I am supercharged...... so my belt routing will be different if you are not.
Here is my bad drawing lol
So if you aren't supercharged you can either go with that k-tuned setup or go the cheaper route and use the Honda Civic EP3 idler pulley
Reply
Bookmarks
diy , electronic , power , steering
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
